NRS rear shock settings?- Mtbr.com
Results 1 to 5 of 5
    phazer
    Guest
    How do I know what PSI I need to set my shock to? Anyone got a chart or a forumla?
    Mar 2005
    If you have the Fox or the Rockshox then look here - http://www.giant-bicycles.com/us/050...50.500.100.asp.
    Jan 2005
    Rear Shock Setting
    Quote Originally Posted by phazer
    A\s per Giant specs your rear shock setting should be your body weight but in psi instead of pounds. At this setting Gaint guarantees no bob while pedalling even when standing. I use this setting when I am racing. When the off season comes around i lower the psi pressure to 80% of my body weight.
    I weigh 180 lbs so I pump up rear shocks to 180 psi, Racing Mode, In the Relaxed Mode so that there is some give whenever i go over bumps or ruts its at 80% of body weight or 145 psi.
    Aug 2005
    Good job! Rear Shock PSI - Rock Shock Sid
    You put your weight -- true riding weight including all the junk on you and added to your bike like a tool bag -- in the top and always put 50 in the lower.
    I weigh 190 and put 205 in the top. That's 205 prior to unscrewing the shock pump. Note that the tube holds some pressure. Leave it at the proper PSI. If you screw it back in, it will seem like it's too low, however, that's because you just pressurized the tube. Same with the 50 in the lower. If you put more in the lower, the thing will be too bouncey. The Giant "NRS" is not really an NRS (advertising gimmick) and needs proper tuning or it will bob terribly!
    Aug 2005
    I weight about 180lbs and have mine set to 170psi if thats of any help.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. NRS ait NRS1 and NRS2
    By phazer in forum Giant
    Last Post: 11-03-2004, 05:44 PM
  4. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
