NRS Headset Maintenace- Mtbr.com
Results 1 to 5 of 5
    gmw
    gmw is offline
    Jan 2005
    New question here. NRS Headset Maintenace
    Help!!!! I know this should be easy but I can't get the headset bearings out of my NRS2 (2004) to clean and re-grease them. What's the secret?
    [paste title here]
    Reputation: mtnbikerdude87's Avatar
    Quote Originally Posted by gmw
    it should be really easy. On my 03 NRS I just take off the fork and lightly pull out the cartridge bearings. Just clean off the drit and re-grease them. Pretty simple.
    Keep Pedaling
    mtbr remember
    Reputation: BikeSATORI's Avatar
    yeah, mine comes out super easy. just take off the fork/stem, then take off the cap on top and take out the cartridge bearings. Mine is the oem FSA btw, but even though I've had no probs w/ it, I'm looking at upgrading to the Cane Creek ZS-6.
    Schralp it Heavy.
    gmw
    gmw is offline
    Jan 2005
    When I've taken the fork and stem off there is a ring about 2mm thick that seems to be holding top and bottom bearings in place. It's this that I can't get off. Does it need brute force or does it unscrew?
    [paste title here]
    Is that the cover for the headset? If thats the case then it should slide off with a little force. On mine the cover needs to be slid off sometimes. The bottom ring should be the crown race. If there's a slit in it then thats it, also should be easy to slide off. Try tuning (CCW?) the rings and see if it does slide off, it might take some force but be careful not to break it. It could be that its new and just needs to be worked on.
    Keep Pedaling
  1. NRS Air 04 integrated headset?
    By Goose127 in forum Giant
    Last Post: 10-08-2004, 05:37 PM
  2. $1000 for a Giant '04 NRS 3
    By pcheninhk in forum Bike and Frame discussion
    Last Post: 09-05-2004, 10:13 AM
  3. Headset issues with 2002 NRS? (xposted to Giant forum)
    By Knucklehead in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2004, 10:30 AM
  4. Conventional headset for a NRS?
    By 2002NRS in forum Giant
    Last Post: 06-26-2004, 09:23 AM
  5. 2003 NRS 3 Headset Question
    By mdf in forum Giant
    Last Post: 03-20-2004, 08:07 PM
