Creaky Smash- Mtbr.com
Results 1 to 35 of 35
Thread: Creaky Smash
    a dad
    Creaky Smash
    Hey All.. any advice?
    Bike is now almost one year old.. its been ridden about 150 days..
    I have pulled BB and cleaned and regreased, took fork off and cleaned and regreased headset.. greased seat post..
    Suggestions.. most noisy while climbing..
    GG is backed up on service so I thought I would try to handle myself...
    BBZ
    Beer is proof that God loves us and wants us to be happy - Benjamin Franklin
    cmg
    cmg is offline
    passed out in your garden
    Reputation: cmg's Avatar
    Mar 2012
    I chased a creak for 6 months, seat rails....
    Im presuming you're seated when climbing?
    EDIT: or remove handlebar from stem, regrease lightly and reassemble to torque specs
    always mad and usually drunk......
    a dad
    Quote Originally Posted by cmg View Post
    I will try those suggestions.. however, I do climb mostly seated, but when I stand and pedal, its creaks even worse so thinking it is not the seat rails...
    BBZ
    cmg
    cmg is offline
    Mar 2012
    Quote Originally Posted by billybobzia View Post
    Ok, l would concentrate on stem and handlebar then....
    I hate those creaks
    a dad
    I hate those creaks
    Just did stem/handlebars.. and seat rails.. no luck..
    Anyone know if BB could be shot? really seems like BB to me..
    BBZ
    1) Shock bushings. Pull em out, put a thin film of antiseize on all surfaces, then reassemble.
    2) Check the pivot bolts at the seat to chain stay pivot. Remove, lightly grease threads, then retorque, if the bolt spins then there's your creak.
    and though I'm sure you went through the rule outs:
    Same noise in all gears
    Same noise seated or standing
    Same noise suspension locked or unlocked
    Swapped in different pedals
    Checked all pivots and torque to specs
    Moved Geo headset to different position and/or reinstalled with anti seize
    Removed bars, cleaned bar center and stem, greased bolts, reinstalled
    I just love creaks!
    My last one was on the Pistola, took me forever to find it ... shock bushings.
    PS: The ill fated BB, always blamed, but rarely at fault. Bluntly put, threaded BB's don't creak unless they loose. When they go bad they feel gritty, grindy. So yeah, it's not your BB.
    GG Megatrail (Frameset for sale)
    GG Trail Pistola 27+/29 (speedy)
    RSD Middlechild 27+ (punky)
    Pivot Shuttle 27.5 (wifeys)
    a dad
    Quote Originally Posted by Nurse Ben View Post
    I just love creaks!
    Awesome.. thank you for the help.. will keep working at it..
    BBZ
    Jul 2014
    Check the chainring too, especially if you have Race Face cranks. I've had their lockring work loose, so that the chainring itself was moving around. Given that you said the noise increases when standing up, that makes sense (you're putting more force on the drivetrain then).
    Apr 2015
    I had a spacer under my stem crack and creak. It took me a long time to find it.
    Reputation: bedell99's Avatar
    Always go for the bottom bracket first and replace. My smash was creaking and it was the bottom bracket.
    Erik
    Jun 2020
    Mine was the front shock bushings on my hazard. A little grease coating and re-torque to spec fixed it.
    Apr 2015
    check the pedals, I've been chasing a creak for weeks and finally realized it's a pedal
    Nov 2017
    So I have been chasing a creak for awhile. Thought it was seat rails and all the other usual suspects. Mine appears to be the section of carbon on the top tube in front of seat triangle. Does that make sense? What's weird is it mostly does it while climbing and it doesn't do it all the time. Temperature and humidity seem to affect it. I tried to reproduce for a video and it wouldn't do it. If I hold the bike in one place and push on the frame below the seat post I can hear it and feel it in frame just above the water bottle holder. Anyone else seen/heard this? I was going to contact GG but left town for work for awhile. It creaks while sitting and standing.
    Oct 2010
    Take the pivots apart per an above comment. Spin each bearing a few times to re-distribute the grease in the bearing. Then you can feel if they need replaced. Once done, clean the surfaces, re-grease and re-install.
    cmg
    cmg is offline
    Mar 2012
    If all else fails, fill your bath with oil, put whole bike in, turn every 30mins, every 24hrs take it out and ride 10kms (no downhills, just walk those), after a week the annoying noise should be gone, replace brake pads and rotors.
    Thank me later.
    Reputation: rossp's Avatar
    Mar 2005
    Thank me later.
    or wear earplugs?
    cmg
    cmg is offline
    Mar 2012
    Quote Originally Posted by rossp View Post
    or wear earplugs?
    Whoa. there's no reason to get silly here....
    Mar 2005
    I'm actually reading the thread with interest - have a Smash on order so hoping I won't need to do much creak tracking...(I know it's going to happen at some point with every bike...)
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    If you'd like, if it's a size 3, S and I can pick it up for you, she can test ride it for a couple of months and only send it to you when we're sure it's not creaking.
    Rolling on 29", 650b, 8.3" and 23mm
    Mar 2005
    Quote Originally Posted by 6thElement View Post
    LOL - lurker alert! Sorry, for a short-ass like me, it's a size 2 ;-)
    a dad
    They all creak at some point... no complaining after nearly a year and 2000 miles..but hope it find it soon, driving my mad...
    BBZ
    Time to break out a 70mm stem
    Mar 2005
    should I throw on some bar ends too?
    a dad
    Found it.. thanks for the help everyone..
    Pivot bearings..
    Still something going on in headset it seems, but its not bad like the other creak..
    BBZ
    Mar 2019
    Pivot bearings..
    Great! Which bearings, and what did you do to stop the noise?
    Pivot bearings..
    What about the pivot bearings? Were they toast or was there build up between the pivots?
    I may have found a simple solution to the headset noise.
    https://forums.mtbr.com/guerrilla-gr...l#post14901045
    a dad
    Quote Originally Posted by BluePitch View Post
    Just pulled off the top screw, cleaned everything out real good and regreased.. quiet now..
    BBZ
    My chainstay to seatstay pivot was also a source of creak. I took everything off and the last thing I checked was that pivot on the non drive side. When I turned the bolt it chirped/creaked LOUD. I knew I had finally found the source.
    Currently chasing a new one.
    Jun 2020
    I just had another creak develop on a ride yesterday - turned out to be a loose chainstay/seatstay pivot bolt on the drive side. Glad I stopped during the climb to investigate. Good reminder to check the torque on the pivots regularly, although it is very possible that I failed to torque it back down when I was tracking down my previous noise that ended up being the front shock bushings. All quiet now so life is good.
    Quote Originally Posted by amc_ View Post
    Funny I had that bolt come loose twice. Just cleaned everything and torqued to spec - letís see if it stays put now
    Apr 2014
    Subscribed....
    I thought my BB was trashed. I cleaned and greased, re assembled, creak stayed away for one ride and was back. It seems like it's the plastic bushing on the chain ring side is where the noise is coming from.
    Quote Originally Posted by TXrocks View Post
    Subscribed....
    I had creak from my ISCG 05 bash guard. I could actually replicate the creak by pushing on the bash guard. With the iscg mount that is on the revved frame it might be a good idea to clean that area behind the mount.
    Thread Killa
    Nov 2012
    My Trail Pistol has had a bad creek for the last 200 or so miles, definitely worse when hammering pedals but my gut (& ears) telling me it's coming from my headset. Logic being I'm torquing on my handlebars at the same time.
    I'm taking it apart after this weekends rides to give it a good service so hopefully, I figure it out.
    always licking the glass
    Reputation: stripes's Avatar
    Sep 2016
    Quote Originally Posted by Andeh View Post
    The chainring being loose was the cause of mine on my Revved megatrail. Made me a bit nuts.
    Guerrilla Gravity BAMF, Colorado Front Range
    https://classifieds.mtbr.com/showpro...product=116154
  1. Carbon Smash vs. Aluminum Smash
    By G-AIR in forum Guerrilla Gravity
    Last Post: 04-10-2019, 03:08 PM
  2. KS Lev or WTB seat creaky, creaky
    By swoodbrn in forum Components
    Last Post: 11-29-2016, 08:53 AM
  3. Cyclist arrested after bike lock window smash
    By mtbxplorer in forum Commuting
    Last Post: 01-07-2014, 10:18 AM
  4. Another Round Of Smash and Grab
    By Ted in forum California - Norcal
    Last Post: 11-01-2011, 11:49 PM
  5. Ciclon - Hope HS - Creaky - Creaky
    By zod in forum Ventana
    Last Post: 09-12-2007, 10:02 PM
Members who have read this thread: 69
