Haro Mary bottom bracket width- Mtbr.com
Results 1 to 6 of 6
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    I have a new Haro Mary frame and plan to run the White Industries Eno crank. What width bottom bracket would I need
    Reputation: downhilljill's Avatar
    Apr 2005
    White Industries can advise you on this...your BB width is determined by what cranks you run and not the frame you are putting them on.
    Quote Originally Posted by downhilljill
    and i was told to contact you *scratches head*
    thanks jill!
    Apr 2005
    That's what White told you? Now I'm scratching my head.
    It's a 68mm shell (maybe that's what they thought you meant?), but your spindle length is determined by the crank manufacturer because of the profile of the cranks themselves. If you look at a bunch of different drive-side cranks from the side/back (as if you were looking at them mounted on a frame from behind), you'll notice that some put the chainrings in a different position. They will determine what length spindle you need to get a proper chainline.
    All's good Jill
    Quote Originally Posted by White Industries
    A 113mm BB will give you a 47.5mm chainline. You will want to add to the length of the BB if the hub chainline is greater than 47.5mm
    Apr 2005
    Sweet! Enjoy your Mary!
