how to manual a reign- Mtbr.com
Results 1 to 15 of 15
    Nov 2006
    Any of you guys & gals can actually manual a reign.
    I am hanging so far of the back that I can use my nuts as a brake and still that front wheel mocks me.
    S.
    Quote Originally Posted by sebpiot
    S.
    I'm hopeless on my Reign X too...
    Mine isn't to bad. I just find pulling up then pumping your legs through and maybe a little pedal stroke and it come up fine
    Middle ring to middle ring tends to be the best gear to wheelie a reign in so maybe its the best to manual it in
    I'm bad at wheelies anyways, so much so that I had no clue what you mean by "manual a reign" but I find it really hard. I can, middle front chainring and middle on the back and I can do it, but its not easy, I wish it was.
    the secret is, the faster you go, the harder it is to get up, but the easier it is to hold.
    I can hold a wheelie for 1/6 to a quarter of a mile (no joke, ill try to put a vid on youtube)
    Nov 2006
    for those asking "what is a manual"
    it's very similar to a wheelie, in that the idea is to get the front wheel of the ground the difference is that in a manual you do not pedal to keep the froont wheel up. It's a matter of getting enough speed/momentum and then lifting the front wheel.
    Reputation: boogenman's Avatar
    I can manual my reign no problem. It motos great through whoops and whatever else I need to get over using only the rear wheel.
    The bike has a huge "sweet spot", I can ride a wheelie on it for a really long time, long enough where I change gears to keep up.
    Start out by doing some wheelies in the saddle so you get a feel of where the bike needs to be balanced.
    I can wheelie pretty good - better if there is a slight uphill, but cannot manual at this time! it is a hard move to learn!
    Nov 2006
    Quote Originally Posted by boogenman
    Well done, what stem and handlebars do you use. I am using the standard failrly flat bars I think the stem is between 70-90mm with 5deg rise
    S
    Dec 2005
    i think we need to work out lol, i cant pull up my bike for my life..(reign)
    i have problems maintaining, i can manual but sometimes its kind of weak and others i loop out
    Quote Originally Posted by sharpshooter
    no problem - keep your finger on the back brake and look for the balance point.
    My problem is pulling up the front (without a pedal kick), no issue with my other bikes.
    Scuffed
    Reputation: Amber's Avatar
    I just swapped out the 90mm stem for a 70 and now 60mm stem and it has made a huge difference making it heaps easier to loft the front wheel. It shifts your weight back on the bike so you use your legs, hips and ankles to loft it rather then just yanking on the bars. I use a combination of down and forward with my legs and up and back with the bars. I am seriously loving the shorter stem, specially with the 160mm Lyrics on the front. I find myself wheelying off anything I can find.
    NO REIGN NO GAIN
    ......MMmmmm
    Reputation: HighTitan's Avatar
    i dont have a reign but i know how to manual. your gonna wanna pull up and push your legs out in front of you kinda that way the rolls out from under you. your gonna use ur legs and arms to balance, by pumping them in and out to get your balance. it takes away so just keep practicing.
    i use to manual my BMX race bike over whoops, doubles, table tops and step ups. usually on the table tops i would do a "power wheelie" thats when you actually pedal in a wheelie across the top of the jump to get more speed. i have taken these skills and put them into downhill and its workin really good.
    I like to ride bikes fast.
