Haro Mary Pictures/Info/Comments Thread - Page 2- Mtbr.com
Page 2 of 2 FirstFirst 12
Results 201 to 333 of 333
  1. #201
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Sooo wheres the Porn
    Formotion Products
    http://www.formot
  2. #202
    May 2010
    Porn coming soon. I had to get all of the vehicles and other toys packed back into the garage because I was afraid is was going ot hail...so no pics tonight.
    Also, to add to my list of first impressions, the fabrication work on the frame is impressive. The welds are unreal. I've carried the American Welding Society Certified Welding Inspector card for almost 5 years now and I've not seen welds on chromoly like these before. Every single weld is super uniform in shape and size from end to end, even when they go around a tube. All of the starts and stops are perfect. I'd really like to see how Haro does it.
  3. #203
    Reputation: downhilljill's Avatar
    Apr 2005
    Quote Originally Posted by crankin
    We use one of the best frame builders in Taiwan to make the Mary frames. They make frames for several extremely high-end bike companies (some of which don't readily admit that their frames are made in Taiwan). It's a truly amazing factory with many talented frame builders/welders.
  4. #204
    Jan 2005
    Quote Originally Posted by downhilljill
    Thats impossible no one would lie/stretch the truth about such a thing!!!!
    Formotion Products
    http://www.formot
  5. #205
    May 2010
    All good so far, except...
    I've been putting some miles on and getting used to the ride. I'll spare you guys all the blubbering about how great this bike is...you already know. I do have a couple little things I need to ask you Mary experts though:
    First, I have a light clicking sound coming form the bike with each pedal stroke, left or right. I suspected the stock Wellgo pedals but when I swithced to my Fishbone bite-me platforms the click was still there. I checked the bottom bracket set screws and they are tight. The headset seems fine too. I also cheked the frame and it looks A-ok. Any guesses? It's driving me crazy.
    Second, if I had to name one weak component on the whole bike it would be the brakes. They just seem a level lower than the rest of the kit. I've got them dialed in as best as I can, and they are still just ok. I burned them once on a long downhill, mostly my fault for being a chicken chit but still, I was beyond my comfort zone and wanted to slow down...thats what brakes are for. The also seem to get a little noisier every ride...they aren't squaling or anything near loud, but they squeak and chirp and pulse a little when I'm really on em.
    Lastly, I'm new to the 29er world and also the single speed world. The learning curve isn't bad at all, just keep the momentum up and carfully pick your lines. The one thing I'm still battleing is getting the front end up. Wheelies, manuals, and hops are still a bit difficult for me on this bike. I'm not sure if the 29 geometry or the gearing is the difference or maybe I just haven't got the bike fitted perfectly to me. I guess I'm just looking for some pointers or suggestions. I've been out in my driveway all night working on wheelies...my neigbors must think I'm losing it.
    All things considered I love this bike. She's a solid, fun machine that has opened my eyes to a new type of riding, and my legs are getting stronger every day!
  6. #206
    master blaster
    Reputation: veloreality's Avatar
    and with woodchippers
  7. #207
    ridin' Mary
    Reputation: OhNooo's Avatar
    Hi crankin,
    For the creak, I've heard it from two sources on this bike:
    1) The bottom bracket. I've taken the EBB out and wrapped the ribs that mate with the frame with 2 layers of teflon plumbing tape to prevent metal on metal movement. This works surprisingly well. But it's rather tough to get the EBB and plumbers tape back into the frame without losing the tape somewhere. Give it lots of trys and eventually you will get it all together with the tape and this will quiet down the bottom bracket a lot.
    2) The seatpost. For some reason, the Mary was designed with an odd sized seat tube and requires a shim to get down to the 31.6 seatpost size. This is my only real beef with this frame. Make sure to grease up the seatpost well to help avoid noises from this source.
    Regarding the brakes, my 2007 Mary came with BB5s which are useless. I don't know if that's what still comes on the newer Mary's. I replaced them within a couple of rides with BB7s which are far superior. BB5s look like disc brakes but don't act like them.
    And regarding wheelies... riding a wheelie on a 29er is trickier than a 26er due to your hubs being farther off the ground. Any error forward/back requires more adjustment effort due to larger wheel size. So riding a long wheelie is something I just don't try. But I haven't found this to be an issue at all while riding on the trail. I have a 20" frame which is a little bit small for me and I added an additional 1" of stem to stretch this out. Even with this long stem, this bike is great for getting up steps. I've never had a bike that was so balanced that I could get either wheel off the ground at will with very little setup time required to lift the wheel.
  8. #208
    May 2010
    Thanks OhNooo, I'll have to do some tinkering after my ride tonight. And the 2010 still comes with BB5's. What's a good price for bb7's? Is it a just a straight swap for the bb5 components? I've already got a good home for the BB5's so I'm ready to upgrade.
  9. #209
    ridin' Mary
    BB5->BB7 is a direct swap. Keep the same rotors and mounts if you wish. You should be able to find BB7s at roughly the same price everywhere since they are as common as dirt.
  10. #210
    Jan 2005
    Formotion Products
    http://www.formot
  11. #211
    SSolo, on your left!
    Quote Originally Posted by OhNooo
    Hi crankin,
    Can also coat the bb in white grease before installing it into the frame, this keeps dirt out and that helps keep it quiet. Mine has not been much problem at all even riding in really wet and sandy/muddy conditions. Did the grease trick to help keep it clean and corrosion free...makes adjustment easier too.
    BB5s are ok for a bike path (paved) but no good off-road. Replcaed mine with BB7s (aobut $35 per caliper nib on the bay) just re-use rotors, cables, etc. Got Juicy 3.5s on it now with G2 rotors and this is even better. Sell the BB5s before the pads get worn down! My seatpost has been ok until a crash when the two-piece deal at the top rotated in the post part of the seatpost. It now creaks sometimes but has stayed put after I grabbed the saddle and twisted it back. No, it was not the post twisting in the frame! I'll ride it until it gets loose enough that it won't stay put or the occasional creaking pisses me off. Any good set-back seatpost recommendos that are forged, not machined? Not a fan of Thompson products.
    Get off the couch and ride! :)
  12. #212
    I wasn't aware that there was any major difference between the BB5 and BB7 brakes beyond some additional adjustments available in the BB7.
    I swapped in some big rotors on my Mary (203 front and 180 rear) and the BB5s are working fine.
  13. #213
    do the BB5s take a little while to break in and develop some bite?
    my first ride on the bike was downright scary, the brakes had no bite even when I was squeezing the brakes really hard.
    I dont remember any break in period on the XT hydros on my Giant
    The mountains are calling and I must go
  14. #214
    Quote Originally Posted by bgredjeep
    BB7 has about twice the swept pad area. and inner/outer pad adjusters.
    Quote Originally Posted by Evan55
    Yes, they need to wear in. Might check adjustment too, but they are under powered imo for off-road.
  15. #215
    ?hipster?
    Reputation: Moementum's Avatar
    I've used the BB5's on all kinds of crazy descents, like any brake they need to be set up correctly. Some people actually like them better because of the one fixed pad. YMMV
  16. #216
    Apr 2005
    I'm lusting for Mary after reading this entire thread. I have an opportunity to buy a 2007 ginger or a 2010 black. The 2010 is about 300 bucks higher. Both are lightly used and bone stock. I know the 2010 has a different frame, and I noticed that no one posted about a 2010 at all. Is there something wrong with the 2010?
    Also, I've never ridden a 29er of anykind, including a single speed. I am currently on a Trek 8000 21". Am I a dummy for impulse buying a Mary 20" over the web based purely on reviews and widespread praise?
    Do it, I did and no regrets... I changed my mind about running a single, and with the help of the forums and haro godess downhilljill, I ordered a RD hanger and now have a 9 speed (3x3 on the stock hub)...
    First built bike I've bought this millenium, it was worth it!
  17. #217
    Reputation: 1stiski's Avatar
    Quote Originally Posted by veloreality
    Was that crank ring and rear cog stock with the 2010? IF not, where did you score them?
    2010 Surly, Curry "Pugs"
    Surly, Gray "Pugs" R.I.P.
    2010 HARO, Mary SS
    Kona "Deluxe" roadbike
  18. #218
    My Mary
    After many years waiting the local shops - or in my country- to bring some 29ers, I order my Mary on-line. This done a couple of months before. Other riders look at me like an alien; a bike without gears and front suspension -at least- can't be mountain bike!!!
    Never mind, I enjoy so much riding my bike so I don't care what they think.
    So, here is my Mary:
    Upgrade BB7
    Charge Spoon
  19. #219
    Jan 2005
    Quote Originally Posted by selin
    Awesome bike and the country side wowzerz!!!
    Formotion Products
    http://www.formot
  20. #220
    Quote Originally Posted by dogonfr
    X2....................nice!
  21. #221
    Apr 2005
    Veloreality...LOVE what you've done with you Mary SS!!! Looks awesome. Love the dirt drops!
  22. #222
    O.T
    O.T is offline
    Quote Originally Posted by dbo43867
    I like my Mary so much I though it would be fun to start a strictly Mary SS/Mary XC forum. Here you can post your pictures, stories, comments, and questions on the Mary.
    I wonder how the Mary comes in the package when I ordered the whole bike (from Winstanleysbikes).For example: is the crankset already putted on the bike, or do I have to put it by myself?
    Question2: Do you need a longer chain if you change the freewheel from 20t to 16t or the front ring from 32t to 36t?
  23. #223
    Quote Originally Posted by O.T
    I had to assemble the bars, pedals, front caliper and rotor and the wheel of course; everything else was already put together.
  24. #224
    O.T
    O.T is offline
    Thank you for the info!
    Which tool did you need to put the rotor?
  25. #225
    25 torx.
  26. #226
    Mary in Mexico
    I have had her nearly a year down here in ol Mexico and she is the perfect bike for the cobblestone streets and dirt roads laden with holes.
    I cant say enough good things about this bike.
    Ive got a anodized gold mary bar on the way from england and a brooks saddle to add the finishing touch.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-bike-haro-006.jpg
    Haro Mary Pictures/Info/Comments Thread-bike-haro-007.jpg
    Haro Mary Pictures/Info/Comments Thread-bike-haro.jpg
  27. #227
    ?hipster?
    That trail appears a bit moist!
  28. #228
    Reputation: rob.char's Avatar
    ride rivers much haha
    Mary ss shenanigans
  29. #229
    O.T
    O.T is offline
    Have to ask one more question. Which tool did you use when you changed the rear cog?
    P.S I got my Mary today! Looks nice with those big wheels, have to take pictures later today.
  30. #230
    Reputation: killn's Avatar
    You have to use a lock ring removal wrench, and a chain whip.
    Or a big hammer and screw driver if ur wana be caveman about it
  31. #231
    O.T
    O.T is offline
    Quote Originally Posted by killn
    This is too small for that lockring. Could you give me a model name?
    Is this the right tool?
  32. #232
    Yeah the second link you posted is the correct tool to remove the lock ring. You will also need one of these to keep the driver from spinning while you remove the lock ring.
    https://www.parktool.com/products/bi...5729_81070.jpg
  33. #233
    Quote Originally Posted by sweetchiba51
    shockfinder.....ride that thing on trails!! I used to have the same fears with my Mary, but when I overhauled my Nomad I rode it! The 29 inch wheels ride over anything, its sooooo fun! Try it, your skills will improve as well! I can ride any trail on my Mary, no problem!
    I'm in on this one too, This bike rocks on the single track, don't fear the technical, you'll smoke right through the tough stuff. I've become an anti-suspension fan. You would be amazed what a ridged can do.
    2010 HARO, Mary SS
  34. #234
    Reputation: kingbobyjr's Avatar
    Love my Mary!!!
    It is 2007 that I bought used a few weeks ago. It has some upgrades with a few more on the way.
  35. #235
    Quote Originally Posted by kingbobyjr
    Love my Mary!!!
    Love mine too, she's such a fine girl.
    2010 HARO, Mary SS
  36. #236
    my new baby
    have you guys noticed the chainring touching the chainstay? I haven't touched the cranks since I got it, so it's the way I got it, but I've noticed some oil on the chainstays where the chainring is. As it is there's maybe 2mm gap between the ring and frame, but I think when I'm pushing the gear the frame bends enough for the ring to touch the frame. Anyone else noticed this?
  37. #237
    Quote Originally Posted by opnykanen
    my new baby
    I am using my Mary for Cyclocross and running a 36T up front. I moved the chainring to the outside of the spider and took the bashguard off. I don't think singlespeeds should have bashguards anyway. Doing this will probable require you to space the rear cog outwards as well. Do you have a spanner and chainwhip to take off the rear cog?
  38. #238
    Reputation: backcountryeti's Avatar
    Just picked up a '08 Mary SS off of the local craigslist for cheap. And its only been ridden 3 times! Looks brand new! I wanted to buy one of these in '08, but couldn't find one and my shop at the time would not bring one in just for a test ride, so I ended up with a GF Rig. 2 years and 2 broken Rigs later, I now have a Mary! Sweet. If this bike lasts like my old Haro V3, then I will be more than happy! Great stuff!
  39. #239
    Mary size
    Hi Bikers,
    Thinking of buying a Haro Mary 2009 (found a great deal on them ;-).
    But I'm not sure which size to pick, the 16"or the 18".
    I'm 5.77 feet, and ride a titanium 29er with a 23.5 inch top tube and 16 inch seattube.
    The top tube says the 18" version and the seatube the 16" version...
    I think the 18" wont have enough stand over height...Or would I get toe overlap with smaller one..?
    Some advice would be great!
    Regards Rolf
  40. #240
    Oct 2010
    Smile Just got a Mary
    Hi guys, posting from the other side of the pond to most of you. Bought a new Mary a couple of weeks back pretty cheap. Not the current one but it looks ok to me in pale blue.
    Been riding 20yrs on hardtail and full suss and a lot of the lads I ride with use ss. Quite a few different makes from Niner, Singular, Dean, On One, Genisis and Kona.
    Anyway there are 2 Marys in the pack. Mine is standard with BB5, Mary bars, Nevegal tyres. I only weigh 145lbs so the brakes do the job fine, The thing that surprises me most is how well those big wheels roll and how well balanced it is on typically Brit techy singletrack. Surprised myself what I can get up on the stock gearing (32/20) but it does spin out a bit too easily on the flats.
    On the negative side it's a bit on the lardy side and the paint is easily damaged, but hey, what can I expect for 385. Can't even get a decent set of suss forks for that price!
    All in all a cracking Winter trail bike for our very wet forests.
  41. #241
    Oct 2010
    Quote Originally Posted by rolfo
    Hi Bikers,
    Regards Rolf
    Rolf,
    Got an 18" and am just under 6' with 30.5" inside leg. IMO the 18" is slightly too big for me but think a 16" would be too small. Sounds like you need a 16"
  42. #242
    Jan 2005
    Soooo wheres the Porn TM
    Formotion Products
    http://www.formot
  43. #243
    Creaking clicking noise.......
    I have this problem. I put teflon tape all around and then grease then squeeze it back in which stops it completely.
    Also sometimes it can be from a little bit of sand or dirt in the cogs/chain. I ride in very muddy, sandy places and have this problem alot. I have to stop alot to wipe down the crank and rear cog.
  44. #244
    Update Mary in Mexico
    Made some changes and put on a Alfine Hub as I have alot of mountain races this year. I loved the SS but need more top end speed and a granny gear for very steep climbs. The brooks saddle complements Mary in Honey but I am not to sure about the anodized gold Mary bars! I also added a carbon fork instead of the white brothers suspension. So far I havent missed the suspension one bit.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-01102010083.jpg
  45. #245
    Apr 2005
    Hi Bikers,
    Regards Rolf
    I'm 5'7" with a 31.5" inseam...I ride the 16" size.
  46. #246
    comment
    Thanks for your tips!
  47. #247
    Rolfo...
    I am 5'8" with a 32" inseam and I ride a 16" Mary. Perfect fit for me...
  48. #248
    Haro's wearhouse Mary 26er/electric/bmx bomber! So much fun haha
  49. #249
    That would be fun.
    2010 HARO, Mary SS
  50. #250
    Apr 2005
    LOL...I just saw that Frankenbike down there this morning! Hey...e-bikes are IN right now!
  51. #251
    Got my Mary today so stoked! '09 Army Green. Had my first ride no complaints except for the Mary Bars aside from some climbing I am not a fan. I plan on replacing the bars, and I have some BB7's and speed dial 7 levers at the house I'm swapping out along with a Salsa chainring and Surly cog this evening photos tomorrow.
    Mary ss shenanigans
  52. #252
    Hi Bikers,
    Regards Rolf
    Sounds like an 18" to me...I go with the TT measurement as long as there's not too much seatpost out and I think you'll be ok on 18.
    Quote Originally Posted by bennym
    Nice changes...but I'm not a fan of the gold bars. Black looks best imo.
    Quote Originally Posted by rob.char
    Sweet, pics please! Took an afternoon break and went for a short ride in the rain...very refreshing!
  53. #253
    Give the Mary bars a little more time, they will grow on you.
  54. #254
    Nov 2008
    Yea, I am using the BB7s and speed dial levers too. Its a great setup. I went w/ Richey rizer bars and they have been really good also.
    GapRider MTB
    aka Chuck Faulkner
    Tazewell TN 37879
    http://www.jeffrothcyclingfoundation.org
  55. #255
    Here's Army Green Mary, Kore Bars (does Kore still exist? haha) XT clips, Surly 20t rear cog, Salsa 32t front ring, BB7, Avid SD7 Levers.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-1222001509.jpg
    Mary ss shenanigans
  56. #256
    O.T
    O.T is offline
    Which is the diameter of the handlebar that will fit the original Ritchey Pro stem? Which one of these would be the best?
  57. #257
    I believe they are 25.4 not 31.8.
    Mary ss shenanigans
  58. #258
    O.T
    O.T is offline
    That's what I thought...
  59. #259
    Nice pics, makes me want to put the rigid back on mine.
    That is correct, original stem and Mary bar clamp area is 25.4.
  60. #260
    Dec 2005
    Haven't posted my Mary for a long time. Here's a pic in snowy conditions.
  61. #261
    Reputation: watkinscapital's Avatar
    looking good!
  62. #262
    Mary Top Tube
    Can anyone tell me what the effective top tube is on a 18 inch Mary please? I've tried the Haro site but they don't appear to have any archived info.
    The geometry is the same with the latest Mary. ETT is 600mm(23.6") for the 18".
  64. #264
    I had to post again since my original photo was not the greatest. Installed: xt clips, kore bars, salsa chainring, surly cog, and bb7s. I need to get some extra cash and get rid of the ugly seatpost.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-img_1247_resize.jpg
    Mary ss shenanigans
  65. #265
    Jan 2005
    Awesome pic bro
    Nothing wrong with the SP here but if you feel the need to replace its all your eyes.
    Formotion Products
    http://www.formot
  66. #266
    ?hipster?
    Mary SS >>>> Mary 2x9 w/bashguard and Niner Reynolds steel fork. The Niner fork is very precise, predictable, quicker handling, Great in tight single track, really happy with it. It weighs the same as the oem fork. Makes a great frame even better.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-p1020079.jpg
    Haro Mary Pictures/Info/Comments Thread-p1020083.jpg
    Haro Mary Pictures/Info/Comments Thread-p1020088.jpg
  67. #267
    Quote Originally Posted by Moementum
    Quicker handling? What's the A to C measurement on it vs the stocker? Shorter than stock I'd guess if its quicker handling. How's it ride compared to stock, cushier, harsher, or same?
  68. #268
    ?hipster?
    Stock fork 473 A-C, 43 mm rake.
    Niner fork 470 A-C, 45 mm rake. This lowers the front end a bit and steepens the head angle a fraction.
    A few more differences. The dropout/leg junction on the Niner is a bit stouter than the stock. The dropouts are thicker and forward facing. I always thought that was a bit thin in that area. Also the leg tube shaping is much different.
    I haven't noticed much difference in cushioning. But there is a definite change in cornering. Someone who doesn't ride agressively in tight corners might not notice it however.
  69. #269
    Only 4 rides on mine...
    and I really like it. And I'm thinking about putting Mary bars on my other bike (if they'd still work with an inch cut off each side.
    '09 Army Green, all stock except for Thomson seatpost and green King headset.
  70. #270
    Wtf ??
    What is it with this bike.. I've got a 2010 Mary SS, this little gal is addicting. I can't believe how much I've fallen for her,, Its been a good solid year of spinning on her, and let me tell you., you can rip up some ground with this gal.. I love the thoughtless way you just have to climb aboard and pedal,, you learn how to utilize your full pedaling stroke, up , down ,sideways, whatever works,, but the payoff is power, and quick acceleration. OMG, Im so sold on the SS train of thought. I only ask myself, Why did I wait so long. I have to thank my riding buddy "Flats" for coaxing my into this love affair. SO worth the work. Thank you HARO for making the Mary SS, but I'm also alittle sad to see her dropped from your line.
    2010 HARO, Mary SS
  71. #271
  72. #272
    i was under the impression that the stock fork was a 38 rake. anyways, i recently put a P2 fork on mine (the stock fork was fabbed crooked, which led to all sorts of fun issues). longer rake, lower crown height- i immediately noticed i could keep the front end down- where i want it- when climbing. not sure if there's any noticeable difference in ride quality otherwise. seems to steer a little quicker, but that might be psychosomatic too. but the old tendency for the front end to lift is definitely lessened.
  73. #273
    ridin' Mary
    You aren't the only one with a crooked Mary fork. I had to use a washer between the fork and the hub to get the disc brake tabs moved out so that a rotor wouldn't rub on the brake caliper.
    Replaced it with a used White Bros Rock Solid, and I love this new fork. It is so much more responsive and I can bomb hills much faster than the stock fork. A huge confidence booster! And no more stupid washers to accomodate a fork defect.
  74. #274
    hmmmm...my stock fork didn't ride weird or look crooked, but I had to put one washer under each brake caliper adapter to keep the ends of the screws from pinging against the side of the brake rotor during hard turns and such....
    Quote Originally Posted by loose chain
    Pic of bike with new fork? Pic of crooked stock fork?
  75. #275
    yeah, i haven't bothered to find out exactly what the problem is- whether it was the legs themselves or just the dropouts. didn't have rotor rub, but the top of the tire was offset by a good 3-4mm all the time, and when i'd get in the front brake pretty hard, it would yank the wheel out of the non-DS dropout a little bit.
    i had the slightest inclination to replace it with suspension, but luckily somebody offered up a takeoff P2 for cheap. has more rake (either 4 or 9 mm, depending on what the reality of the stock fork is), and 7mm less A-C height. altogether that got enough weight over the front end that i'm happy again.
  76. #276
    if i can remember to take a pic, i'll post it. honestly, though, other than saying "P2" on it, there's little perceptible difference. well, i guess it doesn't look quite as beefy.
    and i doubt a picture of the old one would be of much help. but i'll take a picture of it with the tire in so you can see the offset i'm talking about.
  77. #277
    O.T
    O.T is offline
    "Cyclocross"
  78. #278
    Quote Originally Posted by loose chain View Post
    finally got around to looking at this- one fork leg was a full 1/8th inch shorter than the other. the dropouts were perfectly in phase otherwise, but the legs were definitely different lengths. which explains everything above. ended up donating the fork to yellowbike- with full disclosure of the problem.
  79. #279
    Oct 2012
    Couldn't help but bring back this thread. Just picked up this 2007 a few hours ago with 0 miles.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-imag0575.jpg
  80. #280
    Nice, what tires are on there? Mine came with Nevegals.
    Mary ss shenanigans
  81. #281
    Oct 2012
    Quote Originally Posted by rob.char View Post
    Thanks. This came with WTB ExiWolf 2.3
  82. #282
    Reputation: sfgiantsfan's Avatar
    Dec 2010
    Here's mine, changed bar and stem to ibis, deore hydro's. I love this bike, mostly golden gate park and china camp but will try annadel and Boggs soon
    Haro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1349154581.748707.jpgHaro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1349154605.417220.jpgHaro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1349154634.307406.jpg
    I'm sick of all the Irish stereotypes, as soon as I finish this beer I"m punching someone
  83. #283
    Jan 2005
    Soo no riding this weekend eyy
    Formotion Products
    http://www.formot
  84. #284
    oge
    oge is offline
    Oct 2012
    Anybody happen to know the max rear tire width for the 08/09 Mary SS using the stock wheels?
  85. #285
    bhc
    bhc is offline
    It is approximately 2.5" I have a WTB Weirwolf in mine with Velocity p-35 rims which are wider than the stock wheel set.
  86. #286
    Sweet, I was going to ask the same question about rear tire width. I have plans to get a 2.4 ardent and run it in the back as well as the front which is set up currently and have a poor mans fat bike this winter. I am running the Ardent on a flow at 20PSI and it rides really well. A few PSI lower than 20 and I start getting rim strikes. I am at 175 pounds.
    I just read through the entire thread and I didn't see any info or pictures of people putting a carbon Niner fork on this bike. Anyone tried this or have anything to say? Is it blasphemy to put a carbon fork on a steel bike?
    I bought mine used and so far have it set up with a flow/hope front wheel after I tacoed the stock wheel. A WTB rocket v saddle (salsa branded with a chilli logo on the nose), a salsa pro-moto alloy bar, kona stem, Zeus Carbon seat post, Green Salsa skewers (really nice bling to the bike), Black ESI chunkies, BB7's with SD7 levers and 185's front and back, F-Ardent/R-Slant 6 2.2, and SPD 520's.
    Future plans for it are...
    Black Niner Carbon Fork (shoulda jumped on the jenson $200 sale)
    Rear flow/hope wheel w/ Ardent 2.4
    Nicer 18T cog
  87. #287
    Where are the pictures?....
  88. #288
    I haven't taken pictures of it in quite a while and have none to reflect what it currently looks like
  89. #289
    EXORCIZE
    Reputation: Ryder1's Avatar
    Quote Originally Posted by tooclosetosee View Post
    Niner carbon fork should work great. I like mine (on my Kona Unit) more than I liked the '07 Mary fork. Geometry isn't an issue and its lighter and rides better IMO. An all-steel frameset is a classic/romantic ideal, but the Niner fork is tough to beat. I chose Niner's "nude" color so it wouldn't look too out of place on any frame.
  90. #290
    ridin' Mary
    I bought a used White Brothers carbon fork for my '08 Mary. It worked great for about 6 months until I noticed what looked to be a stress crack in the clear coat of this carbon fork about halfway up the leg that has the disc brake mount. I realized that I might be playing with fire. So I replaced it with a Salsa fork. The Salsa fork was a full pound lighter than the stock Mary fork (which was a truly awful beast) and behaves just like the White Brothers carbon fork I took off. I'll stick with steel forks.
  91. #291
    Dec 2012
    I have a 2009 SS model and have heard / read of a conversion to a geared Mary simply by swapping the drop out... Masses of changes, will pop pics on when I see the thread is not dead.....
    The single spread has a flush drop out, I presume this is simply swapped for a drop out which has a mount for the rear mech. Then just run cables through full length outers and attach using zip ties..
    All the dropout manufactures I've been to don't make a drop out anywhere near comparable!
    Can anyone post a link to a supplier of the dropouts please?
  92. #292
    bhc
    bhc is offline
    I got mine from the Haro dealer.
  93. #293
    Dec 2012
    BHC, thanks for responding...
    I'm in the UK, I was speaking with the UK supplier today and they don't supply the part... They suggested a US or Australian specialist provider maybe able to help.
    Do you have an email for your supplier please? Even better if you had a link to the part or component number etc....
  94. #294
    bhc
    bhc is offline
    Look at this old thread
    http://forums.mtbr.com/haro/haro-mar...on-584149.html
    After my reply might help you
  95. #295
    Dec 2012
    Bhc - thanks for that..
    Your links led me to being able to talk my LBS into ordering one in for me to try before I buy... 1/10 Mary here I come.....
  96. #296
    In my quest to build a SS 29er; I was able to find this brand new 2007 Haro Mary XC frame/fork in a friends basement. Built it up with the most reasonable components I could find for the price.
    Stans NoTubes Arch wheels with HD hubs (used)
    Schwalbe Racing Ralph's 2.4
    Raceface Evolve crankset
    Raceface Ride seatpost
    Charge Spoon saddle
    Sunline V1 bars (owned)
    Oury Brown grips
    Easton EA50 stem (owned)
    Hayes Stroker Trail brakes
    Ashima airotors
    32x18 gearing
    Manitou Tower Pro en route
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-harymaryxcss.jpg
  97. #297
    Dec 2012
    I just love my Mary, I ride it to work every day, 20km off road across Salisbury Plain each way....
    Resprayed powder coat, elixir brakes, Roval control wheelset, schwalbe tyres, carbon 600mm bars (big mistake, Easton monkeys on order). Brings this in under 26 pounds..
    Original stem, post, saddle and cranks....
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-image.jpg
  98. #298
    Dec 2012
    Quote Originally Posted by blb228 View Post
    I wish I had a friend with a basement full of goodies....
    Nice looking bike...
  99. #299
    Reputation: mrjustin007's Avatar
    Looking for an geared XL Mary frame & fork - PM me if you got one you don't need anymore.
    WTB: Bontrager Comp Fork & Syncros metal top cap
  100. #300
    Dec 2010
    Here's another one of mine
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-imageuploadedbytapatalk1364256576.305596.jpg
  101. #301
    Reputation: rynoman03's Avatar
    Nov 2012
    Haro Mary Pictures/Info/Comments Thread-img_20130328_135104_898.jpgI'll get better pics later but here is what I've got for now.
    2008 Haro Mary SS
    16" Frame
    RaceFace Dues Ex Headset
    Raceface Air Alloy Low Riser Handlebars
    Specialized 6* 110mm Stem
    OURY Red Grips
    WTB Pure V Saddle
    Kalloy SPC-105 Carbon Seatpost 31.6
    RaceFace Ride OE Crankset (White) w \ GXP Bottom Bracket
    Junk Pedals for now until I upgrade to nicer ones.
    Avid Elixr 5 brakes 185mm front 160 rear
    WTB LaserDisc Trail Wheelset (Stock Rims but off a Redline so Redline hubs)
    GEAX Seguaro Front WTB Weirwolf Rear
    SR Suntour Fork w/ lockout. (Might go rigid later)
    Pics are from my cell so bare with me. I tend to have the shaky hand.
    Haro Mary Pictures/Info/Comments Thread-img_20130323_122248_826.jpgHaro Mary Pictures/Info/Comments Thread-img_20130323_122320.jpg
  102. #302
    Reputation: tatt22d's Avatar
    Anyone give me some tips? Just ordered a Rock Shox front suspension fork. Looking for some tips and advice for installing. Never changed a rigid to susp.
    I looking for a 2010 Haro Mary frame, 18-19in, with the curved top tube, for a new build. If anyone has a lead, please PM me.
    Thanks.
  104. #304
    Mar 2013
    Here's my Mary XC. Love this bike!
    Anyone know how I can tell what year it was made?
    Haro Mary Pictures/Info/Comments Thread-maryxc.jpg
  105. #305
    2008
  106. #306
    My 2009 Mary SS
    Haro Mary Pictures/Info/Comments Thread-dsc_18408.jpg
    Here is my Mary SS. I love the bike! Would not mind a front suspension fork but like the beefy one on it. This was when I got it in 2009 before I changed the Mary bars. Changed gearing to give me a little bit more speed.
  107. #307
    I see alot of Rock SHox on these SS, how they holding up? I have gotten one ride on mine but need to replace the stock headset
  108. #308
    2009 Haro Mary SS
    Niner Carbon Fork
    I9 Rear wheel w/ Flow rim and Slant 6 2.2
    Hope Front wheel w/ Flow rim and Maxxis Ardent 2.4
    Easton EC70 680 Carbon bars
    Zeus Seatpost
    BB7's
    ESI chunkies
    M520 pedals
    Geared 32x19
    24.25 pounds with pedals (mostly due to the heavy wheels and rubber). Going to the Niner fork (540 grams) dropped almost two pounds. The stock fork is around 3 pounds. I was getting a lot of shoe/tire rub with the Ardent and stock fork. The Niner fork with the larger rake is helping with that, but I still get it from time to time.
  109. #309
    Hi all,
    Just bought myself a 2th hand Mary SS, I've never had a SS before so it's a brand new world for me!
    About the EBB, can some of you help me out and tell me what tool I have to use to loosen up the chain tension?
    Thnks!
  110. #310
    You need an allen key to unscrew the two screws under the bottom bracket and then you can adjust the chain tension by rotating the EBB.
  111. #311
    Quote Originally Posted by selin View Post
    Ok thanks! But I don't need something special to put in the 2 holes in the EBB? I can just use any regular key that fits 1 of the 2 holes?
  112. #312
    The two holes at EBB are for helping to rotate it. Just put a rod (allen key , screwdriver, whatever), and rotate the crank, this way will help you to rotate the EBB easily.
  113. #313
    Perfect, thanks for the feedback!
  114. #314
    Hi,
    Anyone tried Schwalbe Hans Dampf 29x2.35 as a rear tire, I'm not sure if there is enough clearance?
  115. #315
    Nov 2012
    Updated pic of my Mary SS with some new Mavic Crossrides.
    Pic was done with Instagram so bare with me.
    Attached Thumbnails Attached Thumbnails Haro Mary Pictures/Info/Comments Thread-img_20131202_145350.jpg
  116. #316
    ridin' Mary
    My 2007 Mary SS. She's covered many miles with a Rohloff speedhub on the back end. Many more miles as a well upgraded singlespeed (replacing almost every component). I finally got another singlespeed frame, and Mary was stripped and sat neglected for the last year.
    I found a bunch of parts including many pieces that came with Mary when she was new in my random parts bin. Found some other stuff used from swap-meets and craigslist. Built her up as my 1x9 local commuter to fetch groceries and beer, and to get me to the gym and library. She came out sweet looking as ever. You can put any manner of odd parts and components on Mary and she comes out beautiful every time. Even as a work mule.
    Haro Mary Pictures/Info/Comments Thread-14045824953_83b256e6d9_c.jpg
  117. #317
    Nov 2012
    Cool, but your saddle angle looks uncomfortable as hell!
    Sent from my SCH-I545 using Tapatalk
  118. #318
    .44
    Reputation: stremf's Avatar
    Dec 2012
    Looking to buy an 18" Haro. Preferably the yellow/orange XC-geared version.
  119. #319
    Dec 2010
    Found a fork oncraigslist thought "why not" 2008 Fox F29
    I was looking for a carbon fork but could not find one less than 300 and didn't want to buy used. Found this one for 150
  120. #320
    Dec 2010
  121. #321
    Mar 2016
    2009 Haro Mary SS
    Niner Carbon Fork
    Zeus Seatpost
    BB7's
    ESI chunkies
    M520 pedals
    Geared 32x19
    Looking at a 09 ss mary and perhaps getting a niner carbon fork as well but the niner forks I'm finding are tapered and I thought the mary was designed for a straight and not tapered fork?
    Did niner once manufacture straight and now only make tapered? Is there a way to get an adapter? This question should have been 1st but, the 09 mary ss was designed for non-tapered right?
  122. #322
    EXORCIZE
    Quote Originally Posted by Divo126 View Post
    '09 Mary was designed for a non-tapered fork. No adapter can make it work with a tapered fork. Niner made a non-tapered carbon fork for years.
  123. #323
    Dec 2010
    They are hard to find, I looked for quite awhile. Mostly on CL, but check ebay and pinkbike too. Good luck, I found a fox fork for 200 bucks and I am pretty stoked on it.
  124. #324
    May 2016
    Anybody know what size BB they use?
  125. #325
    May 2016
    Quote Originally Posted by waltj View Post
    The Mary was bought as a friends bike but is growing on me more and more and has replaced my Karate Monkey as the ride of choice. Absolutely rock steady handling. I get comments about the look of the wheels with the bike every time I ride
    Magura Marta SL brakes
    Rock Shox Reba fork
    Cane Creek S2 headset
    Cane Creek Thudbuster LT
    Bontrager CRZ+ Sport saddle
    Industry Nine Wheels using DT Swiss Rims and orange spokes
    Panaracer Rampage tires
    Chris King stainless cog
    ODI Rogue Lockon Grips
    Dangerboy endcaps
    Odyssey Cielencki copper platform pedals
    Weight 28.22
    What size rotors did you go with?
  126. #326
    Yea, the Haro is non-tapered. When I bought the niner CF fork used they were fairly popular still but had discontinued them or were in the process of discontinuing them.
    I'm getting ready to put a bushnell EBB in it due to set screw issues. On paper, it should work, and I think I read that someone placed one without any problems. I will report back on my findings.
  127. #327
    Bushnell installed and looks like it is going to work perfectly based on riding it up and down on my steep driveway. I also put loctite on the set screws that are now just plugging holes.
    Bushnell Design | Home of Bushnell Eccentric Bottom Brackets
    I got it from excelcycle.com (amazon) for $116 for the featherweight.
  128. #328
    May 2016
    Haro Mary Pictures/Info/Comments Thread-img_9633.jpg
    Just finished building her up!
  129. #329
    Nov 2012
    Quote Originally Posted by sfgiantsfan View Post
    I've thought about putting a Fox on my twin to yours honestly. I've had 2-3 hardtails not but this one is my favorite.
  130. #330
    Nov 2012
    Couple pics of me getting high on Mary Jane
    Haro Mary Pictures/Info/Comments Thread-1029161158_7260%7E2.jpg
    Haro Mary Pictures/Info/Comments Thread-1029161158_7260.jpg
  131. #331
    Dec 2010
    Quote Originally Posted by rynoman03 View Post
    You should, I love it. The rigid was beating me up
  132. #332
    Got any closer drive side photos?
  133. #333
    Reputation: bigdrunk's Avatar
    Picked this frame up for cheap. Started life off as mostly a spare parts build (still kind of is).
    A new STX and XT 11sp drivetrain has recently found its way on as well as a new set of STC brakes. The frame is a SS that I converted over to geared.
    So tempted to build carbn wheels for it....
    Haro Mary Pictures/Info/Comments Thread-haro.jpg
Members who have read this thread: 11
