D Fuse Seat Post Question- Mtbr.com
Results 1 to 5 of 5
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Anyone have anything, good or bad, to say about the D Fuse post? I'm not a big fan of non standard parts. And a D shaped seat post is as non standard as it gets.
    A garage full of steel frames means happiness.
    I have a D Fuse post on my TCX. It provides flex and you never have to worry about the saddle being straight so it's really fast to adjust the seat height if necessary.
    CS2
    CS2 is offline
    Quote Originally Posted by Stonerider View Post
    Thanks, what works in practice is sometimes different than theory.
    Quote Originally Posted by CS2 View Post
    I have a 2015 TCX and I have never had any issues with the seatpost. The clamp works perfectly even with my heavy butt. The offset was a concern but I was able to find enough adjustment for my fit. Giant also sells a zero offset seatpost if needed. I probably have 3K dirt miles and 400 pavement miles on it. With bikepacking I have hung some 25lb loads from the seat rails and secured to the seatpost with no issues either.
    Reputation: MarinCRO's Avatar
    Jul 2013
    I had Dfuse on my 2015 Defy and it kinda worked.
    The auto align feature wasn't that "auto" and it would always turn to the side a bit and you had to hold it to be in the center.
    Single bolt head is also pain to use, 2 bolt heads are far better.
  1. 2017 Specialized Fuse Expert worth the $$$ over the Fuse Comp
    By RumRunnerXT in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 06-25-2019, 02:27 PM
  2. Standard seat post size MTB? I need a shim for my seat post. 30.9?
    By ReturnOfTheMTB in forum General Discussion
    Last Post: 04-05-2016, 01:14 PM
  3. Seat post min insertion into a frame with seat tube brace question
    By Strife21 in forum Bike and Frame discussion
    Last Post: 07-24-2015, 09:36 AM
  4. Replies: 68
    Last Post: 10-01-2013, 06:31 AM
  5. Thomson seat post base on an Easton seat post?
    By steveccnv in forum General Discussion
    Last Post: 06-23-2011, 06:51 PM
