Giant bicycle information, contact info ?- Mtbr.com
    I am interested in purchasing a Trance 2 29er frame, size XL. I need to find out the maximum seatpost insertion depth to see if my 200mm dropper has enough insertion depth. How to go about getting this info? Thanks.
    Reputation: MSU Alum's Avatar
    I didn't know you could buy a 29 2 alloy frame. I'd call an LBS and ask them if they know.
    Quote Originally Posted by MSU Alum View Post
    Itís a used frame on Ebay. I questioned the seller but he said he didnít have a post to check (???) I called the local Giant dealer and they had a hard time figuring out what I was asking - life is tough when you are vertically challenged.
    Quote Originally Posted by keen View Post
    I don't know how much this helps, but this is on a medium Pro 1:
    It's just a measure of the seat tube, above the pivot. Obviously, you can't get more insertion than that, but I don't know if all of it is useable. That section of seat tube is straight, though.
    That section is 240mm , so I'm guessing it would work. When you say a 200mm dropper, I'm assuming you are referencing the length of the dropper that can be inserted.
    Attached Thumbnails Attached Thumbnails Giant bicycle information, contact info ?-20181119_075943-resize.jpg
  1. IRO contact information.........
    By charliethetuna in forum General Discussion
    Last Post: 02-22-2015, 09:52 AM
  2. Replies: 0
    Last Post: 05-24-2013, 09:15 AM
  3. Cole wheels contact information
    By aph72 in forum Wheels and Tires
    Last Post: 10-21-2012, 04:30 PM
  4. USA Giant Contact Information
    By NoBrakes! in forum Giant
    Last Post: 01-17-2008, 05:00 PM
