Stages power meter cut power reading data by 80% on same ride. Huh?- Mtbr.com
Results 1 to 3 of 3
    Jun 2015
    No good Stages power meter cut power reading data by 80% on same ride. Huh?
    I have done the same ride with avg power around 180W for 3 months. Suddenly, on the same ride that I always do, the Stages meter is reading avg power at 52W. Overall, the power graph is lower over the entire ride. It just looks shifted down in value. I have not lost weight. The bike nor anything else has changed. I calibrated the power meter then changed the battery. It still reads lower numbers. When calibrated the zero offset number is always 1023 or 1024. The stages website states it should be between 800 and 900. Anyone have any advice? Other than, I should have not purchased a Stages power meter.....ha ha. It was super cheap ($330) from an authorized seller, new. Feeling $330 of regret....
    Reputation: Lone Rager's Avatar
    Dec 2013
    Other PMs go out of wack too. Call/email Stages and maybe send it in for repair. Is it still under warranty?
    Any chance water got in it? There was a period of time when Stages had an issue with that and they sent out improved covers. You might open it up, leave it in a warm place to dry out and see what happens.
    What, me worry?
    Jun 2015
    Yes, it is only 3 months old. So, it should be under warranty. I will look under the battery cover for moisture. I just sent in a support ticket with Stages. Thanks, Lone Rager.
  1. Replies: 2
    Last Post: 11-19-2015, 08:18 PM
  2. Stages Dura Ace Power Meter $450 Closeout
    By twobigwheels in forum XC Racing and Training
    Last Post: 06-30-2015, 12:03 PM
  3. Stages power meter compatibility
    By BacDoc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-02-2014, 09:24 AM
  4. Stages power meter on Czar?
    By InertiaMan in forum Turner
    Last Post: 06-07-2014, 12:54 PM
  5. Yeti Crab... huh, huh... huh, huh
    By icegeek in forum Yeti
    Last Post: 01-06-2012, 02:58 PM
