Tubeless Ready Setup- Mtbr.com
Results 1 to 6 of 6
    Feb 2012
    How does Giant deliver there tubeless ready bikes? Do they come with tubes installed, only need sealant added, require a rim strip, or something else? Wondering what to expect with my Anthem.
    Sep 2017
    The bike shop added the sealant to mine, a Fathom, when they prepped the bike for delivery. The tires were already set up and inflated when I did the test ride. I received the bike with tubeless wheels, including sealant installed and an extra bottle for later, ready to ride.
    Reputation: sturge's Avatar
    My new Kona came with rims taped, tubes installed, and tubeless valve stems in a bag. I removed tubes, inspected tape job (which was good), installed tubeless valve stems, and put in some Stan's sealant. Pumped them up and followed Stan's video guidance to ensure sealant is properly distributed to all portions of tire/bead, checked for leaks with a squirt bottle. Done!
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    Feb 2012
    Confirmed it was no tubes installed and tubeless ready. Just have to add the sealant.
    One downside. The valve cores aren't removeable. I've always liked adding sealant through the stem to avoid breaking the bead. Guess that won't be happening with this bike. Not sure why Giant went this route.
    Reputation: Steel Calf's Avatar
    Feb 2010
    Quote Originally Posted by josborn99 View Post
    because Giant is stupid, as easy as that. Outsmart them by installing new tubeless valves or suffer for a lifetime
    On which bike and wheels? I swapped tires on my new Anthem Advanced 29 Pro 1 last night and the stock valves did have removable cores.
  1. Tubeless Ready Rims w/o Tubeless ready tires
    By lukeschar in forum 29er Components
    Last Post: 05-11-2016, 08:27 PM
  2. Replies: 5
    Last Post: 10-18-2015, 04:08 PM
  3. Replies: 4
    Last Post: 05-30-2015, 10:03 PM
  4. How to make tubeless ready ready for tubeless
    By 3wheels in forum Wheels and Tires
    Last Post: 02-10-2015, 02:01 PM
  5. tubeless ready vs. non tubeless ready tires
    By tomfish in forum Arizona
    Last Post: 10-28-2014, 12:08 PM
