Page 19 of 19 FirstFirst ... 91516171819
Results 1,801 to 1,855 of 1855
  1. #1801
    Nov 2006
    Quote Originally Posted by Blatant View Post
    I donít want to sidetrack the party train. Probably all in this thread somewhere.
    I ran plush and crush, mostly plush. Air and coil, 28 to 35% sag.
    Excellent sizing, stack, awesome pedaling. I just couldnít tolerate how harsh the suspension was, particularly as speeds increased in successive square edge hits. Even on coil in plush at 35% sag.
    No harm, no foul, just wasnít the bike for me.
    This is interesting. Iím on a Shred Dogg and now that Iíve got the cockpit pretty dialed I love everything about the bike...except the rear suspension feel. Harsh and congested are pretty good descriptors.
    Iím still blaming it on the rear Super Deluxe air until I try something different but itís interesting you had the same feeling with all those different setups.
    Sent from my iPhone using Tapatalk Pro
  2. #1802
    Jun 2018
    It's funny how different people feel different things, I came from a rocky mountain altitude to a smash and the smash is definitely more Poppy and pedal efficient but I've never noticed it being harsh, but I was used to getting a fair amount of bottom outs with the rocky so just different strokes I guess
    Sent from my Pixel 2 using Tapatalk
  3. #1803
    No Clue Crew
    Apr 2005
    I had a 2018 Instinct. Certainly didnít pedal all that well and was overall a meh bike for me. Even with the stock DPS Evol shock, though, it was more plush.
    Just like a raindrop, I was born to fall.
  4. #1804
    For me and the riding around southern Oregon, plush is not particularly necessary. We have a lot of big climbs/big descents on fast, fairly smooth trails where really good geometry and efficient and supportive suspension is more beneficial IMO. Not much in the way of high-speed gnar. I'm mostly interested in a bike that can climb really well, feel stable and confident at speed, but still be playful-ish. I tend to jib my way down the trail rather than plow. I'm thinking the Smash built up more on the trail end of the spectrum with air suspension will be a great recipe for here.
  5. #1805
    That sounds pretty much exactly like a Smash (or a TP) with air.
  6. #1806
    The Riddler
    Reputation: Kaparzo's Avatar
    I'm also curious about others who would say the bike is harsh, being on a new Smash where I've had a similar sensation on slower speed, rocky terrain. Bike just seems to be bounce off of everything. Riding coil front and rear in plush mode and just can't seem to get it dialed. Funny thing is that it feels better at speed, but then starts to move pretty quickly through travel and I tend to bottom on most drops so don't think it's a spring stiffness issue.
    Still tinkering with shock/fork settings and will probably swap springs to see if that helps, but definitely different from my previous Santa Cruz. Not necessarily a bad thing! Just been tricky to dial in my suspension settings and am wondering if I should have went with air.
  7. #1807
    Reputation: vikb's Avatar
    Quote Originally Posted by Kaparzo View Post
    Something sounds wrong. I won't even try and diagnose your bike via the internet, but having the bike be too stiff in the initial stroke and bottoming out easily is not normal.
    I'm running dual coils on my Smash in rocky/rooty coastal BC terrain and the suspension is definitely plush. I've played around with two springs and like them both. I'm going to try a MRP progressive spring this year and sort of split the difference between the 450 and 500lbs springs I've tried.
    Setting up a coil shock is more hassle [initially] than an air shock since it's so easy to add/remove air, but I like the dual coil feel a lot and wouldn't want to give it up for air suspension. Also once you have your suspension dialled it's nice to just grab the bike and never think about your shock pump. It rides the same every ride.
    I wouldn't hesitate to contact GG with your suspension settings/sag and how the bike is feeling to get their input/advice.
    Safe riding,
    Vik
    www.vikapproved.com
  8. #1808
    Reputation: Curveball's Avatar
    Aug 2015
    Quote Originally Posted by Ganderson View Post
    FWIW, I went from a RS Deluxe to a DVO Topaz on my Shred Dogg and it transformed the bike for the better. The rebound damping on the RS seemed pretty whack. The Topaz is very smooth and controlled.
    Riding Washington State singletrack since 1986
  9. #1809
    former lurker
    Jun 2018
    Quote Originally Posted by y0bailey View Post
    Has anyone had pretty horrible backpedaling issues? I'm on a new smash, Ride 1, TS+ 9-46 ring with default GX shifter/derailleur. I thew on a park tools DAG and the hanger is true...but I'll drop in the largest 2-3 gears reliably when backpedaling. I'm not a noob just losing my mind a bit. Haven't been a trail so no break-in at all.
    Any thoughts? b-limit screw has been adjusted, no real good ideas left in my bag-o-tricks.
    I've had a couple of the e13 TRS+ cassettes. I bent the 46t cog on the first one and e13 promptly sent me a replacement for the 3 aluminum cogs... good customer service from the hive.
    However, I've found that even following their directions precisely (torque wrench for the pinch bolt, even!), the cassette shifts slightly on the freehub body after riding for a while. Subsequently, when I spin the cassette, I can see the whole thing wobbling. I think this might be the culprit for clunky shifting and backpedaling, at least on my bike. Might even by why I bent a cog in the first place... that and shifting under too much load like a dummy.
    I've had to remove the cassette and reinstall once more, and it's shifted again but I haven't re-installed. It's irritating, but still ride-able.
  10. #1810
    Out spokin'
    Dec 1999
    Quote Originally Posted by vikb View Post
    Vik nailed this, IMO. I went from a dual air setup on my Trail Pistol (Pike fork/Super Deluxe shock) to dual coil on my Smash (Pike fork w/Push ACS3 coils and 11.6 shock). While I was never unsatisfied with the air sprung TP (I really loved that bike), the coils definitely fit my suspension preferences better, especially at the rear end of the bike.
    I run my Smash in Plush mode and while I would not exactly describe my bike as "plush," I'd definitely say it provides a responsive yet forgiving trail railing platform. Heck, maybe this IS the definition of plush, I dunno. I just know I really like the way this bike responds to all kinds of trail input. I don't want a couch. I want a bike that takes a pounding in a controlled manner and is ready for the next hit pronto, making me feel like increasing speed is all up to me -- the bike is definitely not holding me back. For me, coils go "boing" better than air.
    =sParty
    disciplesofdirt.org
  11. #1811
    Yup, plush is not that plush, esp compared to some other bikes; DW suspension for example.
    That said, the bike rides well and climbs great, so itís all about compromise.
    Maybe try a coil and see if it feels better.
    XMed GG Smash 29/27+ (Frameset For Sale)
    Lrg Fezzari Signal Peak 29+
    Lrg Pivot Shuttle 27+ (wife's)
  12. #1812
    The Riddler
    Thanks, they've been pretty helpful so far and I'll probably get back in touch soon. I only have it to compare to a SC 5010 with a Topaz and don't honestly have a ton of time on it as yet. I also sort of expected the coil setup to be easier and now I know it's not, so that's good.
    Going to try and back out the HSC/LSC and make sure I have the rebound where it needs to be first. Just a bit nervous because of the discrepancy between initial travel feel and high speed/jumping feel. Would prefer for it to be consistent so that I could at least know it's a spring issue and not a leverage style or settings issue.
    Just to be clear, with a dual coil setup I should expect/aim for springs/settings that allow the bike to roll over objects without a lot of skipping/bouncing/deflection? So far the coil (front or rear) haven't felt that way at all so I'm just trying to get my expectations in order.
  13. #1813
    Plush is one of those words that means different stuff to different people. A bike is plush to me when I can ride over my typical rocky/rooty terrain at various speeds and the bike grips the ground well and after several hours there are no comfort issues. I'm in the camp where suspension has a purpose and it's not to be as soft as possible.
    With the Smash I've done big days in rough steep terrain and never given a second thought to how it was providing traction or absorbing impacts. Hence why I called it plush.
    By contrast I grabbed my 275er air sprung for a big alpine ride this summer since my buddy rides the same brand/model and I figured I'd be a team player. Since I wasn't riding that bike regularly I adjusted the suspension air pressure by memory and was a bit off. The ride features a 1hr chunky descent and while the pressure wasn't off enough to compromise grip it was way more harsh than normal. I stopped a couple time just to give my body a break from the abuse and I was constantly thinking about the suspension. That bike was definitely not plush on that ride...although tuned properly that bike is plush.
    When I reviewed the Smash my comment on the suspension was that it just worked and I didn't have to think about it while riding. It just did what it was supposed to, which is part of what makes me so stoked about this bike.
    Safe riding,
    Vik
    www.vikapproved.com
  14. #1814
    Reputation: Gvus2001's Avatar
    Jul 2016
    THIS. This is important, everyone had their preferences with suspension set up. For me I'm after suspension that I can push into very hard without hitting bottom all the time, yet tracks the ground well, and the Smash does that so we'll. I do like the air ribbon though better than the coil one now that I've tried both, it tracks nearly as good but doesn't dive through the midstroke as much, definitely personal preference but I'm stoked on how good I've got my Smash to feel for the way I ride.
    In other news I got around to trying out offset bushings on the Smash. Only a couple rides in but so far so good. Haven't noticed the change in head angle or seat angle too much, but the drop in bottom bracket height is very noticeable in corners. I did have to drop my stem about 10mm to get the stack and reach to feel the way it did before, but after doing that it felt great. Noticeably faster in corners and not much of a compromise on climbs.
  15. #1815
    Jun 2018
    In other news I got around to trying out offset bushings on the Smash. Only a couple rides in but so far so good. Haven't noticed the change in head angle or seat angle too much, but the drop in bottom bracket height is very noticeable in corners. I did have to drop my stem about 10mm to get the stack and reach to feel the way it did before, but after doing that it felt great. Noticeably faster in corners and not much of a compromise on climbs.[/QUOTE]
    Which ones did you end up going with?
  16. #1816
    Jul 2016
    I just got them from offset bushings.com or whatever it is. Cost me about $30 for a 25x8 and 40x8, slacked out by 1 degree and lowered BB 10mm. Very happy with it so far.
  17. #1817
    Jun 2018
    Quote Originally Posted by Gvus2001 View Post
    Thanks! I might have to check them out seems like an easy switch for varying terrain
  18. #1818
    Iím wondering how much this plush vs harsh debate is up to weight. I am 260, probably 265-270 ready to ride w gear, and I find the Smash w SD air in Crush to feel supportively plush. I got a SD coil to try once I have time to source the shim (got it in Megatrail length for future flexibility as needed), but I only imagine it will feel moar plusher....
    Iíve had issues w other bikes in the past with blowing through travel and bottoming out too easily. I ride pretty aggressively (also not very smoothly, aka, hackish), so this plays a role, Iím sure.
    Iím curious...how many of those of you thinking the Smash is on the harsh side are under 200 lbs?
  19. #1819
    Working on collecting parts for another bike. These were a great deal and I get to run a Christmas bike for the Holidays.
    Also - weight difference between a Deluxe air and a Super Deluxe coil with a 500# spring
    My vague Air versus Coil shock comparison
    Air - lighter, sits deeper in the travel to get better small bump, feels (but I don't know if it measurably is) better to stand and pedal unlocked.
    Coil - better small bump, better support, ride higher in the travel, more active suspension / faster rebound felt great.
    Sits deeper / higher in travel is completely dependent on spring rate. It just felt like with air to get small bump I had to have a really low air pressure. I finally pulled my shock apart and saw that it came with 3 spacers installed. I removed them all to make it more linear and will play around with that + a little faster rebound and see what I think. My local trails really don't "need" a coil shock and it is nice to lose 1.2 pounds off the bike.
  20. #1820
    Jan 2018
    Quote Originally Posted by sirsam84 View Post
    I'm 170 lbs., and I don't think that the Smash is harsh. But I do prefer Plush.
    2018 Guerrilla Gravity Smash 140/150 29"
    2013 Specialized Carve SL (rigid SS) 29"
    2015 Diamondback Haanjo Comp
  21. #1821
    Quote Originally Posted by steeple View Post
    I ride plush mode. I'm ~200lbs ready to ride.
    Safe riding,
    Vik
    www.vikapproved.com
  22. #1822
    Reputation: rossp's Avatar
    Mar 2005
    True, forgot about that, I know a good friend of mine ran offset bushings on his hightower for a while and rubbed through the seatube. It's only $20-30 so I might just get them and if it doesn't work out then I'm not out too much, and it will be good info to have.
    Gvus2001 - how are the offset bushings working out from a tyre clearance perspective? Any issues / how does it leave you in terms of space?
  23. #1823
    Mar 2005
    So my Smash is taking shape... currently in MegaSmash mode. DVO diamond 150mm fork, shimmed MT coil shock. Only done a test ride round the yard so far but feels good - less wallowy than MT 180mm mode which I donít ride fast or gnarly enough for.
    Sadly Iím out of town and will miss nice frozen trails this weekend :-( but Iím going to ride it like this a bit and then think about whether I want to go for the smash seatstays #fullsmash!
  24. #1824
    Two days of mud
  25. #1825
    Mar 2011
    Hi.
    Anyone know about conversation Trail Pistol to Smash?
    Is it possible? Which frame parts should I change?
  26. #1826
    Quote Originally Posted by q232 View Post
    Hi.
    Not possible with the 2018 metal bikes. It is possible with the 2019 carbon bikes. You'd buy the Smash rear end kit which GG will sell as a single part number for easy ordering and a new shock.
    Safe riding,
    Vik
    www.vikapproved.com
  27. #1827
    Jul 2016
    Quote Originally Posted by rossp View Post
    Sorry I missed this post, but so far there have been no issues at all. Haven't had any saddle buzz or rubbing on the seatube at bottom out.
  28. #1828
    Mar 2005
    Cool. May try them too - what size tyre are you running ?
  29. #1829
    Jul 2016
    Running a 2.5 Assegai's (so really they measure about a 2.4). Actually just cut the center knobs down to run as a semi slick but they had plenty of clearance before, just a bit slow rolling as a rear.
  30. #1830
    Mar 2005
    Iím on a 2.5 Aggressor so should be good too. Order placed. Thanks.
  31. #1831
    Mar 2005
    With all the carbon love, some OG MegaSmash fun today on the east coast. And ice dammit.
  32. #1832
    If anyone has a large Smash in raw aluminum and is looking to offload, let me know. Thanks!
  33. #1833
    XL Smash
    Just received this today! Bike shop will build it up for me tomorrow morning and I'm picking it up in the afternoon!
  34. #1834
    Jan 2011
    Quote Originally Posted by horriefic View Post
    Not getting any old! Enjoy the ride.
    French line enthusiast and expat in Denver, ig; lazoup
    Megatrail FS
    I Like bikes, I really do
  35. #1835
    Nice. I like the colours. Enjoy the rad new bike.
    Safe riding,
    Vik
    www.vikapproved.com
  36. #1836
    Reputation: Brig's Avatar
    For all of the plush vs. harsh posts, I can weigh in a bit.
    I had the harshness when I bought my Smash with the SD Air. It got to the point where my back couldnít take it. I had some sciatica issues and it was wearing me out. I ordered the super deluxe coil and over the past 6 months my back is back to normal and the bike feel amazing. I even started riding it in crush mode. Crush with coil feels just about perfect. I have no issues with my Ribbon air in the front, or the Lyrik I rode it with for a bit.
    I also added an offset bushing which I recommend as well.
    GG Smash
  37. #1837
    Quote Originally Posted by Brig View Post
    This is disconcerting. As you can see from my pic, my bike has the Deluxe Air. Any ideas why the Smash is harsh with an air shock?
  38. #1838
    I suspect it's the damper tune in the RS SD air. Reviewers noted the 2019 GG bikes felt more supple and the kinematics have not changed, but the bikes had Fox shocks on them.
    Safe riding,
    Vik
    www.vikapproved.com
  39. #1839
    This is definitely a plausible explanation. In hindsight I might have been happy with a custom tune. The extra pound on the coil sucks, but it feels sooooo good. You Might try sending your SD air off. I took my wifeís Lyrik from her megatrail to DirtLabs and had them do a light rider tune. The difference for her his night and day.
    GG Smash
  40. #1840
    I've got an SD Coil. It's good....no real complaints, but I did get a custom tune at Vorsprung to see what that would do since the shock needed a service anyways. I haven't had a chance to test it out yet.
    Safe riding,
    Vik
    www.vikapproved.com
  41. #1841
    May 2013
    I think it is personal preference/perception. I have a first year smash and run the stock RT air shock and it feels like a plush couch flying down gnarly mountain terrain to me.
    Just run what you have and decide later if you think you need to upgrade.
    50 mile ride past weekend with over 6k descending and super plush-o-rama!
    Sent from my LM-G710VM using Tapatalk
  42. #1842
    Seconding. It's all preference. I got mine with a coil and switched to an RS deluxe (not the super - cause light-weight). I prefer the coil but I wouldn't describe it as harsh.
    But I also prefer it in Crush almost exclusively (haven't tried plush with air though).
    I do have to run my Deluxe rebound as quick as possible.
  43. #1843
    Jan 2011
    Yes, all preference I guess. I've ridden my Smash with a deluxe RT3, in crush and plush, and I never found it harsh, even riding it in Moab. I hope to soon be able to give impressions on the new one Same shock, but since it needs a service, I may just have it custom tuned at Dirtlabs (I'm a firm believer of custom tuning suspensions).
    Megatrail FS
  44. #1844
    Thanks for the feedback guys! Will update here how my ride goes.
  45. #1845
    Interested to hear your thoughts on it!
    I have one as well with no tune, but am thinking about a DHX2 maybe...
  46. #1846
    Reputation: Little_twin's Avatar
    Feb 2016
    I can't imagine what some of you would say about my trail pistol. Compared to a similarly set up smash it feels "firmer" sure but I don't think it's harsh when ridden properly. My wife rides a smash with a super deluxe air and to me it feels very soft and wallowy but she likes it.
  47. #1847
    Mar 2005
    As a non-expert in suspension set up - I scratch my head when folks talk so conclusively about a bike being plush vs firm (not this thread specifically....more some of the internet rants Iíve seen). There is so much variability in shock set up that it seems to me you can set up bikes to feel however you want - and Iíd be curious to hear thoughts on that - am I over-simplifying things?
    On the Smash side - totally agree on the personal view. Iím switching between an Evil Following MB and a MegaSmash and yeah thereís a difference between them, but in isolation, both feel good and plush when needed, with settings making a big difference. Anyway, enough armchair riding, back to wishing it was the weekend and dry..... :-)
  48. #1848
    XL Smash
    Received my bike today! Next is ride it on the trails!
  49. #1849
    The Riddler
    While you can definitely change/goof-up how a bike does/is supposed to feel with suspension settings, all bikes have different suspension patterns and kinematics. So some bikes move easier than others in the initial stroke/sag. Some bikes hang a bit in the middle. Some bikes have more platform, etc. Plush and harsh are probably too subjective but they're easy words to use. I think thinking of terms of deflection and initial stroke friction is pretty helpful when trying to describe how a bike feels off the top.
  50. #1850
    I don't think you can just adjust a shock so that any two FS bikes feel the same, but I do think it's correct to point out there are a ton of variables at play.
    - specific shock
    - shock settings
    - spring rate
    - shiock/bike maintence
    - rider weight
    - rider style
    - terrain
    - speed
    So it's not shocking [pun intended] that different people prefer one bike over another and that it gets confusing when trying to compare feedback from a bunch of riders.
    I've talked to other folks riding the same bike as me who had pretty much opposite opinions to mine in terms of how the bike performed. I have to take their comments at face value and just acknowledge we aren't all going to agree without being able to nail down exactly why that is the case in a specific instance.
    Safe riding,
    Vik
    www.vikapproved.com
  51. #1851
    Mar 2005
    Exactly. It's less about making bikes feel the same (even trying to get two identical bikes to feel the same may not be easy...) but recognizing the vast differences even basic shock & fork tuning/settings can make.
  52. #1852
    Rode my Smash yesterday. It was superb. I cleared many technical uphill sections that I could never clear before. The bike is an excellent climber indeed.
    Set my fork sag 30% and shock sag 30%. Riding in Plush mode. Did not feel harsh. Yes it felt firm, but the shock and fork were doing it's job well. I'm not a fast rider, but I could see that I was going faster than on my previous bike, while still feeling more at ease and in control.
    The XL was the right size for me, and I'm 5' 11.5' (just under 6') but with relatively long torso (torso length of 20.5").
    I feel like I'm a much better rider with this bike!
  53. #1853
    Mar 2011
    I am thinking about Smash\Megatrail as base frame for 2in1 bike. Could you please help me with some information. How much will cost seatstay?
    Is Smash better for temporal conversation to Megatrail?Or Megatrail better as a base frame?
  54. #1854
    Mar 2005
    Iím speaking about the alloy version, not the new carbon, and from memory the seatstays are $495. You will also need a different shock or one that you can space down the travel on, plus potentially a different fork (29 vs 27.5) and wheelset.
    I donít really plan on changing mine back and forth - for the trails I ride, the Smash is a better choice (less travel + bigger wheels). I would choose based on that.
  55. #1855
    Out spokin'
    Dec 1999
    Nice looking bike! Love the None More Black with gold graphics.
    Iím on an XL Smash, too. Iím 6í2Ē tall and took just a little grief on this forum for getting an XL frame instead of an L. Unlike you, Iím all arms & legs (36Ē inseam, +3Ē ape index). Anyway in my opinion my XL Smash is a perfect fit. My bike is outfitted with a 40mm stem and 185mm party post.
    =sParty
    disciplesofdirt.org
  1. Fantasy Island Tucson Smash and Grab
    By Chris2fur in forum Arizona
    Last Post: 11-13-2015, 08:35 AM
  2. Do you bash your bash guard? Smash chainrings?
    By One Pivot in forum General Discussion
    Last Post: 09-09-2015, 02:03 PM
  3. Cyclist arrested after bike lock window smash
    By mtbxplorer in forum Commuting
    Last Post: 01-07-2014, 10:18 AM
  4. Another Round Of Smash and Grab
    By Ted in forum California - Norcal
    Last Post: 11-01-2011, 11:49 PM
Members who have read this thread: 594
