replacement front triangle for 05 x1- Mtbr.com
    i have a 2005 L x1 in army green.it has a hydroformed top tube.i have cracked the down tube recently and the supplier here in uk does a crash replacement deal.only they dont have any 05 frames.will an 07 front triangle fit my 05 swingarm.they look the same.
    Reputation: downhilljill's Avatar
    Apr 2005
    Frames are the same. You should be good to go.
    Jill,
    I had been meaning to ask, and this is the perfect opportunity. On the 07 Werx7 Geo is listed at 71* head angle. On the X7, it's listed at 67*. Is it just a different swingarm/shock mounting location that changes the geo? If so, could you slap an 07 X7 swingarm on an 05 X1,2,3 front end and get the slacker HA? If so, what's the PN for the swingarm, MSRP, and required eye2eye and stroke shock?
    Thanks,
    Chris
    Apr 2005
    Wow, you just found a really blatent error on our website. Goes to show no matter how amny times you proof your site before going live with it, you never catch everything. The correct geometry for the Werx 7 is exactly the same as the X7.
    Thanks for helping catch that error...I have our web guy on it right now to get it fixed.
