Shimano GRX bleeding issue- Mtbr.com
Results 1 to 13 of 13
    Feb 2014
    I can't seem to get a good bleed on my front grx 800 brake. The group came with a quasi quick connect in the middle which is not really a quick connect. I can get an initial good bleed with good stroke but after 24 hours it all goes to crap. I thought maybe that barrel adaptor in the middle of line has a leak but can't find it. Do I just need to get rid of the middle barrel adapter altogether and go full hose from end to end?
    Dirty Dog Race Pack
    Reputation: DDRP Anchorman's Avatar
    Jan 2009
    Did you make sure the oring was on the cap in the lever? How old are your pads?
    Anthony
    ____________________
    www.steeringboxscrapers.net
    Feb 2014
    Quote Originally Posted by DDRP Anchorman View Post
    The whole group is brand new. It's the ones that come pre-bled from the factory but of course I had to shorten hoses. So I shortened the hose on the caliper to barrel connector side and left it alone on the sti to barrel side.
    Reputation: RickBullottaPA's Avatar
    Mar 2015
    Quote Originally Posted by gus6464 View Post
    I would personally go full hose (I've even always done that for derailleur housing). Can you post a pic of the barrel connector? Mine didn't some with such a creature...
    May 2012
    I had similar issues on my RS405 brakes, the problem on my case is that I had not tipped the bike nose down during the bleed process so I still had some air in the system. Once I learned that the bike had to be tipped nose down I got all the air out and the brake were fine. I had/have the quick connector too. The conector was not the problem. Once I upgraded to GRX the process was the same.
    Reputation: RSAmerica's Avatar
    If you follow Shimano’s bleeding procedure 100% you will get a good bleed.
    I've had the same problem, but also don't think I've been doing nose down. Also, I'll cke out Shimano's bleeding procedure.
    Oct 2017
    That's really weird, if it was good initially but not 24 hours later, it's gotta be a leak somewhere.
    Nov 2013
    Quote Originally Posted by klatekin View Post
    The good one moment, soft the next, usually is bubble(s) stuck in master and is more common on rear and usually manifests for me when bike gets inverted or really tilted and the bubble works its way out of master into the line.
    Do the Shimano method which involves tilting the lever/master up and down. And the lever flick is usually the fibal thing that gets it all out.
    Reputation: Coal-Cracker's Avatar
    May 2010
    Word of warning with Shimano GRX brake bleeding: When removing or installing the bleed screw, be VERY careful. Being plastic, the threading on the housing strips VERY easily - resulting in an expensive replacement of the whole shifter. Very poorly engineered.
    (In the event a warranty claim isnt an option, I'm thinking a helicoil *might* work as a fix.)
    Sent from my SM-G973U using Tapatalk
    Feb 2014
    Well for an update turns out my bleeding procedure was not the culprit but instead there was an issue with both brakes.
    Over the past couple of months my bike was loosing pressure on both the front and rear brakes. Got tired of trying to re-bleed so ended up taking it to my shop.
    They had to take everything apart but found out that the rear caliper was leaking at the pistons and the front had a leak in the master cylinder at the shifter.
    To Shimano's credit though the shop called them and they had a brand new left shifter, caliper, and brake pad arrive the next day and got it all installed. Seems I got lucky that they even had the part because the US warehouse is empty with no restock until March 2021 they said. But I am running the GRX 800 left dropper post type shifter which is not that common so they had plenty of those.
    Also my shop said that the first batch of GRX800 stuff seems to have a leaking problem which is why Shimano replaced everything no questions asked.
    So everyone check your GRX 800 stuff for any leaks...
    Mar 2014
    After about 9 months on my GRX800 setup, I just noticed my front brake had gone soft. Bleed was clean and easy, and I had that classic grey, cloudy fluid when I drained the system. Hoping it was just nasty, contaminated fluid and not a leak. I've dealt with leaky shimano mountain brakes, usually a leak at the caliper is obvious as it gradually contaminates pads and rotors.
    Jun 2019
    I had a set of GRX calipers develop leaks both front and rear. Seems like there might have been a production issue on that early run. Replacements have been fine so far.
    -The back up bike needs a back up bike: n+2
  1. New Shimano GRX Inline Brake Levers - an update
    By RickBullottaPA in forum Gravel Bikes
    Last Post: 1 Day Ago, 10:48 PM
  2. Shimano GRX brakes
    By DenyEverything in forum Brake Time
    Last Post: 10-17-2019, 08:08 PM
  3. Replies: 0
    Last Post: 10-09-2019, 01:59 AM
  4. Q Factor - mixing Shimano 105 power meter (146 qfactor) with GRX crank (151 qfactor)
    By capoz77 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2019, 12:57 AM
  5. Replies: 6
    Last Post: 07-09-2019, 06:26 PM
Members who have read this thread: 87
