trance / recommended tire- Mtbr.com
Results 1 to 5 of 5
    Reputation: jean_luc's Avatar
    Mar 2006
    hi, everyone.
    someone says at this forum that TRANCE have cheeper tires originally.
    which tires do you recommend ?
    which size is maximum for trance's tire clearance ?
    Reputation: LyNx's Avatar
    To tell the truth the Bulldogs that come on the Trance aren't the greatest, but by no means are they totally horrible. Tyre choice really depends on where you live and the conditions of the trails you ride - , clay, sand, gravel, slick-rock, loose, hardpacked, wet etc .- so it's hard to recomend a tyre. Personally I ordered some of the KENDA Nevegals and they really are a nice tyre that work very weel, but can be a bit slow rolling on tarmac. Wouldn't recomend getting anything under the 2.1" version and would recomend the DTC compound.
    As for max tyre size for the Trance, so far the biggest I've run are 2.4" and in the dry they're fine, however in the wet you might get clogged up rather quickly.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Apr 2005
    I have Nokian NBX 2.3's, which complement the bike nicely.
    Mar 2006
    I got the Kenda Nevegal 2.1 Stick-E version. I'll be converting them over to no tubes once the weather dry up a bit.. I love to climb and need xtra traction on some loose single track and they seem like the right tire to use.
    Mar 2006
    how about Kenda Blue Groove is ?
    and what size tires fit for Trance3's XM117disc rim ?
    can I set Kenda's 2.35 size tire for it ?
