You weigh 170lbs +/-.....................- Mtbr.com
Results 1 to 8 of 8
    .........and ride your Reign "all mtn."/"aggressive xc" approx. 60/40 using 2.35 tires.
    What psi do you run in your main/spv chambers?
    Reputation: tkblazer's Avatar
    i'm 175 and currently running around 135 main and 70 psi spv.. keep in mind i've only had my reign for a week and i'm still messing around with different psi in the shock.
    Bump. Anyone else?
    Motion activated
    Reputation: Steve71's Avatar
    Run enough air pressure in the main chamber to get between 25-40% sag, adjust to taste.
    Start out by setting the SPV pressure to the minimum 40 psi. If you want less out of the saddle bob, increase the SPV pressure a bit (10 psi) and try again. The down side to increasing the SPV pressure is that the small bump compliance will suffer.
    Your tire pressures sound really high for you weight.
    Happiness is a warm 2 stroke.
    Quote Originally Posted by Steve71
    Yeah thanks, I can do that just wondering what others had arrived at.
    60/40 is riding venue %s, not tire pressures!
    Mmmmmmmmmkay, anyone else wanna' post their #'s then?
    Just roll it......
    Reputation: ebxtreme's Avatar
    Quote Originally Posted by tungsten
    First off, I'm assuming you're referring to the swinger 3 way.
    If that's the case, I'm 160 nekkid (170-175 with gear) and run about 110-115 psi in the main chamber and as little as possible in the SPV. Usually around 60 psi.
    Since you're revising an almost 2 year old thread that you started, what are your issues? In general, I would worry less about "what pressure" and worry more about "what sag". I like to have 30-35% sag on my rear shock.
    EB
    180lbs on a reign x 2.35 maxxis high rollers f and r 32psi rear about 28-30 fr add 5 psi per tire if i know i will be riding super rocky areas
    2020 Santa Cruz Megatower
    2015 KTM 1190 Adventure R
