swinger coil on reign- Mtbr.com
Results 1 to 3 of 3
    Dec 2005
    for the reign x yes.
    Motion activated
    Reputation: Steve71's Avatar
    I don't think the spring will fit in the basket, but I could be wrong. If you're looking for a plusher ride, then I'd stay away from a SPV'ed shock. A Pushed Float R direct from push is about $370 vs $350 for the Swinger. I'd be willing to bet the pushed float will be a way better shock.
    If a coil does fit I'd look at the Avalanche stuff. The have a basic shock without a piggyback for $399. It's not the correct I2I, but it is close enough that I think Id work ok.... but I would check on that.
    Happiness is a warm 2 stroke.
