NRS rear shock settings- Mtbr.com
Results 1 to 2 of 2
    Gimme my MOJO!
    Reputation: leleklegrunt's Avatar
    Hi all. Been tinkering around with my nrs rear shock, but noticed something. Been pumping the shock up (giants own nrs air shock) until I get no sag, but at that setting, I noticed that after a pretty hard ride, I'm only using about 1/2 of its stroke, by looking at the o-ring travle indicator. If I reduce the pressure so I use more of its travel, then I start getting sag and bob. Anyone got any suggestions on what to do?
    That sounds about normal
    Quote Originally Posted by leleklegrunt
    I've got the RS shock, but it works about the same. I rarely get more than half travel under normal riding conditions (Arizona XC). I don't do jumps or drop-offs for the most part.
    The NRS design is biased towards locked out for pedalling efficiency. Not the plushest design out there, but it helps me keep up with the twenty-somethings.
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Conflicting info for rear shock settings for EPIC
    By rollinrob in forum Specialized
    Last Post: 11-22-2004, 03:39 PM
  4. NRS SID rear shock rebound setting?
    By ekin in forum Giant
    Last Post: 06-09-2004, 08:10 PM
