Swapping out for some 650b's on a diverge.- Mtbr.com
    DAC M5 Beast
    I've got a 2019 Diverge S works. Looking to try riding some 650b's. Any special things to consider?
    Brake disk and cassette. Should the hubs and thru bolt work off my mountain bike?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by adcampo View Post
    You should use the thru bolt from the bike you intend to use...your gravel bike.
    Given that we have no clue what your mountain bike is, itís impossible to say yes or no.
    Death from Below.
    DAC M5 Beast
    Thanks. I'll have to mess with it some. I've got my Stans Crests on my Remedy, but I have an old set of Bontrager I'll have to check out.
    Nov 2008
    As Le Duke mentioned keep the axels with the bike, there are a lot of variables with thru axle's. The rear you might be good with out any changes. Maybe a brake adjustment is all that is needed.
    Most gravel bikes use 12mm in the front and mountain bikes use 15mm, you will have to do a little work to fit the front wheel. Older Bontrager wheels use Dt Swiss internals so parts are readily available, if they are the higher end models you can get end caps to swap out and the front wheel should work. If it is a newer model utilizing boost your out of luck.
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
  1. specialized diverge
    By Q-VILLE in forum Cyclocross
    Last Post: 06-19-2019, 04:14 AM
  2. Diverge anyone?
    By PdlPwr in forum Specialized
    Last Post: 03-18-2018, 05:48 AM
  3. Warning: Road content - Roubaix vs Diverge
    By cobi in forum Specialized
    Last Post: 07-15-2016, 10:19 PM
  4. Giant Anyroad or Specialized Diverge?
    By plaucc in forum Cyclocross
    Last Post: 08-18-2015, 12:05 PM
  5. When sensible forestry and mountain biking diverge
    By heyyall in forum Riding Passion
    Last Post: 03-22-2012, 12:03 PM
Members who have read this thread: 31
