Results 1 to 11 of 11
    Reputation: sissypants's Avatar
    Sep 2016
    ICAN GRA02 Gravel Bike Frame
    ICAN has hit another home run with their GRA02 gravel racing frame. I built up a frame a month ago and since tested it over nearly 500 miles of diverse terrain. I am very pleased with the quality, ride characteristics, competitive price, and outstanding customer service.
    KEY FEATURES
    • Aggressive geometry designed for fast riding
    • Large tire clearance (up to 27.5x1.95Ē and 700x42C)
    • Competitive price tag
    • Fast delivery, great service, 2-year warranty
    The ICAN GRA02 is designed in-house with geo numbers a bit different than other offerings on the market. Itís molded from stiff Toray 700 carbon fiber and weighs just under 1.5kg in a size 56cm, including hardware. ICAN includes a proprietary expander seatpost clamp and carbon seatpost with the frame, as well as a derailleur hanger. The internal routing is tidy, with a removable sliding port underneath the bottom bracket making it easy to shove cables through in either direction. The ports on the headtube are positioned normally, making for a setup thatís as clean as the average frame out there.
    ICAN has designed the frame around a 2x drivetrain, though the mounting bracket can be removed. The chainstays and fork are shaped to fit big gravel-friendly rubber, up to a recommended width of 700x42C or 27.5x1.95Ē, with margin for experimentation.
    GEOMETRY
    There are several cyclocross frame options on the Chinese market, but based on geometry, aesthetics, and my preference for original design, I quickly zeroed in on the relatively obscure ICAN GRA02 and the mega-popular CFR505. I was looking for aggressive race geometry that could deliver fast and comfortable rides even on grumpy roads, quite like the 2018 Salsa Warbird.
    I did not consider the 3T Exploro knock-off cloned by Tideace due to awful experiences with their products and their service, not to mention other issues people have had with this frame.
    The GRA02 wheelbase is ~20mm longer than the CFR505 due to a 10mm longer chainstay and ~5mm longer reach, despite a ~1o steeper HTA. This fit on the GRA02 should encourage a more aggressive riding position and provide better stability in the sprints than the CFR505. Conversely, the CFR505 should outperform the GRA02 at endurance riding.
    The 2018 Warbird geo appears quite different than both the CFR505 and GRA02 at first glance, but when the frames are superimposed, the key contact points on the Warbird and GRA02 are positioned similarly. For instance, compare the sum of fork length and headtube length, the seat tube angle and toptube effective length, or the sum of chainstay length and reach to the wheelbase. The seat tube angle is a bit less steep on the GRA02, however. I did away with all spacers and used a -17o riser stem to get the handlebars positioned down as low as I wanted them.
    RESEARCH AND DEVELOPMENT
    I reached out to Linda at ICAN bikes to learn more about the R&D process leading up to the GRA02. I didnít get an indoctrinating marketing spiel in the likeness of Spesh, C-dale, or Big Giant, but did collect evidence of a vast spectrum of marketing prowess within the industry. The R&D process I learned about is unflinchingly customer- and quality-focused, but candidly reliant on innovation by industry pioneers.
    Hereís what Linda kindly shared, edited for English:
    What were your goals when designing the GRA02 frame?
    We wanted to meet our customer requests for a gravel-specific frame that can handle a variety of road conditions and meet the requirements of different riders.
    How do you structure your research and development at ICAN? What engineering, design, and testing is needed to take a frame from an idea to a product thatís ready to ship?
    Our R&D team follows 5 steps. First, based on market demand, we do market research to see what products will be the most popular based on sales in the last year. We look at what features, performance, and aesthetics customers like, and of course and most importantly, quality. Then we draw pictures, design, solicit customer opinions, mold, test, run actual test rides, and evaluate. After rigorous testing we solicit customer opinions again to further optimize and perfect the products to meet customer requirements. Finally, we put the product into mass production, optimizing it yet again and again. After designing, small batch production, and testing, it takes about half of a year until sales are ready to be launched.
    Whatís next? Do you have any new gravel or road models coming soon?
    We are updating the professional AC388 cyclocross frame with a 60cm size to meet the heights of very large riders. In terms of new road models, we have begun the R&D process for a new super light disc road frame that will succeed our A2 design.
    RIDE IMPRESSIONS
    Iíve been enjoying my time on the GRA02. I like taking Strava KOMs and this thing is up to the job. The bike has seen huge climbs, lots of gravel, rails to trails, loamy double-track, and flat tarmac.
    Compliance on gravel and rough tarmac is remarkable. The frame absorbs vibrations on rough surfaces while staying laterally stiff on the sprints. Carbon drop bars and 700x38C rubber helps, but the frame still absorbs the bump brunt. However, the compliance isnít quite enough on technical singletrack to make it the steed of choice. This, however, is not what I expected from this bike.
    Climbing is also very efficient, thanks to a relatively light setup. The bike delivered on an 80-mile HC assault on Mt. Mitchell, just doing what it had to do and meeting my expectations. I was never bothered by rear flex whether in or out of the saddle, and I could ride the top of the bars and stay upright comfortably. On the way down from Mt. Mitchell I chose to take a rough gravel forest road, and this was too muchóa plethora of sharp stones, washed out ruts, and steep grades made for a precarious and bone-rattling experience.
    On steep and long descents, the low top tube helps achieve a nice ďtop tube safeĒ aero tuck. This is a challenging position on many bikes due to the top tube height, but it just clicked on this bike.
    I weigh 167lbs at 6í2Ē and ride mostly gravel roads, some two-track and hard-packed singletrack.
    LOGISTICS
    Cost. ICAN is like most online vendors and quotes only on demand. I encourage negotiating if you have any leverage. Their prices are competitive compared to the rest of the market, but the service and quality they provide is more than worth any extra penny you may find yourself spending. Less risk, more satisfaction, better quality, better service, and faster shipping. I recommend using a PayPal balance and the friend method to avoid all fees, just let them know thatís what your doing so they donít upcharge your invoice by 4.5% to account for PayPal fees on their end.
    Shipping. It took just two and a half weeks to get to my door after payment even with the custom paint job! ICAN handled import duties at their discretion and packaged everything excellently.
    Paint. Linda at ICAN was a pleasure to work with, and after a few emails we came up with this Salsa Cutthroat-inspired design. It turned out nicely except that the gradient was quite abrupt. For reference, this 4-color paint job cost $110. Note that you can get a metallic glitter look integrated into quite a few paints, though itís not a typical Pantone code.
    ABOUT ICAN
    Iím a repeat ICAN customer but have also worked with three other companies in the past (Pro-Mance, Tideace, and Angle Sports). ICAN is my favorite. I can email at any time of any day and get a reply usually within minutes and at most within 8 hours. These agents must either work from home or put in impressively long days and weekends. They honor warranty excellentlyóI once broke a chainstay due to riding an overly wide tire and they immediately sent two rear triangles by EMS express, painted to color. That was a surprise! Communication is also excellent, I have never had a ďmisunderstandingĒ with them over three separate purchases.
    BUILD KIT
    The frame requires a press-fit bottom bracket, tapered headset, 12x100mm front hub, 12x142mm rear hub, quick-release style 12x142mm rear axle and 12x100mm front axle, and a 27.5mm round seatpost. The seatpost and proprietary expanding clamp is included with the frame, and I recommend getting at least their rear axle since they were unsure of the thread pitch when I asked. You can use your own seatpost if desired. You may ask for an extra derailleur hanger just to be safe.
    The cockpit features my favorite padded carbon 134g $30 saddle, a great set of carbon aero drop bars, the ICAN-supplied seatpost, Cane Creek 40 tapered integrated headset, thick and super-cheap bar tape, and XTR SPD pedals.
    I highly recommend ICAN wheels as they are great value. However, I kept things very affordable and had Velocity build a set. A $160 pair of 29er double-wall hookless ultralight carbon rims from a ridiculous sale was laced to $70 Hope-esque CNC machined hubs (PM me if you want a pair) with DT Swiss Competition spokes and alloy nipples. Yep, thatís a <1450g wheelset for <$400 including the build fee. I needed to get a Velofuze 12mm-15mm axle shim for the front hub which is inconvenient, but itís nice having wheels that I can run on my MTB as well.
    For the drivetrain, I chose a 42T oval WolfTooth cinch chainring to Race Face Next SL crank arms, a wide-range SRAM XG-1195 10-42T cassette, and SRAM Force 1x11 shifters and a SRAM Rival 1 11s long-cage derailleur. I transferred my crankset from my 29er and still love it just as much. I preferred a Rival 1 derailleur over a Force 1 derailleur because itís just 8g heavier and was said to perform equally well and saves $100. I've been having shifting issues, however, and regret not going with a Force derailleur. I really donít need as much range as the cassette has to offer--I never used the 42T cog even while climbing Mt. Mitchell. SRAM Force flat-mount brakes and Ashima AI2 discs handle stopping duties. Contrary to popular rumor, Ashima AI2 rotors are simply the best, won't bust up your brake pads, weigh less than anything else, cost less than almost anything else, and pack plenty of power.
    For your reference, my build weighs 17.5 lbs.
    POTENTIAL LIMITATIONS
    Although Iím very impressed overall, I noticed room for a few minor improvements. First, there is no 1x-specific option. The mounting bracket for the front derailleur screws into a flat surface molded right into the frame, meaning even if you remove the mounting bracket youíre still left with an awkward space. I suspect we will not be seeing 1x-specific options in the Asian market before model year 2020.
    Second, it would be ideal to spec a seatpost with a more robust saddle mounting mechanism. I should not mount a saddle with oval carbon rails using this mechanism, but I did anyway. There are some scary creaking noises when I slam down on it.
    The rear dropouts are not compatible with Burleyís steel hitch, which means my wife now does the pulling on family rides.
    Finally, there arenít rack mounts, which does limit what this bike can be used for. Iíve settled for a front triangle frame bag.
    Reputation: Ray Lee's Avatar
    Great looking bike.
    Also ended up buying an ICAN frame (AC388) mostly based on the higher stack hight .... Im only 6'3 but more legs than normal so the seat was towering over the bars on the bikes I tried in the stores (and they all had chopped fork steerers)
    Would like to see ICANs take on a heavy duty bike that could take a 29 2.3 from ICAN... I guess something Cutthroat like.
    Sep 2016
    Quote Originally Posted by Ray Lee View Post
    Great looking bike.
    Cool build, I like the way you worked the geo to your advantage! I have thought about building something in the spirit of the cutthroat, but couldn't parse out why I couldn't just use a 29er frame and slap on some drop bars. it would take some fiddling around with the number of spacers in the steerer tube, but ultimately I think it would come really close in terms of fit. What do you think?
    "I have thought about building something in the spirit of the cutthroat, but couldn't parse out why I couldn't just use a 29er frame and slap on some drop bars"
    Maybe its my hight leg problem but the top tubes on 29ers were longer than a typical road/gravel style frame and going down a size would give me really low bar heights (stack again) would need insane steerer length.
    My 29er drop bar creation is what got me wanting a more purpose built 29er/gravel bike thing like the Cutthroat. We have a park near here with miles and miles of single track but most of it is a bit mellow for my 120mm suspension mountain bike figure a light rigid carbon bike would be fun... might just pick up a ICAN 29er mountain bike, brakes and shifters are much cheaper than for drops anyway
    my drop 29er
    Bicycles aren't motorized
    Reputation: life behind bars's Avatar
    May 2014
    They need to start building with longer head tubes and chain stays imo, these aren't road racing bikes and should reflect that.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Quote Originally Posted by life behind bars View Post
    Bike geometry from medium and large frames doesn't seem to scale up or down evenly across the range so the problem is magnified in the bigger sizes. Same trail bike or endurance road bike in a medium and average sized rider will typically have a seat an inch or two higher than the grips or hoods the XL and tall rider often 4+ inches. oh and as an added bonus when you buy a complete bike from the LBS the fork steerer is already cut so you can't eek out a bit more bar hight if needed
    I noticed almost all of the carbon direct from China mountain, cross, and gravel bikes are already pretty racy (short stays and low stack) ICAN was the only one I could find that offered some options.
    perfect example, really not even the same bike at this point (and this is pretty typical and holds true in gravel bikes as well)
    Sorry for getting so far off topic
    Sep 2016
    That is a "representative" example in the extreme But yes I agree there is not enough resizing of front triangles with the various sizes. I think this is because manufacturers prefer not to actually open separate molds for each size, but rather extend tube lengths where possible without altering the junctions. This is only true for some models, of course.
    Sep 2016
    Just wanted to post up and say that after 1000 miles the bike is still exactly the same and going strong. My goal is to keep it, downgrade a few parts in order to transfer some of the pricier stuff to a new build, and just use it as a workhorse during gravel season.
    I just missed the podium at a local gravel race (my first ever race) with a stacked field of 300+ locals last Saturday. I'm no sprinter, and there were 20 of us in the bunch sprint.
    It's seen everything, and handles it all like any other gravel bike would.
    I'm not a fan of the pressfit bottom bracket, but it's been problem free except for one time when I got caught in sleeting hail and some grit worked its way in there.
    The derailleur hanger dropout grew a slight crack after a brutal impact in one case, but no signs of spreading after 600 miles. It's structurally fine.
    I really do like the low position I can get on this bike. This can always be achieved with a more negative-rise stem, but this bike is just built around this position, IMO.
    Nov 2015
    Thanks for the great review sissypants!!!
    Do you happen to know if the frame will fit a 52/34 chainset/chainrings?
    Sep 2016
    Quote Originally Posted by mr4fox View Post
    Yeah I don't see why it wouldn't fit that. My 42T oval 1x chainring fits no problem, and going with a 2x setup you move the outer chainring even further out a couple of millimeters, so you shouldn't have any problems.
    I'm getting ready to part out my bike apart after a good season and free up some funds for the next one, PM me if you want a good deal on anything.
    Nov 2015
    Quote Originally Posted by sissypants View Post
    Thanks again sissypants. Im in Norway so would probably cost almost as much to ship the frame as it would to buy new from ICAN. but good luck with the new build!!
  1. Ican boost frame
    By eyeluvdirt in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-26-2018, 07:08 AM
  2. iCAN P9 Enduro Frame...
    By gontxo_nos in forum 27.5
    Last Post: 11-25-2017, 10:53 AM
  3. Ican bikes carbon 65 and 90mm rims?
    By Gilboy in forum Fat bikes
    Last Post: 08-09-2017, 04:53 AM
  4. Replies: 0
    Last Post: 10-16-2015, 11:59 AM
  5. Ican Carbon hardtail frame from China
    By C-kaae in forum Bike and Frame discussion
    Last Post: 11-06-2014, 09:38 AM
Members who have read this thread: 110
© Copyright 2018 VerticalScope Inc. All rights reserved.
