Headset Play please help- Mtbr.com
Results 1 to 9 of 9
    Jul 2014
    I have been scratching my head over some slight play in my Son-in-laws XL 2017 Trance 4 headset. There is a clunky feel when you hold the front brake and rock the bike back and forth and so far I have:
    1. Re-greased the headset but the problem remains
    2. Swapped out the bearings and compression ring
    3. Tryed a different stem
    4. Tried a different wheel
    5. Swapped the fork
    After all of these attempts the problem remained. The only parts I didnít swap were the pressed in cups and also the top cone spacer (I should have swapped the cone spacer I will try that next). The bike is brand new only been on maybe 12 rides so I canít believe the cups need to be replaced. He went OTB once off a drop and the steerer needed to be re-aligned but it was a minor crash... Does anyone have any ideas?
    Reputation: Steel Calf's Avatar
    Feb 2010
    you haven't swapped the frame yet. Maybe the bearing socket has ovalized due the crash?
    If there is a major movement but you cannot locate the source find someone that can. Very hard to determine the cause over the Internet. Or maybe the installation is just wrong, I've seen people tightening the stem screws first before tightening the headset screw (which preloads the bearings)
    Jul 2014
    Quote Originally Posted by Steel Calf View Post
    Thanks for the reply! Actually I did... rebuilt on my frame with his fork and bearings etc. and it was solid as a rock. Iím beginning to think the socket has ovalized like you say - which Iím finding hard to believe as it was such a minor crash.
    Reputation: Ride1424's Avatar
    Oct 2016
    Enough spacers being utilized to get proper compresion of the headset? Is the top cap bottoming out?
    "In dog beers......... I only had one"
    Can you feel the clunky from the head set? Does the stem and head tube wiggle/clunk when you rock the bike?
    I ask because it could be the rear shock mounts that's loose. It gives the sensation of a loose headset when you lock the front brake and rock the bike
    Jul 2014
    Quote Originally Posted by the-one1 View Post
    Interesting! Iím 98% sure itís the headset because when I hold on to the stem and rock the bike back and forth I can feel it in my hand... Next time I have his bike at my house I will investigate this. I have a new headset on order so we will see...
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Have you asked your Giant dealer where the bike was purchased for assistance or advice?
    Jul 2014
    Yeah he took it there today and they agree there is play in the headset. A new headset has been ordered...
    Jul 2014
    Update!
    I was riding with my son in law today and got a chance to look over the bike again. the-one1 you were absolutely right! The rear shock mounts had come loose problem solved! Donít need a new headset... so anyone who has a loose headset feeling check your shock mounts!
    Cheers to you the-one1!
  1. FSA Headset issues, play in headset
    By Gillroy in forum Components
    Last Post: 11-14-2017, 10:03 AM
  2. Replies: 6
    Last Post: 07-27-2015, 10:17 AM
  3. Replies: 5
    Last Post: 09-12-2011, 04:13 PM
  4. Lefty headset/cups/steerer tube movement/play
    By xsanmarco in forum Cannondale
    Last Post: 08-28-2011, 07:53 AM
  5. mojo headset play?
    By kattrap in forum Ibis
    Last Post: 06-17-2011, 06:23 AM
