Reign X, ISCG, Chainguide...- Mtbr.com
Results 1 to 5 of 5
    I need your feedback for a future assembly of a chainguide on Reign X with the ISCG old.
    To know if E13 DRS (E13 or others models) is assembled in ISCG or BB?
    Thank you to put a picture of each face if possible.
    Didn't it occur to you to check their website?
    http://www.e13components.com/product_drs.html
    I run an E13 SRS with a 40T chain ring and there are no clearance issues. i only needed to use 1 large spacer per bolt to get it spaced properly. now the one thing is that the ISCG mount tabs on mine anyways where not mounted correctly and i can not get the guide completely to 12 o'clock but that doesn't seem to effect anything.
    Hope that helps
    Scott
    i am running an STS which is abit more compact than the SRS and i had to do alot of machining to get my guide to fit. Giant is aware that their reign X frames have problems with the linkages getting into the way, and apparently are going to fix it for 08' ill believe it when i see it. the drs that comes on the stocker is BB mounted, the iscg old is the bolt pattern that should work. id try out the new FSA guide if i were you. it has tons of adjustment room.
    2020 Santa Cruz Megatower
    2019 Chromag Rootdown
    2019 Specialized Stump-jumper EVO 29er
    2015 KTM 1190 Adventure R
