Pivit Rear Hub- Mtbr.com
Results 1 to 12 of 12
Thread: Pivit Rear Hub
    Pivit Rear Hub
    May I know the diameter of the PIvit Rear Hub installed on Haro X6?
    And other specs also may help.
    Thanks.
    Reputation: downhilljill's Avatar
    Apr 2005
    Quote Originally Posted by glenjoyrosana
    Thanks.
    Diameter? Are you trying to order spokes to re-lace a wheel to the stock rim?
    Or maybe you mean axle width? (It's 135mm; standard MTB spacing)
    If you tell us what you are trying to accomplish, it will help give you the correct info.
    What is the size of the dropout for Haro X6?
    Thanks.
    Thanks.
    Thanks.
    Please delete multiple posts.
    Thank you.
    Apr 2005
    Axle size? 10mm. Standard MTB size.
    Axle size of Pivit is 10mm right? How about the dropouts of the frame? X6 2007 frame.
    Shop *****
    Reputation: drakan's Avatar
    10mm, quick release standard...
    Quote Originally Posted by <sL4yEr>RuLz
    All good suggestions. What kind of "ass-orderant" would you recommend?
    Quote Originally Posted by drakan
    You are talking about the hub or the frame drop out?
    Shop *****
    Both are the same
    Apr 2005
    Yes, both are the same. Bikes that are designed to have standard axles will have standard drop outs. Bike that have oversized axles will have oversized drop outs. The X6 bikes are standard axles.
