Reign shock?- Mtbr.com
Results 1 to 21 of 21
Thread: Reign shock?
    Reign shock?
    Hi i am new I ahve just recently cotom built myself a 2007 giant reign. This one in fact.
    I have set the shock to the correct sag about 12mm. But at this pressure i can bottom the shock out off about 2-3 foot drops. This can't be right? Anyone got any ideas why and what i can do? apart from juts pump it up harder which i have done but it feels wrong like that.
    Dunk
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    well..that's what you should do.... it is a trade off between having a compliant rear and big-hit capability....
    other shocks offer a bottom out adjustment...but it is not the case in the "Float family" shock you have there
    do you bottom hard? or you just see that you used all travel?
    I can see it bottomed out and felt it
    Quote Originally Posted by MTB Dunk
    then you definitely need more air.. sorry.. maybe a tuning by Push could do something...
    Yeh i looked at mojo cutom valved but that is expencive adn so is push. On todays i ride i pumped it up more and it didn't bottom out, i lost a bit of small bump sensitivity but it still felt good . Though there still was a cluck on big hits any idea?
    maybe you can get from Mojo the "bottom out bumper" that PUSH sells...it is basically a thick rubber ring (from the pics I saw somewhere), the helps the shock in the end...
    no idea on the clunk.... but keep an eye on it....
    Will do cheers for the advice. You got a pic or link to this bottom out bumper?
    I only know from it around here... but check for example this post
    Quote Originally Posted by jmtazzy
    i ordered a rp 23 from push today. they actually ask you if you would like to increase the rear travel of the bike by putting on a longer stroke shock (25 dollars to price of shock). these people seem to know what they are doing in the industry so i went for it. also went for a bottom out bumper(20 dollars to price of shock) . all in all it will cost me around 550 bucks and will be a hell of an upgrade to my 05 reign. if i like the shock my fork will also go to them (07 talas) this bike just keeps gettin better and better!
    Sounds good. Will look into that. Thanks
    Reputation: tkblazer's Avatar
    smaller volume air can would help it be more progressive as well
    How can you change that?
    there are different size air cans/sleeves, for Fox shocks.... that is another possibility...
    Would it be another mojo thing or could it do it?
    you can get it from Mojo (it is a Fox part)...
    So do i want smaller or bigger?
    for progressiveness... smaller... (personally I would try the bumper first, as the smaller sleeve will prevent you more from using full travel too... just depends on what you want to go for)
    Yeh ok thats cool. I guess thats a ring up thing as i can't see them anywhere on there website. Right?
    yep.. I guess calling is best
    Cool cheers for teh help i will see what i can do
    no prob... glad to help out
    please post back with what you find out
