Flightline Comp Bottom Bracket Size?- Mtbr.com
Results 1 to 5 of 5
    I don't know if anyone can answer this but here goes, Does anyone know what size Crank Bottom bracket is on the the new 2008 Flightline Comp? I'm looking to upgrade it and the Crank assembly.
    Haro Product Manager
    Reputation: PatSS's Avatar
    Quote Originally Posted by chia355
    The Flightline has a 68mm BB shell. Which crankset were you thinking of going with?
    Smile
    A Race Face Crank assembly,also besides being 68mm what is its length? 113mm,116mm or ?mm. I'm trying to get away from a square taper BB
    It will depend on the crankset, the bike comes stock with a 113mm spindle and a 51mm chain line. If you have a set of ISIS Race Face cranks you will probably end up running the 113mm length.
    Thanks, that helps me out alot
