REIGN-Fox RP3 pressure- Mtbr.com
Results 1 to 3 of 3
    I am a little confused. To get proper sag (15mm-30%) I have to put in about 40psi more than my body weight (180lb=210lb pressure). I don't think I have ever ridden a bike where I have needed to use much more than my body weight and this is a high volume air shock so shouldn't it need less than average pressure?
    It's a '06 Reign2
    What pressure are others running?
    Reputation: tkblazer's Avatar
    fox shocks are fairly low volume and its common ti have to use a lot of air pressure.
    Come on winter!
    Reputation: ytc100's Avatar
    On my Trance's PUSHED Float R I run 150lbs and I weigh 140lbs.
    zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
