help make my reign a tad lighter- Mtbr.com
Results 1 to 11 of 11
    Dec 2005
    hey guys i havent rode my bike since a bad accident in may, and i tried it out yesterday and the thing is HEAVY (35, 36 pounds ). i know im probably a bit over weight (5'10 168), so im working on a diet as well as trying to make my bike lighter, this is the last known configuration.
    2005 Giant Reign 3 with
    2006 Marzocchi Z1 Light
    2005 Truvativ Holzfeller Cranks
    2005 Easton Ea 70 monkeybar
    2005 Hope Big'un front hub
    2006 Hayes Hfx-9, 8 front-6 rear
    2005 Kona jackshit pedals
    2006 Bontrager select comfort saddle
    2006 Lizardskin lock-on grips
    i am willing to change everything except the frame(duh) and the fork. the rims are stock so are the tires and i think these weight the most...any suggestions will be extremely appreciated.
    EDIT: i am pushing for sub 30 pounds, but im happy with looow 30s (31 hopefully no more)
    Gone riding
    You’ve got the right idea, tyres and wheel set will be the most noticeable upgrade.
    Some lighter, quicker rolling tyres will certainly make a noticeable difference. As always with bikes like this, it’s going to be a fight between saving weight and keep the strength in components where it’s needed.
    Dave.
    Reputation: Swerny's Avatar
    cranks and pedals after the wheels and tires.
    Mike
    Toronto, Canada
    2019 Scott Foil 10 Disc
    2019 Norco Search XR Steel
    2017 Trek Farley 9.6
    Reputation: tkblazer's Avatar
    Quote Originally Posted by MS MSP
    thats what i would say as well.
    and man i must really be a fatass, i'm 5'9 180lb
    Dec 2005
    ^ lol you might be muscular for all i know, i just havent moved a lot in quite a while so i do have fat for muscles in a lot of areas.
    also, any suggestions for wheelsets? i was thinking of crossmax XLs.
    Also cassette - my Reign X1 came with a SRAM cassette weighing ~450g. If yours is similar (which is likely with the 3 model) you can save 150g+ by getting an XT cassette, which can be found for reasonable prices.
    Crank - yeah XT/Hone will save a lot of weight.
    jones'in
    Reputation: venom600's Avatar
    Quote Originally Posted by fsrxc
    Which cassette did your X1 come with? Mine has a SRAM PG950. According to SRAM's website, it weighs 230g....?
    \m/ (>.<) \m/
    For Sale: Revox ISX 10.5x3.5
    Dec 2005
    Here's mine with the mods I've made from stock- other than the fork, hub and front disc they've all saved considerable weight:
    '06 Reign 2
    Upgrades from stock:
    Pike 454
    North Shore Billet 20mm hub
    180mm front disc
    RaceFace Deus XC stem
    Syncros Gain OS bars (soon to be RaceFace Next SL carbon)
    ODI Rogue lock-ons
    SDG I-beam post (soon to be Kore carbon I-beam)
    SDG Bel-Air SL seat
    M2 racer seatpost clamp
    RaceFace Deus XC cranks
    Exustar Ti pedals
    XTR shifters
    XTR rear derailleur
    XTR cassette
    Continental Vertical protection tyres
    Maxxis Flyweight tubes
    Quote Originally Posted by venom600
    Yeah, that's for the 11-26 though, not 11-34.
    Weight Weenies does list this:
    SRAM PG-950 2004 11-34 9-speed 386 g
    SRAM PG-950 2004 12-26 9-speed 228 g
    I weighed the cassette when I took it off and it was ~450g, but I really can't remember if there was a part number on it. I'll check next chance I get.
    I got a deal on an XTR 11-34 which is ~250g, but XT or PG-990 would be the best gram-for-buck value.
    jones'in
    Whoops, my bad. Didn't even look at the gearing.....
    \m/ (>.<) \m/
    squish is good
    Reputation: Clutchman83's Avatar
    I'm assuming your using the Hutchinson Bulldog 2.1 tires if it's an '05. Ditch those things and get a set of folding bead Nevegal 2.35's. Consider switching to tubeless, that will save you plenty of rotating mass and the Nev's works so much better than those crappy old bulldogs. I usually buy the cheapest strongest wheelset I can and then just swap to tubeless and it still is lighter than a good wheelset with tubes and wire bead tires, If you have the scratch to get a better wheelset then it's all just gravy after that!
