Giant Revolt Advanced - Page 5- Mtbr.com
Page 5 of 5 FirstFirst 12345
Results 801 to 832 of 832
  1. #801
    Apr 2020
    Good job!
    Quote Originally Posted by mowmonster View Post
    @mhon72 TY!
    A couple of thoughts. Who ever takes the pictures of Giants bikes for their website needs to be fired. For some reason the stock pictures do not do their bikes justice. The picture you posted is gorgeous (and I don't really geek out to roadie stuff in general). Second, the bike looks really good as well in terms of sizing/geometry. I was going to pull the trigger on Giant Defy a few years back and then saw a Defy in my LBS getting serviced and the balance of the rear triangle size compared to the rest of the bike turned me off. It just looked funny and undersized.
    Sizing: I hear what you are saying but, in general fit/bike set up, I like as little steerer tube as possible. The front end of the bike gets flexy when you lean and throw the bike into corners. Thank you for posting.
    No worries.
    I googled that picture from an ad for an XL bike:
    https://www.pinkbike.com/buysell/262...0&lastredirect
    I was surprised myself how the proportions seem different to an XL Defy.
    Unfortunately Giant don't use the oversized OD2 headset & fork with this model. However, I can't say I notice flex when cornering on my ML with a 10mm spacer and that's with a 120mm stem.
    Definitely try to get a ride of both sizes as I was on the cusp of getting an L but went smaller based on the better ride from having a shorter seat tube.
    Giant Revolt Advanced 2 2019 - GRX
  2. #802
    At Work
    Reputation: sxr-racer's Avatar
    @mhon72 TY!
    Giant Revolt Advanced-revolt-bought.jpgGiant Revolt Advanced-revolt-test-ride-pic.jpgGiant Revolt Advanced-revolt-first-gravel.jpg
    Same Color, Not as good as the one he posted!!!!!!!!
    TREK EX9 27.5
    NINER MCR 9 (Moondust)
    GIANT REVOLT ADVANCED 1
  3. #803
    powered by peanut butter.
    Reputation: heartland's Avatar
    Hey all, I'm having trouble with installing a new shift cable on my Advanced 2. The internal sleeve came loose as I was swapping it out (user error for sure), and now I can't get the cable or the sleeve attached again. Any ideas? I'm really at a loss here.
    "Never trust a man in a blue trench coat. Never drive a car when you're dead." -- Tom Waits
  4. #804
    Apr 2020
    Front or Rear? I removed the bottom bracket cover where I could access the sleeves. And feed from the bottom bracket up to the front or to the rear.
  5. #805
    Sorry, this is the rear, at the end of the chainstay. I've got that cover open and even pulled the crank to get a better look at what's going on down there. I pulled a new inner sleeve from the headtube to the BB, but I can't get it connected to the end of the chainstay.
  6. #806
    Apr 2020
    Iím not sure the existing one was connected all the way to the rear - just to the bottom bracket cover Ďthingí. From there it just was open. For the rear brake I removed the rubber bung but I canít recall the derailleur price Iím sorry - it was 2 weeks ago
  7. #807
    At Work
    can you fish it from the rear to try and get it lined back up?
    TREK EX9 27.5
  8. #808
    Apr 2020
    Quote Originally Posted by sxr-racer View Post
    Snap I remember now...... I did exactly this. I took a piece of old cable and feed it from the rear derailleur cable hole. Then, taped the new wire to the old wire and pulled back through. I removed the plastic sheath from the back of the bike.
    Hope that makes sense.
  9. #809
    Thanks, all. Yes, that's exactly the issue. I tried fishing it from the rear, but that cable sheath is too narrow to fit a taped cable through.
    How did you remove it? I tried to pick mine out, but it seems bonded to the frame.
  10. #810
    I'm about ready to drill that bit out...
  11. #811
    At Work
    can you get the sleeve to move any?
    TREK EX9 27.5
  12. #812
    No, it's stuck in place. I'm thinking of drilling out that inner hole so I can tape two cables together and pull them out. I have a jagwire housing cap with a thin cable sheath that I think could fit in there after I widen that hole a little bit.
  13. #813
    Finally got it. I managed to pull that housing stop by hitting it gently with my power drill. Popped that out and was able to fish the cable through. Phew. I'm a newb to internal routing, so I'll chalk this one up to ye olde learning curve.
  14. #814
    Mar 2015
    Heres my MY20 Revolt Advanced Pro Force. Been waiting for this bike for quite some time, super stoked to ride it.
    In comparison, I had a MY18 TCX Advanced SX and a MY18 TCR Advanced 1. I liked how the TCX felt when it comes to corning, and the 40c tires. However the TCR I felt was more comfortable, it was easier for me to "settle-in" the bike. And I liked the speed, but pure road wasn't my goal.
    This new Revolt is pretty damn sweet, fast and comfortable. I find slow speed tight cornering a slight bit sloppy, but it's fine.
    This is my first time using eTap AXS, and it's a very nice setup. It's making me contemplate getting the AXS upgrade kit for the Trance Adv
    This bike is such a great value for what you're getting. I'm very happy I got the Revolt over the TCX.
  15. #815
    Dec 2019
    @EP3RR
    Sharp looking ride. What model is the seat bag & the light around the seat post? I've had a hard time finding a light with a flat base (vs concave) that would more easily mount to the flattened D shape or the Revolt post.
  16. #816
    Mar 2015
    Quote Originally Posted by biglmbass View Post
    @EP3RR
    The seat bag is https://www.evocsports.com/products/...ies/saddle-bag
    And the tail light is a Giant Numen Plus Spark TL. Itís INSANELY bright, like stupidly bright. I tried looking on giants website, but looks to be gone. Try a LBS. However, I HIGHLY recommend this tail light.
  17. #817
    Dec 2019
    Anyone else know if a good rear light that has a flat base to enable seatpost mounting on D-Fuse, d-shaped, post. The one mentioned below is no longer available.
    Thanks, EP3RR for the saddle bag link. Been thinking on a bag w' more capacity than my current one.
  18. #818
    At Work
    I use the garman Varia Light/Radar (Do a good bit of road riding also). No issues mounting it. Also the Bontrager Flare R works really well.
    TREK EX9 27.5
  19. #819
    Mar 2015
    I think they have a smaller version of the same light. Just little smaller, which for being this bright, I really wouldnít worry about the size. Heck, I could go for a smaller one (I wish thatís what she said)
    I also had a Bontrager Flare, but found it wasnít bright enough for daytime riding, and doesnít cover as big of angles. Being visible from the side is important to me.
  20. #820
    Reputation: pulser's Avatar
    Dec 2004
    My Bontrager flare RT mounts to the seatpost just fine.
  21. #821
    jasonaknight
    May 2020
    Hi all. New to this thread, so please go easy.
    I am considering a Giant Revolt Advanced 2 (2019) in orange, as my LBS is running a special for the ZA Rand equivalent of $1,500. In order to get rid of the Giant Conduct system, I'd like to know if I can fit the Shimano GRX 810 1x11 kit (for $1000), and if there would be any issues with cassette or BB? Many thanks
  22. #822
    Feb 2010
    Quote Originally Posted by olibluegoat View Post
    Wow can you list the spec on that. Woukd love to get mine that light
    Base model: Giant Revolt Advanced 1 (2019)
    Size: L (I'm 6'2"with 33" inseam)
    UPDATES:
    Wheels: Light Bicycle AR36 (w/ DT 240 hubs)
    Tires: Conti Terra Speed 700x40
    Rotors: Sram centerline R (160 mm)
    Cassette: XG-1195 (10-42t)
    Derailleur: Force 1
    Levers+brakes: Force 1
    Crankset: Force 1 GXP, 40t (175 mm)
    Handle bars: Easton EC70 AX Carbon
    Stem: Easton EA90
    Saddle: Prologo Dimension NDR TiroX 143
    Pedals: Shimano XTR PD-M9100
  23. #823
    May 2020
    Quote Originally Posted by kiwiscott View Post
    Hello kiwiscott, your posts come extremely timely. I am going nuts with the same issue: I cannot get the cable to get out of the chainstay through the tiny hole. Did you remve the part inside the frame with the tiny hole? How did you do that? Looking forward to your answers.
  24. #824
    May 2020
    Quote Originally Posted by heartland View Post
    Hi Heartland, I am struggling with the same issue and am not clear how you resolved it. Did you remove the part with the tiny hole that is deep in the frame? Is it supposed to slide out? Did you damage it with your drill? What did you replace it with if it is the case. It is my first time changing shifter cables and am going CRAZY
  25. #825
    Dec 2019
    update
    Update
    After a bit more time googling the topic I ended up with the following:
    Cygolite Hotrod 50-Lumen 6-Mode USB Rechargeable LED Bicycle Rear Tail Light
    It fits perfectly on my seatpost & is shockingly bright at its highest setting. I think weíre going to really happy together.
  26. #826
    Quote Originally Posted by gijom View Post
    Hey, just saw this. Yes, the piece slides out, but I couldn't for the life of me get it loose with a pick or screwdriver or anything. I got frustrated enough that I decided to drill out the inner hole. I gently (well, as gentle as you can be with a power drill), stuck the drill in there, and it turned immediately, which enabled me to slip it out. The drill didn't damage it --even though that was my intention
    There is probably an easier way to do this, but it's my first time messing with internal routing. That piece definitely needs to come out because there is a skinny tube on the other end that would be impossible to poke a cable into.
    Also, in retrospect, I should have smeared a bit of grease around the housing stop before reinserting it to help it slide out easier.
  27. #827
    Dec 2019
    How are you folks mounting cycle computers to your Revolt? Just now trying to mount my new Garmin 530 (my 1st device) and am not crazy about the included stem mount options. I might could continue to stretch the largest bands to fit, but it's a struggle and not ideal mount location IMO. The out front (handlebar) mount will not quite tighten down as securely as I'd like on the small full round section coming directly out of the stem. Aside from that small section of round bar, the bars taper quickly to full oval & the mount, naturally, doesn't work there at all. I've not yet researched other options; thought I'd mention it here first. I have considered cutting a small section of inner tube to use as a shim so the out front mount will fit better right next to the shim.
    Edited to add: I'm not beyond buying a better or different out front handlebar mount if need be & plan to anyways as i have other bikes I'd like to use the 530 on.
    Any & all info is appreciated...
  28. #828
    At Work
    LBS installed my wahoo when I bought it, he used some kind of Bar Tape and cut it down, wrapped it around the bar next to the stem to give the outfront mount better grip.
    TREK EX9 27.5
  29. #829
    Dec 2004
    I use an old barfly mount that puts the computer over the stem. Itís the same one I use on my mountain bike.
    https://barflybike.com/collections/m.../bar-fly-4-mtb
  30. #830
    Apr 2019
    K-edge
    Hello,
    I'm using a K-EDGE, it's pretty inobtrusive. I've also used an official Garmin mount, the only difference is that it sits higher on the stem and it makes easier reaching the two buttons on the bottom side of my Garmin 520 (for instance the one on the right, used for pausing a ride). But given that I hardly touch those buttons during a ride I must say I prefer the K-EDGE as it sticks out less than the Garmin.
  31. #831
    Apr 2020
    I have the Advanced pro 2 which came with the conduct brakes (removed). That system has a bracket that replaces the stem bolts with an out front mount. Itís not elegant (like the garmin our front brackets) but itís functional and sturdy. Iíd never thought about it to much until now so itís effective.
    some thing this was an after market option looks better (just have to get it mounting with the right stem)
  32. #832
    Dec 2019
    I put about two wraps of electrical tape closest to the stem & got the factory out front mount mounted to my liking. Canít believe I didnít think of the tape before posting. Itís not super duper gorilla strong tight, but I think itíll do and Iím thinking itís not a bad thing for the mount to have some ďgiveĒ in case of a crash. Iíd rather it get busted than the Garmin in case of a whoops. I may go back yet and put another wrap of electrical tape under it. Regardless, I just now tested the unit in my driveway & street out front. Works great & Iím stoked to use it on a real ride in an hour or so.
    Appreciate the suggestions & info offered. That out front stem cap mount is neat & isnít something Iíve seen before. May look into that for my other bikes, though they have round bars & the factory mount will be fine I think.
  1. Giant XTC advanced sl0 2015 vs Giant XTC advanced sl1 2016
    By owen_cool1 in forum Bike and Frame discussion
    Last Post: 06-05-2016, 12:12 AM
  2. Replies: 52
    Last Post: 09-11-2015, 06:16 AM
  3. Replies: 3
    Last Post: 07-24-2015, 11:16 AM
  4. The new Giant Revolt - cross/gravel grinder bike
    By kingsqueak in forum Gravel Bikes
    Last Post: 06-09-2015, 10:03 PM
  5. (X-post from Giant) XTC 27.5 Advanced 2 or 29er Advanced 1
    By Ninjasstolemytv in forum 29er Bikes
    Last Post: 09-30-2014, 04:26 PM
Members who have read this thread: 321
