Rear SID Pressure- Mtbr.com
Results 1 to 5 of 5
    New question here. Rear SID Pressure
    I am sure there have been similar questions....for those of you that are running the SID on a NRS what pressures are you using? Have you found the mfg suggested pressure works for you?
    Reputation: 02_NRS's Avatar
    softer ride=less psi/
    Quote Originally Posted by Sprocketty
    I weigh 175 & run 150 in top/ 60 in lower.experiment for what works best for you.also you may lose up to 10 psi when removing the pump hose fitting.
    \|/Home of the Braves\|/
    Reputation: RedRocker's Avatar
    I weigh about 180. I run 180+ and about 110-. You'll notice more pressure loss when you fill the - chamber than the + chamber. Fill it, disconnect the pump, then reattach the pump. Note how much you lost and compensate when you finalize the pressure.
    Big hoopy.
    Turner Sultan / On One Inbred
    Quote Originally Posted by RedRocker
    I weigh 165lbs and I use 165 + and 70 -. Sometimes when I feel beat and want to have a more supple trail ride, I lower the positive to around 150. Have never bottomed the shocks yet but then again I don't do too extreme trails and I don't drop much.
    mtbr remember
    Reputation: BikeSATORI's Avatar
    I weigh approx 150lbs w/ gear and I run 155psi+ and around 50- because I like it to ride semi stiff. The more psi you put in the -neg chamber the more it will respond to small bumps, which don't bother me since I ride mostly tech rocky rooty trails in the north country here. It's all preference and trail conditions- take your shock pump w/ you on a ride and mess around with your settings until you get it dialed in- start w/ your body weight in + and 50psi in the - chamber as a base setting and go from there. Good luck, and ride on
  1. More plush rear shock for my '03 NRS 2?
    By johnmre in forum Giant
    Last Post: 02-22-2004, 05:51 AM
  2. Your experience with SID rear shocks?
    By dgangi in forum Shocks and Suspension
    Last Post: 02-07-2004, 12:15 PM
  3. Should I be concerned about blowing a rear air shock?
    By mtn_man2 in forum Shocks and Suspension
    Last Post: 01-31-2004, 11:14 PM
  4. dawg rear shock psi and other q's
    By cudevil in forum Kona
    Last Post: 01-31-2004, 12:48 AM
  5. Burner rear shox question.
    By jensen23 in forum Turner
    Last Post: 12-29-2003, 11:58 AM
