Flexpoint suspension torque specs- Mtbr.com
Results 1 to 3 of 3
    Reputation: scoobiemario's Avatar
    Aug 2016
    I'm trying to find torque specs for Flexpoint suspension for my 2016 Stance. No luck so far.
    Can anyone help?
    More you beef it up, more it will handle like a cow....:skep:
    Oct 2016
    I doubt you will be able to find them online. I would either shoot giant an email or maybe even call your local giant dealer. For the most part I think you will be ok without an exact torque spec for the bolts that hold the rear triangle and shock on. I would say use common sense taking into account how big the bolts are. When you are done take it for a ride or two and check them after
    Aug 2016
    Well, bummer....
    but I've found discussion about Maestro suspension:
    http://forums.mtbr.com/giant/2014-tr...al-946341.html
    And manual for maestro:
    http://www.ridelife.ca/manuals/Giant...eManual_v2.pdf
    Seems that "Gut 'n tight, but not too tight" is tight enough.
    I'll follow numbers from Maestro manual and see how it goes.
  1. Frame Suspension Pivot Torque Specs for a 2010 GT Sensor 1.0
    By dbarberic in forum Shocks and Suspension
    Last Post: 10-05-2016, 09:39 AM
  2. Giant Maestro vs. Flexpoint suspension
    By theberk in forum Shocks and Suspension
    Last Post: 03-12-2016, 04:57 PM
  3. Help: 2013 Maestro Suspension Torque Specs???
    By thrash_273 in forum Giant
    Last Post: 04-30-2014, 12:06 PM
  4. Replies: 14
    Last Post: 01-23-2013, 11:41 AM
  5. Replies: 5
    Last Post: 10-21-2012, 12:02 AM
