Any fix for broken mounting tabs on a Garmin?- Mtbr.com
Results 1 to 8 of 8
    Took an endo today, and must have knocked my Garmin with my chest or stomach on the way over the bars. Anyway, the tabs on the Garmin broke off inside my KS Edge bracket, and so now it won't hold solidly. Any fix? Replacement back available from Garmin?
    Reputation: Lone Rager's Avatar
    Dec 2013
    Replacement backs are not available. Garmin will sell you a refurbed unit for $100-$150 depending on the model. There is a company that makes an aluminum piece that attaches to the back to replace the broken tabs.
    https://www.instructables.com/id/Gar...en-Tab-Repair/
    I'll add that I've hit my chest on my Garmin more than a few times when I had it on top of my bars or stem. I put it on a mount that extends rearward from the bars right next to the stem. It does come close to hitting my knee but I also have it loose enough that it will rotate around the bar before anything breaks.
    https://forums.mtbr.com/gps-hrm-bike...l#post13931942
    What, me worry?
    Yeah, I contacted Garmin, and after some chat where the rep mentioned that there was no replacement, nor will current parts fit on my older 510, he finally directed me to the DogearsGPS site, and I have a new aluminum cup on the way.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by rufus View Post
    yup, those are what you need.
    Be aware that since you'll be using something with MUCH more robust tabs, you want to make absolute certain that you're using a mount with a replaceable plastic insert that will be your failure point in the future. That is, unless you're just using those cheap Garmin rubber band mounts as it is.
    Dec 2013
    ^^^ Yeah. I have a friend who put one of those aluminum backs on his Garmin. He wound up tearing that off too.
    What, me worry?
    since 4/10/2009
    Quote Originally Posted by Lone Rager View Post
    I've got a bunch of mounts with replaceable inserts (plus a bunch of spare inserts) and they do work well as the failure point. I've wrecked a couple of times where the Garmin was pried out and the insert broke instead of the Garmin. Except the one time that the Garmin's screen smashed on a rock. But the tabs didn't break!
    Quote Originally Posted by Harold View Post
    I do. K-edge switched to replaceable plastic inserts years ago.
    Reputation: escrowdog's Avatar
    Oct 2018
    For anyone else reading this, my Edge Explore was still under a year old and Garmin did exchange the unit for me after I broke a tab off. Key is "yes, I was using a Garmin brand mount". You pay shipping of the old unit back to Garmin.
  1. Garmin Edge Series with broken Mounting Tabs?
    By Jomax2 in forum GPS, HRM and Bike Computer
    Last Post: 05-18-2015, 10:01 PM
  2. Disc brake tabs: Seatstay vs Chainstay mounting
    By bee in forum Frame Building
    Last Post: 04-27-2012, 07:55 PM
  3. Niterider replacement parts (mounting tabs)
    By mgv101 in forum Lights and Night Riding
    Last Post: 11-08-2011, 08:28 AM
  4. Intense Uzzi vpx do they have iscg mounting tabs
    By BLH2 in forum Downhill - Freeride
    Last Post: 07-15-2007, 11:41 PM
  5. Facing caliper mounting tabs?
    By Singletrack Pig in forum Brake Time
    Last Post: 06-28-2005, 06:30 AM
