XC-1 Wheel Tubeless Help- Mtbr.com
Results 1 to 5 of 5
    Jul 2016
    I just bought a 2017 Trance 2 and tried going tubeless with Sun Ringle presta valves but one won't seat correctly on the XC-1 rim (it audibly leaks at 25psi). I tried tightening the nut with a needle nose pliers but it still leaked. I saw somewhere that there was a specifically contoured presta valve which fits neatly to the inside of the rim. I tried looking at the Giant at the 3 they offered but was confused because I couldn't tell if the profile would fit right. Anyone know for sure?
    Oct 2011
    Quote Originally Posted by hucker73 View Post
    I just converted my 2017 trance 2 to tubeless and I just used some stems that I had laying around. They leaked for a little bit at the stems tell the stans sealed them up. I keep it on the stand for a few days and would just keep move the wheels around to get the stans over the stems. Make sure you are not over tightening the stems because this could cause a problem.
    Never tighten the nut with pliers unless you have them with you on the trail. If you flat and can't get that valve out of the rim, then you can't put a tube in and you're effed.
    Sent from my Moto G (5) Plus using Tapatalk
    Reputation: grubetown's Avatar
    Sep 2013
    Did you read the description of tubeless valves on the Giant website?
    Nov 2015
    I had same prob. After spinning wheel a few times and bouncing on ground, the liquid latex needs to set in room temp, this winter been cold. Good to go for me 5 mos running
  1. Converting Maxxis DH non-tubeless to tubeless; Stans is no help
    By rdhfreethought in forum Wheels and Tires
    Last Post: 07-25-2016, 10:52 AM
  2. Replies: 4
    Last Post: 05-30-2015, 10:03 PM
  3. Replies: 1
    Last Post: 12-20-2013, 11:03 AM
  4. Using tubeless tire on a non-tubeless wheel
    By Will Goes Boing in forum General Discussion
    Last Post: 05-07-2012, 04:58 PM
  5. To much wheel weight, going tubeless. Help
    By heathcoat in forum Wheels and Tires
    Last Post: 05-18-2011, 06:55 AM
