Results 1 to 6 of 6
    DNW
    DNW is offline
    Reputation: DNW's Avatar
    Mar 2006
    Garmin Fenix 5 plus & Computer Question
    I currently have a Garmin Fenix 5 plus that I wear all the time and use for all my fitness tracking. I find it is just OK for riding, as the small wrist mounted display is not ideal while riding.
    I want to add interval training to my routine, and was thinking of adding a bike computer to make that easier, essentially as a display. Here are my parameters:
    • I want to continue using the watch as my primary tracker.
    • I usually use an external HRM (Wahoo Tickr) for activities
    • I don't care that much about mapping
    • I am interested in checking Strava segments after the ride, not so much during
    • I only have one bike, my MTB.
    • My primary use of the computer would be a display to track intervals.
    • I use Training Peaks to track and create workouts
    • I am not interested in mounting the watch to the bars
    So far I have looked at the Wahoo Bolt and Garmin Edge 520. Are those overkill for my use? I would probably use that to guide the workout but the watch to record it?
    Should I look at a Garmin and use it as an extended display? How well does that work?
    Thanks for any input, I read a bunch of threads here and other reviews and am still scratching my head.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by DNW View Post
    Either one should work well, since IIRC all Tickr HRMs send both ANT+ and BTLE signals (Garmin Edge 520 only receives sensor data from ANT+ devices).
    I don't know how the Garmin extended display function works. Not sure why you would buy an Edge 520 to use at the same time as a Fenix as only an extra display, and turn off the GPS and recording functionality of the Edge. Seems like an excessive level of redundancy. If you don't like using the watch when on the bike to view workouts, then why not just buy something for the bike that serves your needs?
    DNW
    DNW is offline
    Mar 2006
    I think where I get confused is on how multiple devices will be managed without duplicating or losing fitness data. Right now I sync with Garmin Connect, and Training Peaks and Strava pull from that. Is it as simple as adding another device to Garmin Connect and starting an activity on that vs the watch?
    Reputation: Lone Rager's Avatar
    Dec 2013
    You can mount the watch on the bars, though it will still be small. Here's some recent info on Garmin's "extended display":
    https://www.garmin.com/en-US/blog/fi...-display-mode/
    Do the math.
    since 4/10/2009
    Garmin Express handles multiple devices easy peasy. On my computer, Express handles multiple devices (mine and my wife's) and pushes data to the correct Connect accounts no problem. Each Connect account then pushes the data over to the correct Strava accounts no problem, as well.
    So certainly, it CAN be this easy. But the Edge wouldn't be doing "display mirroring" of your Fenix. The only reasons I'd see choosing display mirroring over a standalone device would be if you're doing a multisport activity like Lone Rager's article mentions, or if your Fenix collected some important piece of data that the Edge would not. Say, for example, you preferred the HRM built into the Fenix, or you had the pulse ox sensor and cared about the data, the rep counter (back to the multisport functionality again), etc.
    But, since you're using a Wahoo Tickr HRM strap, you can just pair that to an Edge or Bolt and use that as a standalone computer for biking, and the watch for everything else. Not crazy to have a device dedicated to a particular activity. I use a Forerunner for running (haven't done much of that for a long time due to my knees) and an Oregon for hiking or paddling or even some mtb rides.
    Armature speller
    Sep 2004
    I used my watch to do the recording and syncing.
    The head unit is just for info during the ride and the ride gets deleted at the end instead of saved.
    The head unit never gets synced.
  1. Garmin vivoactive HR replacing Garmin Bike Computer (500,510,ect.)??
    By Jukez in forum GPS, HRM and Bike Computer
    Last Post: 11-13-2016, 04:33 PM
  2. Garmin Fenix 3HR GPS question
    By BuckeyeRT in forum GPS, HRM and Bike Computer
    Last Post: 11-11-2016, 02:57 PM
  3. Garmin Fenix
    By Dirthugger in forum GPS, HRM and Bike Computer
    Last Post: 10-08-2012, 01:55 PM
  4. Droooooolll....Garmin fenix
    By Harold in forum GPS, HRM and Bike Computer
    Last Post: 08-11-2012, 05:17 AM
  5. Garmin Vs Bike Computer (computer more accuratte)?
    By Ilikejeeps2 in forum GPS, HRM and Bike Computer
    Last Post: 04-22-2012, 02:33 PM
Members who have read this thread: 25
