New Headset for Reign - Need reco....- Mtbr.com
Results 1 to 9 of 9
    Just roll it......
    Reputation: ebxtreme's Avatar
    Hi all,
    I did a search, but didn't come up with anything. My stock cane creek headset is making some nasty clicking noises and has a bunch of play in it. I have no idea what kind of things could make that happen.
    Anyway, I figure this is time to upgrade it. Any good recommendations for the integrated headsets? FSA, Cane Creek, etc. with model numbers would be appreciated.
    Cheers,
    EB
    Reputation: tkblazer's Avatar
    i believe people have had no problems with the FSA orbit headsets, i think the orbit zr?
    Reputation: afliparlabill's Avatar
    FSA Orbit Z
    Just roll it......
    Thanks guys. I'll look into that asap.
    EB
    Nov 2006
    I went with a Cane Creek ZS-2 and I've had no problems.
    could get a semi intergrated hope one? bit more pimp maybe
    Reputation: The Rose's Avatar
    Your giant has a 50 mm head tube. There are a few companies that make the HS for it. Just be sure that the small cups have the chamfer on the bottom edge. The ones with the square edge wont fit. Just a side note, the head set is INTERNAL not INTEGRATED. Integrated headsets press bearings directly into the head tube, the HS on your giant has cups. I run the one from FSA on my Ac with no problems at all.
    Last of The Allaire Bastards
    Just roll it......
    Quote Originally Posted by The Rose
    thanks man. I realize my terminology wasn't straight after I did more research.
    Yeah, I just ordered an FSA orbit Z1 from Jensen that fits an OD of 50mm and ID of 44mm. Based on some info. I found, that should be fine. I put a mic on my Headtube and it was indeed 50mm, so I felt pretty confident with that purchase.
    Cheers,
    EB
    cool. I'm glad you found the one you needed.
