Is the front fork of the Anthem Advanced SX 2015 adjustable?- Mtbr.com
Results 1 to 5 of 5
    Sep 2014
    I am getting mixed information about this. I am told the fork that is used is used is adjustable up to 140 with a new air spring.
    The shop told me that's not the case. But I've read on a few places online that it is?
    Can anyone clarify?
    RockShox Revelation RL w/ 15mm thru-axle, OverDrive steerer, 120mm travel
    Edit:
    Called SRAM, the answer is apparently yes. I may go up to 130mm if it's a cheap/easy fix.
    Sep 2014
    So it looks like it will cost me $100.
    Currently it's 120 travel on the front, would I notice any difference going to 130? This wouldn't be an issue for the frame?
    Reputation: sturge's Avatar
    Not much of a change in travel (10mm = .39 inches). You mention cheap/easy 'fix'...are you fixing a problem or just looking to increase travel? Not thinking 10mm will make a big difference...maybe the compression and rebound circuits will feel different due to the change in internals? As for frame...check with mfg on warranty impacts.
    Years ago I 'over forked' a Trek Fuel 98 and rode it for a couple of years that way (I think I went 120mm to 140mm). It was a used frame so no warranty. I'm sure your Anthem will ride fine with only 10mm increase in front...may require a more forward body position adjustment to adjust CG for climbing.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    Sep 2014
    Well looking to increase travel really. The xc trails around here are pretty technical, lots of rocks and roots that I find my angle is a bit to steep at times and hard to put my weight back and I feel like I'm going to get bucked over the bars when the trail gets steeper and gnarly. Pedal strikes are also a pain.
    Jun 2014
    One thing to watch out for is the seat tube angle, it's already slack on that bike since it's meant for a 100mm fork. Something to consider if you also do a lot of steep technical climbing.
  1. Replies: 28
    Last Post: 09-27-2017, 11:15 PM
  2. Replies: 22
    Last Post: 06-05-2016, 08:50 PM
  3. Anthem SX advanced 2015 / Anthem SX 1 2016
    By Kulharin in forum Giant
    Last Post: 10-14-2015, 08:14 PM
  4. Replies: 11
    Last Post: 12-25-2013, 10:12 AM
  5. Replies: 9
    Last Post: 01-28-2012, 05:32 PM
