Page 8 of 8 FirstFirst ... 45678
Results 701 to 781 of 781
  1. #701
    Jun 2013
    Thanks all for the advice on the front hub. I'm going to get some chinese carbon wheels (light bicycle) with dt swiss hubs for the Slate. A bit wider rim with a deep profile would make the bike ride even better I think.
  2. #702
    Feb 2014
    My shop was selling the leftover 2017 Apex 1 slates with the rigid lefty for almost 50% off so I jumped on it and a couple of days later I found a lefty oliver on ebay that looked pristine for $450. It comes with the steerer tube as well. Does anyone know if I will need to swap out the headset on the rigid slate or will it be the same as the suspension slate?
  3. #703
    Reputation: mtnbkr80015's Avatar
    Anyone tried the Cannondale Slate
    Just ordered a SAVE seatpost for my Slate and am removing my KS Lev dropper post as I find I am not using my bike for singletrack as much as I thought I would. Anyone interested in a dropper? Installed but no scratches and working perfectly
    Enjoy the ride...
  4. #704
    Oct 2016
    Quote Originally Posted by Seventh-777 View Post
    Where can I get an 80mm stem online for this thing? I ordered one over a week ago from BicycleBuys.com, and they just called me today to tell me that they don't actually have that stem and are sending me a refund. (Grr, won't do business with them again...)
    Try a Thompson stem, works a treat on mine:
    Grinduro, Scotland by mapledocumentdesign, on Flickr
  5. #705
    Jun 2013
    what Thompson stem is that and what did you you use for a stem cap?
  6. #706
    Reputation: mtuck1's Avatar
    Make sure you choose the 1-1/2" steerer, not the 1-1/8" if you do go with Thompson. It appears that they only offer lengths of 45mm, 75mm, and 95mm.
  7. #707
    Oct 2016
    Quote Originally Posted by matadorCE View Post
    Not sure on the model of the stem, itís just the regular 1-1/2Ē as mtuck1 mentioned, this is the 95mm version. Standard top-cap that came with the bike is a perfect fit.
  8. #708
    Feb 2014
    So just got off the phone with Cannondale and for those who are curious if you have the Slate with the rigid lefty the headset bearings are not the same diameter as the ones required for Lefty Oliver. So if you happen to have the 2017 Slate Apex 1 with the rigid lefty to be able to use Oliver you need these two parts:
    HD169 bearings
    QSISEAL
  9. #709
    just put the G Ones back on(tubeless) waiting for my SAVE seatpost and Fabric Flat Pro Carbon saddle. She will make a great 60/40 gravel/road bike. Thought I would have used it for more singletrack (thus the dropper).saw this poor girl limping with some sort of spike in her leg
    Enjoy the ride...
  10. #710
    May 2010
    Anyone here selling a rigid solo lefty fork?
  11. #711
    Feb 2006
    Some road duty, keeping up well enough with the roadies with this gearing range.
    I do want to put on more of a gravel bar, perhaps with 12-16 deg flares on drops, since will be on dirt more this summer. Anybody with experience on the degree amounts for stability?
  12. #712
    Jul 2017
    Force 1 Slate with custom DT Swiss wheels (XR361 rims, 240s hubs, competition spokes, G-one tires, centerline x rotors and stock cassette). Sorry for quality of image, canít wait for daylight after receiving wheels and had a quick night ride.
  13. #713
    Quote Originally Posted by aohammer View Post
    I am really happy with Easton EA70 AX.
    https://www.eastoncycling.com/products/details/ea70-ax
  14. #714
    Maxxis Ramblers SAVE seatpost and Fabric Flat Pro Carbon. Took off the Knards (tubed) running the Ramblers tubeless and took off the KS LEV Integra. Saved two pounds, mostly in the wheels
    Enjoy the ride...
  15. #715
    May 2010
    Quick question as a first time lefty owner. I want to flip my stem. Do I just pull off the plastic top cap, then just loosen the stem bolts? No preload like traditional fork set up?
    Loving this bike though. I changed out the stock tires to G-One in the rear and WTB Byway front. Rides great.
  16. #716
    Feb 2006
    Quote Originally Posted by 2:01 View Post
    Yes, itís that simple. Ride on....
  17. #717
    Feb 2006
    Quote Originally Posted by mtuck1 View Post
    So, the 16 degree flare gave you nice added stability on the rough stuff?
    Iíll check into it. Thx
  18. #718
    May 2010
    In my experience, not really. I had Salsa Cowchippers on my CX bike (not Slate). Having the bottoms flare out never felt right to me. I felt more natural with no or very little flare on normal bars. Plus, it drove me nuts on flat road or smooth dirt sections as I felt I couldnít get as aero. So I took them off and went with regular bars.
  19. #719
    Cowchippers are 24 degrees and though it doesnít sound like that much more compared to the Easton with 16 degrees the difference in feel is dramatic. I definitely would not choose a bar with more than 16 degrees.
  20. #720
    May 2010
    They did feel weird. I did have Cowbells before that and you are right, there was quite a bit of difference in feel. Although I really didn't care for the 12 deg flares on the Cowbells, either.
  21. #721
    Jun 2013
    Anyone looking to convert to 700c? I ordered a set of Chinese carbon wheels and they sent me the wrong size, so now I'm stuck with a frankenset of wheels that is not what I ordered but won't take back.
  22. #722
    What is a fair life expectancy for rear axle bearings? Whilst changing my BB bearings, I noticed that these have gone too. Less than two thousand miles.
  23. #723
    Oct 2016
    Quote Originally Posted by Stutto View Post
    About the same distance I covered on mine before I threw the wheel away and replaced it with a Hope wheel. The Formula hubs are OEM suppliers and trying to get spares for them is like pulling teeth, my free-hub failed, a replacement was impossible to get.
  24. #724
    I've ordered bearings, but I suspect that getting the old ones out will be a PITA.
    Already eyed up the hope XC wheel, but that would involve a new disc too - six bolt vs centrelock.
  25. #725
    Oct 2016
    A good excuse to get a Hope disc rotor at the same time.
  26. #726
    May 2010
    I swapped rear wheels recently, too. The stock Formula's left a lot to be desired. I went the DT route. Ordered a 350 CL hub from bike24 for $140 shipped. I've had Hope before, too, and they're excellent. But I favor DT's more, as cleaning/maintenance is a lot easier. I have DT hubs from 10+ years that I've abused and still going strong.
  27. #727
    Feb 2006
    I'm liking my WTB Resolutes tubeless, but also still have a fresh pair of Knards on another wheelset, tubed. Has anyone mounted the Knards tubeless? If so, easy or pain in the butt to mount, and do they hold tight on the beads, i.e. not lose air often?
  28. #728
    Feb 2006
    Really can't go wrong with DT hubs. I have them on almost all my bikes, even on my XC race hardtail for a few seasons.
  29. #729
    Reputation: Seventh-777's Avatar
    Aug 2013
    I run the Knards tubeless and it took quite a bit of doing to get them to finally seal up. They slow leaked for a couple of weeks, but after a good bit of riding they've been solid ever since (knock on wood).
    I consider myself pretty good at setting up tubeless, and the Knards were one of the most finicky tires I've mounted. I have the post-recall Mavic rims, FWIW.
    Trail: Scalpel-Si / Sherpa / Fatboy
    Gravity: Nomad / Wilson
    Road: Stigmata / Slate
    "Aah the great indoors - No One Ever"
  30. #730
    I never tried my Knards tubeless based on the horror stories of others but just got some Maxxis Ramblers which are tubeless compatible and offer black sidewall and knobby(for gravel tires) tread. I have two sets of G-Ones ( TL Easy and non tubeless), Knards, and stock tires as well. Had the shop install the Knards from the get go and was happy. I donít have thorns or other puncturing objects so tubed was fine for me. They never had a cut sidewall or any problem. The G-Ones however got sidewall cuts and were a struggle to remove so trailside repairs were not an option (it literally took an hour to remove those damn things). I just wanted to go tubeless again and save some weight and the Ramblers were a good option that mimicked the Knards but were tubeless compatible. I do have to add air somewhat frequently but they ride smoother than the Knards and the G-Ones and are much lighter. Between a switch from a dropper post to a SAVE seatpost and Ramblers tubeless , I saved about two pounds off my Slate and couldnít be happier. The ride is dialed and suits me much better as I did not ride singletrack like I envisioned I would with my Slate. If you can get the Knards to seat they are a great tire, no doubt based on experience, but there are lighter smoother options. Believe me I have tried them all. I will never run G-One tires again based on their removal efforts and the Rambler is a great tire.
    Enjoy the ride...
  31. #731
    Feb 2006
    Went ahead and ordered another WTB Resolute to replace the worn one. They seat great tubeless and handled nice, grippy and supple. I'll keep my Knards tubed on my backup wheelset, won't hassle converting them to tubeless. Used these today on a 30 miler fireroad/road combo with 3300ft total elev, no issues. Thx all.
  32. #732
    Aug 2013
    Quote Originally Posted by mtnbkr80015 View Post
    I had the same experience with the G-Ones. I liked they way the tires performed and think they're the best aesthetic option out there for the bike, but I ended up just cutting mine off of the wheels after breaking a good dozen or so tire levers trying to get them off.
    There's no way in hell I'd be able to do a trail/roadside repair on those things, I'm just lucky I got a puncture close to home and not in the middle of a century.
  33. #733
    Mar 2011
    Scouring through this thread. I have the Ultegra Slate and love it......BUT....geared wayyyy to high for hilly gravel. I want to make small changes to begin.......can I do an 11-32 cassette without having to change the derailleur or jack with chain length?
    Cheers.
    Alan
  34. #734
    Feb 2006
    Quote Originally Posted by irishal View Post
    Cheers.
    Alan
    Yes, that was one of the first 'upgrades' I did, made a difference. Did not have to change the chain nor adjust derailleur. But if your der does touch the low cog, turn in the B-limit screw just a tad.
    I have the Force 1 now with 44 x 42t, just enough for me, even on steeper hills.
  35. #735
    Aug 2013
    Cheers.
    Alan
    Yup, straight swap with no issues. Makes things a lot more comfortable in the hills, for sure.
  36. #736
    Jun 2013
    The Knards on the stock Mavic wheels were a nightmare to set up tubeless. I had to take it to a shop twice before one of the wheels stopped leaking air--forget about mounting them with just a floor pump or even a shot of CO2. I finally ditched them for the G-ones (yes they fit tight but they seal up well) and won't be going back. I hate tubes and on a bike like the Slate it definitely makes sense to run it tubeless.
  37. #737
    Cheers.
    Alan
    Yes, no problem with the cassette change but plan on a new chain as you're adding 4 teeth to the big ring.
    The other thing I did was swap the chainring(s) to 50-34 which are relatively easy to find. At one point Cannondale was shipping 2 chainrings with high end road bikes and most guys didn't take the smaller 50-34 so some dealers had a few of them sitting around. That's how I got mine. You can find them on ebay as well.
  38. #738
    Aug 2013
    After almost 1500 miles, the only thing I don't like about this bike is the crap engagement on the rear hub. I think I'm going to bite the bullet and have a set of new hoops spun up for it.
    Oddly enough, I have a 2018 carbon Scalpel as well and the stock rear hub engagement on that sucked too.
  39. #739
    Feb 2006
    I have similar experience. If both are of the FSA variety, they suck. Iíve converted to either Stans or DT Swiss, much happier!
  40. #740
    just re-wrapped my bars(Fizik 3mm tape)
    Enjoy the ride...
  41. #741
    Sep 2018
    Hi, did you overcome the free hub size issue and find a replacement? I'm trying to do the same and can't find a way to put a 11 speed road Shimano cassette on a crossmax pro
  42. #742
    Quote Originally Posted by Gritz View Post
    Not sure if this is directed toward me but I have experience with this and posted those experiences further down this thread. I used an 11 speed MTB cassette and removed one ring (and spacer) on a Crossmax wheel, which works flawlessly. I forget now which one I removed. There is another workaround that I didn't try which involves machining clearance into the back of the cassette which I am sure would work also. Ultimately that gearing was too low and I went back to the stock wheel and cassette.
    I would suggest contacting Mavic support as it has been awhile now and they may have a replacement free hub that would work by now.
  43. #743
    Aug 2013
    Winter is on the way... Are there any decent studded options for this bike yet?
  44. #744
    Jun 2013
    Recently changed wheels on my Slate and didn't pay attention that the rear brake rotor is Shimano centerlock instead of 6-bolt. Luckily TRP makes a 2-piece 6-bolt 140mm rotor similar to the shimano ice-tech rotor, since shimano only makes 6-bolt rotors 160mm and up.
  45. #745
    Feb 2014
    Isn't the slate 160mm front and rear?
    Sent from my LGUS997 using Tapatalk
  46. #746
    Jun 2013
    Quote Originally Posted by gus6464 View Post
    Not my '17 105.
  47. #747
    Reputation: 1-bar's Avatar
    My 17' Slate CX1 Force is 160/140. I think the comparable orange and red Force models are both 160 frt/rr now.
    Got LEFTY?
    -2017 Cídale Scalpel Carbon 3
    -2016 Cídale Slate Force 1
    -2014 Cídale Bad Boy 1
  48. #748
    Jul 2017
    I've just ordered a Slate, though it isn't clear if the UK distributor actually has any in the country. All the online shops have sold out within 2 weeks of the 2019 Slate being released in the UK. Fingers crossed!
  49. #749
    Went for a cold(sub freezing) ride this morning
    Enjoy the ride...
  50. #750
    Oct 2016
    Has anyone removed the Lefty? My frame is going for a respray, to remove the strut (calling it a fork just seems wrong) is it just a matter of removing the stem, slackening the upper and lower clamps and then tapping the steerer tube from above with a rubber mallet?
  51. #751
    YouTube has a ton of videos on this. That would be the easiest way to learn how to remove the lefty. Hope you post your re-spray when itís done. Good luck.
    Quote Originally Posted by Cheshire Cat View Post
  52. #752
    Feb 2014
    It is ridiculously easy.
    1. Remove top cap and stem
    2. Push down on steerer tube with hand
    3. Remove fork and top seal
    4. Bottom bearing will fall out and remove top bearing.
    That's it.
    There are only 3 pieces between the fork and frame. Top and bottom headset bearing and qsiseal.
  53. #753
    Feb 2014
    I have been using WTB Byway's since I got my slate but the clearance is hair thin at the rear chainstay and I have started training for the Belgian Waffle ride in San Diego and realized that I am not comfortable with them as the wheel has to pretty much stay perfect or I'm screwed.
    Has anyone mounted up Donnely Strada USH 650x42's on their Slate? They look like smaller Byway's basically.
    Or maybe I should be looking at the X'Plor MSO 650x42? Both look like super solid options.
  54. #754
    My BB has started creaking. Any revelations on fixing the creak and has anyone tried the BBinfinite solution or any type of threaded BB shell w the SI crankset?
    Got LEFTY?
  55. #755
    I called BBinfinite and their sleeved BB30 bearing setup does not work with the Slate because the internally routed lines - bummer. I had to have the bearings removed and greased to solve the creaking. That seems to be the only fix for now. On a side note, I installed my Mavic Open Pro UST 700c shod w 700x28 Yksion UST tires. I dropped a solid 1.6lbs. Pretty excited to try it out...
    Got LEFTY?
  56. #756
    Feb 2014
    Has anyone done the steerer tube conversion from project321 to use 1-1/8 stems on their Slate?
  57. #757
    Feb 2014
    Just got off the phone with project321 and on an XL lefty the adaptor will increase the stack height almost 2 inches on an uncut steerer. They were very nice on the phone and ordered the adaptor. Figured since Cannondale 1.5-inch stems are not cheap and now I can use whatever stem I want it's a no-brainer.
  58. #758
    Feb 2014
    Did the project321 1-1/8 conversion. It was super easy and trickiest part was removing the old steerer.
    Just take out old steerer and replace with project321 one then just put the top collar on top of the lefty top crown. The top collar piece is compression which extends into the frame and grapples the top headset bearing.
    You get a lot of extra stack with the new steerer as well. In the pics for reference there are 36mm worth of spacers below the stem. Will need to cut it for sure.
    Granted it wasn't cheap at 90 bucks but the 1.5in stems available aren't cheap either and options are super limited.
  59. #759
    Aug 2013
    Still on the hunt for a proper set of studded tires for this thing now that winter's on the way again... I emailed these folks:
    https://www.peterwhitecycles.com/studdedtires.php
    And they got right back to me. $116 plus shipping for a pair of 650x40 Nokian A10s with 72 studs per tire. Will be ordering up a set this weekend and will post up some pics when they're mounted.
  60. #760
    Jul 2017
    I have obtained a Slate Force 1. Looks as if a lot of retailers sold out quickly in the UK.
  61. #761
    Feb 2018
    I donít know if this is relevant but I noticed new 2019 models of the Slate up in Cannondaleís website. https://www.cannondale.com/en/USA/Pr...d-8ece8f0935e3
    They seem to be called ďSEĒ models and the are species slightly less in areas with a price bump (at least in the US). I suspect this may be due to tariffs. In any case thought it was worth a mention because I had assumed the Slate was being discontinued in favor of the new Topstone and others.
  62. #762
    Aug 2013
    For those curious about studs, I ended up getting the Nokian A10s from Peter White Cycles. It was an interesting buying experience - the lady who answers the emails is super polite, but Peter himself is not exactly the most pleasant guy to do business with on the phone and has all the charm and charisma of Bill Belichick.... His reputation for being hard to deal with is well-deserved.
    It was not the $116 that I was quoted over email, it ended up being somewhere around $160. Either way - here they are.
    Not the most fun to mount, and they are super thick. Unfortunately I forgot to weigh them beforehand, but if you're running studs I you aren't exactly shaving grams anyway. A couple of broken tire levers, a dozen or so f-bombs and some help from the heat gun later, they roll pretty well.
  63. #763
    Sep 2014
    Got myself a 105 Slate to replace my Giant TCX. Absolutely love the slate, I've fitted WTB resolutes and changed the rear cassette to 11-40 with the new Ultegra RX rear mech. This gives me all the gears I need for climbing without spinning out on tar...
    Only other mod I'm going to make is to fit a set of bars with a small amount of flare.
  64. #764
    Jul 2017
    Anyone else having dramas converting the WTB tyre to tubeless? I can't get my car tyre compressor to seal them. Going to take them to the local bike shop or to the petrol station who have an industrial compressor.
  65. #765
    Dec 2016
    Quote Originally Posted by amcdj View Post
    Have you tried the usual tricks? Valve core out, soapy water?
  66. #766
    Jul 2017
    Thanks, didn't try taking out the valve core. The shop mechanic has sorted it for me.
  67. #767
    Aug 2013
    I'm going to grab some lightbike carbons to build up over the winter. Does anyone happen to be running these?
    https://www.lightbicycle.com/Disc-65...vel-bikes.html
    Opinions, if so? They're pretty inexpensive, and I have a spare set of stock hubs from my recall wheels that I can throw at them.
  68. #768
    Jul 2017
    2019 Slate
    Here's my new Slate. Tubeless conversion. Rear hub Thru-axle changed to DT Swiss ratchet version after immediately stripping the one that came with the bike.Anyone tried the Cannondale Slate-20181212_130359-1-.jpgAnyone tried the Cannondale Slate-20181212_130408-1-.jpg
  69. #769
    Feb 2014
    Here's my new Slate. Tubeless conversion. Rear hub Thru-axle changed to DT Swiss ratchet version after immediately stripping the one that came with the bike.Click image for larger version.
ID:	1229326Click image for larger version.
    What chain is that?
  70. #770
    Jul 2017
    Its the stock chain with some Wend wax on it
  71. #771
    Jun 2013
    I have those, and like them a lot. I got mine from the US side of Light Bicycle built with I9 hubs. They made the bike feel fast and like typical carbon wheels they smooth out some of the harshness and the steering is very direct. These aren't super deep, but I can definitely feel a good crosswind when riding on these.
  72. #772
    Sep 2018
    Is anyone running fenders? Looking for a rear fender to fit to up to 42mm wide tires
  73. #773
    Feb 2014
    Anyone interested in a Slate part-out? Have the frame along with other goodies that are not common:
    Slate frame in XL
    Lefty Oliver fork
    Lefty Solo fork
    Project321 1-1/8" steerer for the Lefty Oliver
    100mm and 80mm 1.5" Cannondale stems
    So basically this will let you run the Slate in multiple configs
    Slate with Oliver and 1.5" steerer
    Slate with Oliver and 1-1/8" steerer
    Slate with Solo rigid and 1.5" steerer
    Could also sell the complete bike as well I guess with Byways if anyone is interested.
  74. #774
    Death Mud
    If the rigid fork fits a large frame, Iíd be interested in that and the bits to make it work.
  75. #775
    Feb 2014
    Quote Originally Posted by velcipede View Post
    Ohh sorry should have specified better. I am looking to sell everything together as I don't want to keep anything that will never sell unless it's all together.
  76. #776
    Oct 2016
    So, anyone else going to try a WTB Sendero front and Resolute rear combo on their Slate? Just picked a Sendero up, seems like itíll certainly give the front end some grip.
  77. #777
    Oct 2018
    My Slate
    "Pigeon, oiseau ŗ la grise robe/dans líenfer des villes/ŗ mon regard tu te dťrobes.../Tu es vraiment le plus agile."
  78. #778
    Feb 2018
    Quote Originally Posted by SRD123 View Post
    I don't run regular fenders on it because of the lefty fork and I usually MTB/gravel on it (I have a racing bike and a gravel commuter with 2 wheelsets). I use the Crud Racepac 29ers on the Slate when it has rained recently or is raining. The worked fine enough for me last season but they do do have a bit of the offroad look to it, so it might not be your bag.
    I haven't run them in months because since this fall, the girlfriend has been riding my Slate both on and off-road and I set it up for her (she likes the disc brakes and shifting, and it's the best bike I own for MTB). I'll probably have to dig out the rubber bands on the front guard sometime and clip them on in a month as she's starting to get more serious about cycling.
    Wish I could find some photos of it.
  79. #779
    Jul 2017
    2019 Slate
    Better pictures of the 2019 SlateAnyone tried the Cannondale Slate-img_7034.jpgAnyone tried the Cannondale Slate-img_7036.jpgAnyone tried the Cannondale Slate-img_7033.jpg
  80. #780
    Reputation: solarplex's Avatar
    Apr 2014
    Better pictures of the 2019 SlateClick image for larger version.
ID:	1233547Click image for larger version.
ID:	1233548Click image for larger version.
    Oh that red is
    Fatbike, XC bike, Gravel Bike....
  81. #781
    I built up a very similar wheel for my Slate but used the Nextie cArbon version. I also went slightly narrower, 27mm external si that the 42c Resolutes would give some rum protection from the rocks. With DT240 hubs, they were a nice upgrade as well.
  1. Cannondale Slate Force CX1 tubeless?
    By Just J in forum Cyclocross
    Last Post: 10-09-2015, 01:11 PM
  2. ASR-5 Slate Ano is a GREAT color!
    By NightOWL in forum Yeti
    Last Post: 02-04-2013, 08:01 PM
  3. Pilot Cove Loop - Slate Rock
    By bank5 in forum North & South Carolina
    Last Post: 08-29-2012, 07:01 AM
  4. OK I give up : Slate Trail Access From East
    By VBrakesAndBarEnds in forum Arizona
    Last Post: 07-12-2012, 07:11 PM
  5. History of slate rock connector?
    By puddleducky in forum North & South Carolina
    Last Post: 10-24-2011, 12:37 PM
Members who have read this thread: 194
