RP23 on VT- Mtbr.com
Results 1 to 2 of 2
Thread: RP23 on VT
    RP23 on VT
    I'm tired of fixing my swinger over and over again.Will fox float RP23 fit on VT ? That bottom bolt is what i'm worried about. Will it fit fox eyelet or I need new mounting hardware ?
    Michal,
    Yes it will fit. If you are buying thru your LBS they should know correct shock sizing. I think it was 7.875 x 2.0 but don't quote me on that. Be aware the bushes from your Manitou swinger will not fit the RP23 and I also needed to drill one of them out to fit the top mounting bolt I think (was a while back).
    But other than that you will ask yourself why you did not do it sooner. The ride improvement is sensational. Matched it to some 2005 TALAS up front it is a new bike.
    Good luck
