Dropper routing Giant Trance 2017- Mtbr.com
Results 1 to 5 of 5
    Nov 2017
    Has anyone done this before? If so can they offer any advice. I can't see anything when I look down the seat tube. Should I start from the top tube and feed a gear cable down first? It's a Brand X dropper.
    On other frames I've fitted them to before the cable exits the downtube and re-enters the seat tube but the 2017 Trance doesn't do this.
    Reputation: armii's Avatar
    Jan 2016
    There should be a small hole inside the seat tube above the BB. Angle is very tight, so routing from the bottom up should be easier.
    Nov 2017
    Quote Originally Posted by armii View Post
    So start from the cable entry in the top tube and start feeding it in there?
    Jan 2016
    From the seat tube I would think, https://www.youtube.com/watch?v=ZdrmmL6HxH4
    Sep 2017
    I've done it on a 2017 Trance Advance 1. There is a rubber tube that guides the cable housing/cable between the bottom bracket and seat tube. This tubing is long enough that you can see it from the seat tube.
    Unfortunately when I did mine when I pulled the cable housing out that rubber tube came out as well. I tried to install the new housing without the rubber tubing but its hard for the cable housing to navigate around the bottom bracket, its such a tight fit.
    I had to remove the cranks and bottom bracket to get the rubber tube back in place. It was a PITA, but I did learn a lot about the bike.
  1. 2017 Santa Cruz Bronson vs. 2017 Giant Trance 2
    By bear99 in forum All Mountain
    Last Post: 09-04-2017, 11:27 AM
  2. 2017 Norco Sight vs 2017 Giant trance
    By paddy73 in forum All Mountain
    Last Post: 07-28-2017, 02:44 PM
  3. Advice Needed: 2017 Giant Trance vs 2017 Trek Remedy
    By Mluisgr81 in forum Beginner's Corner
    Last Post: 03-05-2017, 05:57 PM
  4. Should I get a Giant Trance 3 2016 or a Giant Trance 3 2017?
    By harell286 in forum Beginner's Corner
    Last Post: 01-04-2017, 09:25 PM
  5. Replies: 9
    Last Post: 12-08-2016, 12:16 PM
