GT Talera- Mtbr.com
Results 1 to 11 of 11
Thread: GT Talera
    GT Talera
    Anyone know what year this could be..
    <a href="https://s20.photobucket.com/albums/b237/audiosyncrazy/?action=view&current=Talera.jpg" target="_blank"><img src="https://i20.photobucket.com/albums/b237/audiosyncrazy/Talera.jpg" border="0" alt="Photobucket"></a>
    <a href="https://s20.photobucket.com/albums/b237/audiosyncrazy/?action=view&current=Talera1.jpg" target="_blank"><img src="https://i20.photobucket.com/albums/b237/audiosyncrazy/Talera1.jpg" border="0" alt="Photobucket"></a>
    <a href="https://s20.photobucket.com/albums/b237/audiosyncrazy/?action=view&current=Talera2.jpg" target="_blank"><img src="https://i20.photobucket.com/albums/b237/audiosyncrazy/Talera2.jpg" border="0" alt="Photobucket"></a>
    this sounds about right...
    GT Talera 1996
    BB Shell Width: 73mm English
    BB Spindle Length: 122.5 mm
    Bicycle Type: mountain bike, non-suspension
    Bottom Bracket: Shimano BB-CT91, 122.5 mm spindle
    Brake Levers: Shimano AceraX
    Brakeset: Shimano Altus brakes, Shimano AceraX levers
    Chain: Shimano CN-UG50, 1/2 x 3/32"
    Chain Size: 1/2 x 3/32"
    Chainrings: 22/34/42
    Chainstay Length: 42.5cm
    Colors: blue/green fission, satin
    Component Group: Shimano AceraX/Alivio
    Crankset: Shimano AceraX, 22/34/42 teeth
    Fork Brand & Model: GT
    Fork Crown: unicrown
    Fork Material: chromoly, unicrown crown
    Fork Rake: 5.00cm
    Fork Travel:
    Frame Angles: 70.0 head, 73.5 seat
    Frame Construction: TIG-welded steel
    Frame Tubing Material: chromoly main triangle/hi-tensile steel rear stays
    Front Brake: Shimano Altus
    Front Brake Lever: Shimano AceraX
    Front Derailleur: Shimano AceraX top-swing, bottom-pull/clamp-on 28.6 mm
    Front Derailleur Type: bottom-pull/clamp-on 28.6 mm
    Handlebar: GT steel
    Handlebar Extensions: Not applicable
    Handlebar Stem: GT low-rise
    Head Tube Angle: 70.0
    Headset: 1 1/8" threadless Victor VP-H93 sealed
    Headset Diameter: 1 1/8" threadless
    Hub Front:
    Hub Rear:
    Hubs:
    Largest Rear Cog: 28
    Num Rear Cogs: 7-speed
    Pedals: Victor VP-872
    Rear Brake: Shimano Altus
    Rear Brake Lever: Shimano AceraX
    Rear Cogs: 7-speed, 11 - 28 teeth
    Rear Derailleur: Shimano Alivio
    Rear Shock: Not applicable
    Rear Shock Travel: Not applicable
    Rim Front: Araya GP-710
    Rim Rear: Araya GP-710
    Rims: Araya GP-710, 32-hole
    Saddle: GT Supersoft
    Seat Post Diameter: 26.8 mm
    Seat Tube Angle: 73.5
    Seatpost: Kalloy SP-242, 26.8 mm diameter
    Shift Levers: Shimano AceraX EZ Fire
    Sizes: 14.5", 16", 18", 20", 22"
    Smallest Rear Cog: 11
    Spoke Brand: stainless steel, 2.0mm straight gauge
    Spoke Gauge: 2.0mm
    Spoke Holes: 32-hole
    Spoke Material: stainless steel
    Spoke Nipples: brass nipples
    Spoke Type: straight gauge
    Sugg Retail: 395.00
    Tire Front: Tioga Psycho KS
    Tire Rear: Tioga Psycho T
    Tire Size Front: 26 x 2.00"
    Tire Size Rear: 26 x 2.00"
    Tires: Front: 26 x 2.00" Tioga Psycho KS, Rear: 26 x 2.00" Tioga Psycho T
    Top Tube Length: 56.5cm
    Weight: Unspecified
    Wheelbase: 106.8cm
    Aug 2005
    based on the decals, it's older than 96. 93 or 94 I'd say.
    Reputation: gm1230126's Avatar
    93 For sure....the only year it was made in the blue marble color....catalog shot shows a different color decal but back in the day many decal colors were changed after the catalog sample bikes were shot. I sat through a few GT International distributor meetings back in the day and decal changes were common before production.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    I measured from center of crank to toptube was 20 to the seat post clamp its 22. Not sure which is its actual frame size. Still have a few things to put on to modernize my ghetto GT trail buster (needs shifters). its been a real fun bike so far. thanks for your insights into helping me rediscover the year of its manufacture.
    Yours would be a be a 20" frame as all GT's are measured from the center of the BB to the center of the top tube when you run the tape up the seat tube.
    Rubber Side Usually Down
    Reputation: Mr Crudley's Avatar
    Quote Originally Posted by gm1230126
    My first mtb was an 87' Talera. I loved that bike but the 92 Avalanche felt so much smoother.
    The high altitude nosebleeder stem is a liability unless you aim to take it onto concreted bike paths, My Talera gave me many good memories
    'Geez, I wish I had a witty signature'
    I would also suggest that it's older than '96. That looks like a 1" threaded headset to me. Regards, Mark.
    Quote Originally Posted by Mark S
    Mark did you miss this? http://forums.mtbr.com/showthread.ph...01608#poststop
    A couple of us had already nailed it as a 93.
    Nov 2019
    Handlebar change out
    Hi, newbie to MTB. I just bought a GT Talera '93. Its needs a bit of TLC. I would like to change the handlebars, but I'm not sure of the diameter and don't own a caliper. Is it 28.6 or 31.8?
    Also is this what I would need to update it to fit most modern day bars?
    https://www.amazon.com/dp/B0028N14GQ...v_ov_lig_dp_it
    Sneaker man
    Reputation: mik_git's Avatar
    should be 25.4 for the bars... but do you want to change the bar of the stem?
    But yes you will need a new stem oif you want to run newer/wide bars. You should be able to find up to somewhere in the 600's still in 25.4 on ebay and the like, but wider will be 31.6 and require a new stem.
    For the adaptor you linked, according to the 1993 catalogue, the Talera has a 1-1/8inch fork (and therefor headset and stem), so no that will not work. You just need the exat same thing, but not 1inch ->1-1/8 inch converter, just 1-1/8 straight.
    All the gear and no idea.
