Reign Fox Talas Setup info wanted- Mtbr.com
Results 1 to 2 of 2
    Reputation: Pitto's Avatar
    i have just put a fox 36 talas [07] on my reign and i need some basic starting point information to get the fork adjusted.
    type of riding i do is AM, and i weigh 105kg's [230lb] with all my gear on. Anyone have some setup details that i can use and then adjust further once i am riding.
    G
    Quote Originally Posted by Pitto
    G
    I would adjust it in this order:
    - sag (air pressure)
    - rebound
    - low speed compression
    - high speed compression
    Once you learn what each adjustment does, you can dial it in for your riding.
