front derailleur for a VL120- Mtbr.com
Results 1 to 9 of 9
    I'm a dog person
    Reputation: emptybeer's Avatar
    Apr 2005
    Jill,
    Is there enough room on the VL120 frames to use a bottom swing front derailleur? Also, I lost my calipers, what clamp size do I need?
    Thanks,
    EB
    "It is the glory of God to conceal a matter; to search out a matter is the glory of kings."
    Busted!!!
    Reputation: mxracer33x's Avatar
    A friend wants me to build up his new Sonix lt frame. I had the same question. Can I use a Bottom Swing Derailleur? and can I use an Isis bottom bracker, or does the VL pivot require an external type?
    Edit: what is the seatpost size as well.
    I'm a dog person
    Apr 2005
    I talked to Haro directly. It is a 31.8, top swing, top pull. It can't be a bottom swing as the seat tube isn't long enough.
    I'm using an ISIS bottom bracket with no problems.
    I'll have to check on the seat post for you.
    Reputation: Biker75's Avatar
    Quote Originally Posted by mxracer33x
    30.9 on the post size.
    Beer has food value. Food has no beer value.
    weird on all the pics of the haro sonix , the front derailleur is always a low clamp bottom pull ? or so it seems sinc ei just checked.
    I received roday a high clamp for the bike i'm building and it wouldn't fit .
    Busted!!!
    I put 2 front derailleurs on 2 Sonix LTs this weekend, and the front derailleur must be a Top Swing type derailleur. We used an XTR and a Deore.
    If you go to your local bike store, ask for a Top Swing, Top pull capable derailleur that can clamp on a 31.8mm tube. All the newer shimano stuff should be dual-pull (top or bottom), and have the uni-clamp, but ask to be sure. I personally prefer setting up XT or better shimano stuff. the Deore was a bit flexy, and the low grade SRAM one was impossible to get setup properly. I have not tried an X7 or X9 Sram front derailleur. I love the rears, but choose to use shimano fronts.
    I'm a dog person
    Apr 2005
    Quote Originally Posted by steppin
    Hmm...the frame takes a top pull...no other way around it. If you found a picture of one w/ a bottom pull, I'd like to see it.
    As far as top/bottom swing. Top swing = low clamp, bottom swing = high clamp. As per the thread prior to this, the frame takes a top swing (low clamp), top pull.
    ok i think i got confused with the clamp/swing . i think i'll get a x9 front since i have all x9 setup , i planned to try a 100% sram group. Luckily they introduced a x9 low clamp for the first time on their 2007 range.
    Thanks for the explanation.
    I'm a dog person
    Apr 2005
    What?! You mean to tell me that the top/bottom/dual pull, top/bottom swing issue confused you?! That's crazy talk!
    Who started this stupid thread, anyway?
