Strava on iOS10 permanently using location??- Mtbr.com
    Professional Noob
    Reputation: eicca's Avatar
    May 2014
    Ok. So a month ago I did my first ride with iOS10. Afterward, Strava was continuing to use location services and the arrow icon would not go away. I have the setting set to "Always" and I'm always sure to close the app when finished. On iOS9, the location arrow would turn off after a few seconds.
    On iOS10, I have reinstalled the app, disabled background app refresh, restarted the phone and updated the OS twice! But if I set the location settings to anything other than completely off, the arrow pops up in the menu bar! I haven't used the app in a month!!
    Anyone else having this issue?
    => CannondaleExperts.com <=
    All the parts and accessories your Cannondale ever needs
    Professional Noob
    May 2014
    Nobody else with iOS 10 has this problem....?
    Reputation: thecanoe's Avatar
    I have mine set to WHILE USING APP. When I close Strava, the arrow icon takes a few second to turn off. I'm using an iPhone SE
    Santa Cruz Tallboy
    Moonlander
    Professional Noob
    May 2014
    Quote Originally Posted by thecanoe View Post
    Try setting it to "Always." On iOS 9, even set to "Always" the arrow icon would go away a few seconds after closing. On iOS 10, it's been two months since I've opened the app, several reboots and iOS updates, and the icon still turns on if I select "Always"
  1. Fox Re:aktiv Shock permanently locked out
    By Trek Ninja in forum Shocks and Suspension
    Last Post: 10-15-2016, 03:21 PM
  2. Location, location, location - advice
    By iceboxsteve in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 06-27-2014, 07:20 PM
  3. Front fork is locked in extended position
    By Greenie in forum Shocks and Suspension
    Last Post: 06-08-2014, 05:51 PM
  4. Do you keep your bar light permanently mounted?
    By Hyperocity in forum Lights and Night Riding
    Last Post: 03-25-2014, 05:29 AM
  5. fork permanently flexed/misaligned??
    By bluebean in forum Shocks and Suspension
    Last Post: 06-08-2012, 03:13 PM
