Garmin mount insert- Mtbr.com
Results 1 to 18 of 18
    Reputation: James80's Avatar
    Garmin mount insert
    I managed to break my 520 off itís out front mount with my knee, the insert broke protecting the mounting tabs on the 520 (good thing) but everything Iíve managed to find on line says the sacrificial insert isnít replaceable (bad thing).
    Is this true? Garmin doesnít sell the insert?
    Iím using one of the bar mounts for now but much prefer the out front backwards over the stem.
    Oct 2018
    Have you searched Google? I don't have a Garmin, but I recall reading something about inserts.
    I searched Garmin mount insert and there are a lot of pictures....perhaps check that and see if those inserts are what you need. Perhaps the inserts are not for Garmin specific mounts, but aftermarket?
    Yeah there are lots of inserts but most if not all are replacements for K-Edge mounts and most answers on amazon says the k edge replacement doesnít fit the Garmin mount but I was hoping to hear from users here.
    since 4/10/2009
    Reputation: Harold's Avatar
    so this is weird. I looked at my Garmin out front mount, and the insert is clearly removable/replaceable. The screws are on the underside of the mount, and thread into the knurled nut inserts you see in your pic. I could not find such an insert on Garmin's website. My own Google search did not turn up any inserts that are threaded like the Garmin one. The screws all thread into the mount base and the screw head is countersunk into the insert, and holds the insert in place.
    why would garmin make this part replaceable, but then not sell the replacement part?
    I'd reach out to Garmin's customer service and ask them WTF. Then if they don't supply you with a replacement, buy an aftermarket mount that has readily available replacement inserts, or is cheap enough to replace outright.
    Reputation: Wombat's Avatar
    Perhaps the K-Edge Garmin inserts also fit the Garmin mount? https://k-edge.com/shop/computer-mou...in-insert-kit/
    Tim
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ won't work. Screws go the wrong way, if nothing else. If it does fit in the Garmin mount, it might be possible to use some longer screws with nuts under the mount...?
    Perhaps the intention of Garmin's insert may be allow using two materials, a strong one for the structure, and a frangible one for the insert so as to reduce the possibility of breaking the tabs on the Edge.
    Do the math.
    Quote Originally Posted by Lone Rager View Post
    You are correct. On the older units the tabs broke off the unit making it useless. Garminís solution is great but only if they sell replacement inserts.
    Quote Originally Posted by Harold View Post
    Iíll message Garmin and report back.
    The mount is $39.99 retail and can be found cheaper.
    You can buy cheap 3rd party bar mounts that have inserts that work w/ Garmin mounts. I found one recently for something like $10, so not cheap but much less that a whole new assembly from Garmin.
    since 4/10/2009
    Quote Originally Posted by ChrisInYpsi View Post
    got a link to such a thing?
    Me, I'd rather buy something like a k-edge, where the inserts are easy to get.
    Jun 2013
    Quote Originally Posted by James80 View Post
    Reviving the thread. Good news and bad news.
    Bad news, I contacted Garmin directly to purchase a replacement insert, they do not sell them and I have yet to locate an aftermarket part that confirms compatibility.
    Good news, they offered to send me a replacement out front assembly for free as a goodwill gesture.
    A for customer service, F for not offering the replacement.
    Did this over the customer support chat, so no hold time and automated menus to deal with. Simple and fast.
    since 4/10/2009
    Serious fail for making a mount with an insert, but then not offering said insert for sale for when people inevitably crash and break it.
    Dec 2013
    Definitely. At least breaking the insert and having to get an entire new mount is preferable to breaking the tabs on the Garmin and having to get a new (or "refurbished") Garmin, which is the other way this can go. Either way, it's kinda lame on Garmin's part to not offer replacement inserts or replacement backs.
    Do the math.
    since 4/10/2009
    Well, the other way they could go would be to stop pretending that the mount itself isn't entirely sacrificial (because it is, the insert serves no real purpose at this point) and make the whole thing out of the same material that winds up being sacrificial.
    The solution I see here is to run the replacement Garmin mount until it breaks, and then replace it with something that offers true replaceable inserts, like a K-Edge or something.
    Dec 2013
    Yeah. We're wining and complaining about Garmin. K-Edge is good now...but originally they were all aluminum without a plastic insert so it was always the Garmin tabs that broke.
    Do the math.
    since 4/10/2009
    no doubt. but at least k-edge sells inserts now. I have a SRAM quickview mount that's just plain, lightweight, molded plastic. No pretense of an insert. Crash and break it? Buy a new one. It's fairly brittle. It'll definitely go before the Garmin tabs. I also use the basic Garmin rubber band mount on one of my bikes. I just don't like any other mounts on that one. I have probably 20 of those things and 4x as many rubber bands, so if it breaks, then it's not like I'm hurting for a replacement.
    The Garmin mount itself is fine. Good, even, because it's quite stable. Except it has replaceable inserts...but no inserts to buy for it. So the nice, stable base gets tossed if the insert fails like it's supposed to in a crash.
    Reputation: thasingletrackmastah's Avatar
    I have an Ali mount (ZTTO topcap type).
    Like this, but different store:
    https://es.aliexpress.com/item/32837357059.html
    My insert broke so I mailed ZTTO.
    Yes they do have spares, but because of handling and shipment, buying a whole new mount was cheaper.
    Strange world.
    (The ZTTO insert does not fit TS's Garmin outfront mount)
    Belgian beer and Scotch whisky.
    Dec 2018
    If I had a choice, I would prefer a mount that has a sacrificial mode and would fail before the tabs on the device. Iím OK with replacing inexpensive mounts out to about $20 - $25 in value. Easier and much cheaper than having to have a Garmin replace the unit with a refurb.
  1. Threaded Insert in Carbon Fork Disc Brake Mount
    By 755872 in forum Brake Time
    Last Post: 04-04-2015, 10:38 PM
  2. JET 9 RDO - Loose frame insert (pivot mount)
    By xcbarny in forum Niner Bikes
    Last Post: 09-01-2014, 11:02 AM
  3. Garmin 800-Use Elevation Correction on Garmin Connect?
    By nevermiss in forum GPS, HRM and Bike Computer
    Last Post: 03-15-2012, 01:05 PM
  4. Garmin Connect or Garmin Training Center elevations
    By wvmtb in forum GPS, HRM and Bike Computer
    Last Post: 06-17-2011, 06:59 AM
  5. Garmin software and Garmin GPS Not talking.
    By crux in forum GPS, HRM and Bike Computer
    Last Post: 01-01-2011, 11:44 AM
Members who have read this thread: 44
