Installing hydraulic brake cable Toughroad SLR-0- Mtbr.com
Results 1 to 2 of 2
    I had to replace the front fork of this bike and therefore needed to pull the hydraulic brake line out of the fork - it threads into the fork just below the stem and back out lower down.
    In order to pull the cable through the holes I needed to cut the brake end of the house off as the ferrule would not fit through.
    How to I replace this ferrule? Does it need to be pressed on with a special tool? Alternatively can I use a shimano hose barb?
    thanks for any help.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Tektro Slate T4 hydraulic or what ?
    if OEM T4's you need these parts
    https://www.trpcycling.com/product/olive-and-barb-set/
    the barb can be tapped in with anything, the olive compresses by itself
    when you connect hose and tighten down on final install
    don't mix and match olives and barbs that's how brake systems can fail
    every maker has different fittings specific to their setup
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
  1. Giant Toughroad SLR
    By paulmich in forum Bikepacking and Bike Expedition
    Last Post: 02-11-2018, 10:05 PM
  2. 2018 Giant toughroad SLR 1 or 2
    By paulmich in forum Commuting
    Last Post: 11-21-2017, 08:55 AM
  3. Toughroad SLR 1 or 2
    By CS2 in forum Giant
    Last Post: 04-06-2016, 08:29 PM
  4. Giant ToughRoad SLR 2
    By DG40 in forum Commuting
    Last Post: 01-28-2016, 05:35 PM
  5. Replies: 23
    Last Post: 03-06-2014, 03:49 PM
