Anthem Rear Shock Set Up- Mtbr.com
Results 1 to 2 of 2
    I just bought Giant Anthem, International version with black links and it comes with Giant Maestro-A rear suspension. The suspension set up guide recommends sag of 6mm for the rear suspension. However, if I follow the recommended PSI guide for my body weight, the PSI is much higher, therefore the sag is only 1mm. Which recommendation should I follow?
    Reputation: Captain's Avatar
    Takes a good hour atleast for a new shock to wear in so you are best off setting again after a decent ride. I think you are also better off setting sag by sight 1st rather than psi recommendations.
