VT travel setting?- Mtbr.com
Results 1 to 10 of 10
    Combat Wombat
    Reputation: BrianU's Avatar
    VT travel setting?
    I just got a 2003 VT-1 and love it. I'm currently running the front at about 105mm and I have the rear set at 5". The thing rocks on tight, twisty singletrack. I do not have to adjust my weight for turns, just stay in the middle and both the front and back stick to the ground like glue. I'm just wondering where other VT owners set theirs and how they handle?
    Brian
    Rollin' a fatty
    Reputation: DiRt DeViL's Avatar
    5" front and 5.7" rear
    I love the way it handles, specially when ridding with fat tires. It goes to wherever you want it to go, feels like it's on rails.
    Combat Wombat
    I am thinking about trying that.
    Quote Originally Posted by DiRt DeViL
    One of the great things about this bike. If I do not like it, I can switch it back.
    Brian
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    The VT1 I tested was set at 5.7” in the rear and I saw no need to even try to set it at 5”. The only reason I would even consider changing it to 5” would be if I were thinking of racing it (but that’s not my “thing”).
    Have been racing my VT3 at 5.7" on the rear but keep the front set at 90mm, I find the 90mm makes it handle the tighter switchbacks much faster and also stops the steering from getting too light on some of the more technical climbs.
    Rollin' a fatty
    Agree on the 90mm, I played with the travel setting on my Psylo and found out that the longer travel in the front the more lighter it became. I usually ride it around 100 to 110mm front travel but never at 125mm.
    Have tried the rear at both 5" and 5.7" and have found I like the handling better at the 5.7" setting. For the front I find that about 100mm is just right- have tried it at 125mm and did not like the feel. I use the 80mm front setting only when climbing steep rough terrain to help keep the front planted.
    I`ve tried the 110mm & 120mm settings on some of the more "wicked" downhill & rough sections of my favourite trail, and i really couldnt notice that much difference between them and having it set at 100mm.
    do you guys have any suggestions as to what setting i should have in my spv i weight 190 lbs.? also what tires for the front and rear should i get since my mosquitoes are worn out thanks
    Rollin' a fatty
    Let me see if I can remember (haven't used my VT recently), I'm 200lbs.
    SPV: 1 turn in, 100psi
    Main Chamber: 170psi
    Rebound: Half way
  1. How much travel does your fork really get?
    By Structure in forum Shocks and Suspension
    Last Post: 02-14-2004, 07:02 PM
  2. mxc travel adjustment?
    By dompedro3 in forum Shocks and Suspension
    Last Post: 01-26-2004, 04:06 PM
  3. Black Super Air travel adjustment
    By kpicha in forum Shocks and Suspension
    Last Post: 01-26-2004, 10:40 AM
  4. Replies: 7
    Last Post: 01-23-2004, 01:00 PM
  5. Replies: 4
    Last Post: 01-22-2004, 12:09 PM
