Giant hubs on xc1 and xct1?- Mtbr.com
    Sep 2017
    What type of hub/bearings do these giant hubs use? Trying to figure out what to do with some rear giant wheels I have with dented rims.
    When you pull them apart are that prawl based or ratchet? If ratchet then depending on the year type either DT Swiss 240 or 350. I believe the dimension are the same but the quality of the bearings are different.
    Sep 2017
    I have not taken them apart yet. The xc1 rim is off a 2017 trance 2. The xct1 rim is new this year also. I dented both rims on rocks....Trying to figure out if it is worth having the hub relaced....
    Giant was using the 240/350 based hubs when they started their "wheelsystems" but they have switch a number of them except for the very high end ones to DT Swiss 360 prawl based hubs. IMO not a great candidate for a relaced unless you are really press for $$$. On the current xct1 the website does not state that it is star ratchet based which means its not.
  1. bottom bracket needed for KCNC bearbone xc1 cranks
    By rivertrash in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-18-2015, 07:07 AM
  2. What's the diff between mtb hubs and cx hubs?
    By MI-29er in forum Wheels and Tires
    Last Post: 12-23-2014, 03:05 PM
  3. XCT1 warranty info
    By terrasmak in forum Jamis
    Last Post: 01-22-2014, 10:36 AM
  4. hubs hubs hubs
    By rho in forum Singlespeed
    Last Post: 05-31-2013, 07:34 AM
  5. easton xc1, ex2, or havoc
    By zachkh in forum Wheels and Tires
    Last Post: 03-23-2011, 08:19 PM
Members who have read this thread: 7
