Rear wheel travel Giant Reign 27.5 2 LTD 2016- Mtbr.com
Results 1 to 10 of 10
    Giant Reign Advanced 1
    Reputation: ka81ua's Avatar
    Oct 2014
    Hi
    Could somebody please help with correct info about rear wheel travel - Giant Reign 27.5 2 LTD 2016 ?
    https://www.giant-bicycles.com/hr/re...specifications
    https://www.giant-bicycles.com/us/re...specifications
    https://www.giant-bicycles.com/gb/re...specifications
    OK
    Reputation: Steel Calf's Avatar
    Feb 2010
    not sure what your issue is but the amount of travel as stated on these three websites is the correct one
    click on your own links
    Oct 2014
    160 mm for front.
    what about rear? is it 6 or 6.25 or 6.3 inches ??
    p.s. you think i put links without watching them?..
    OK
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by ka81ua View Post
    160 mm for front.
    Where are you seeing the discrepancy(s), specifically? That would help....
    Wait whuuut, who did he tell you that!?!?....
    Feb 2010
    Hi
    160mm in above link
    6.3" in above link which equals 160mm!
    160mm in above link!!
    Still unsure?
    There are more ways to find out:
    Google for "Giant Reign" and ask a Friend to help interpret the results
    write Giant an email. They usually reply even to the dumbest requests
    Oct 2014
    First of all I don't see any info about REAR travel at all.
    I just suppose that front and rear the same and then it comes with 160 = 6.3.
    But, guys from https://www.tftuned.com/spring-calculator has written me: one says 6, another one 6.25.
    So, a little bit confused.. ))
    OK
    Feb 2006
    25.4mm = 1 inch
    160 / 25.4 = 6.29" ( round up to 6.3")
    Oct 2014
    It was interesting and funny, but not anymore.
    i gave links only to be clear what model (year) this thread is about.
    the queston is - did somebody ACTUALLY measured rear whel travel on any reign 2016 by YOUR OWN??
    I just measured without shock and it's 166 mm, which is 6.54". With shock frame is a little bit not stable while measuring so will wait until some help. Anyway, it's possible to be not 160 mm..
    it's important for me because I have to input rear whell travel to spring calculator, and even 6.3 and 6.5 makes a difference in spring rate.
    OK
    Oct 2014
    Well, here are the numbers:
    without shock - difference between heights is 166 mm
    with shock (air out) - difference between heights is 150 mm
    So, if such a type of measuring (linear) is correct the travel is 5.9".
    OK
    NedwannaB
    Your right was abit interesting at first, then not funny. You thru 3 links at us with it clearly stating rear shock 160m. I did not see anything spelled out in inches. Nor did you explain your reasoning for needing this info needing to be confirmed. Then you throw in additional info from some other source and measurements of your own.
    Surprised steel calf hasn't blasted you on it yet....:0
  1. Replies: 4
    Last Post: 03-30-2016, 11:28 AM
  2. Replies: 3
    Last Post: 10-06-2015, 03:05 PM
  3. Replies: 2
    Last Post: 06-10-2015, 10:18 PM
