Thru-axle conversion possible on my Toughroad?- Mtbr.com
    Aug 2015
    I have a Giant Toughroad that I plan on using as my rigid 29er for single track use. The bike has been thoroughly upgraded with XT 1x11, Stans Arch EX, with a pair of Shwalbe Nobby Nic Addix 2.35 tires on the way. So now I would like to convert the wheels which are currently quick release, to thru-axle. Is it possible? If yes, what do I need? Thanks!
    Reputation: Steel Calf's Avatar
    Feb 2010
    yes you can do that (just the sake of having thru axles right?)
    you just need new frame and a new fork that support thru axles (probably new wheels too but since you conveniently didn't mention which Toughroad model you got I can only speculate on this)
    Aug 2015
    According to Giant, thru-axle isn't compatible with the Toughroad frameset. Oh well.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by steel calf View Post
    you just need new frame and a new fork that support thru axles (probably new wheels too but since you conveniently didn't mention which toughroad model you got i can only speculate on this)
    lol.
    A garage full of steel frames means happiness.
  1. Giant ToughRoad SLR 2
    By DG40 in forum Commuting
    Last Post: 01-28-2016, 05:35 PM
  2. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  3. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
  4. 2010 Crosstrail 15mm thru-axle conversion possible?
    By kermit_xc in forum Wheels and Tires
    Last Post: 04-10-2011, 07:52 PM
  5. Replies: 8
    Last Post: 02-10-2011, 03:36 PM
