anthem ground clearance annoyance- Mtbr.com
Results 1 to 5 of 5
    i would like to improve ground clearance on my anthem, but not sure what i can do to improve on what i have done so far...I have already removed the big ring up front and replaced it with a bash guard, and is there any other option to improve the ground clearance?
    buy a Reign?
    Never had clearance problems when I had my Reign. Come to think of it, I am not having any clearance problems with my Anthem either- running a 22/36/bash up front. Maybe your trails are too hairy for an Anthem...
    Live Free or Ride!
    Reputation: GiantMartin's Avatar
    I don't find the anthem to have any more clearance problems than any other bike. Slap a bash guard on 'er
    2007 Giant Anthem 1
    2009 Giant XTC 0
    bi-winning
    Reputation: rkj__'s Avatar
    not much you can do. get big tires and a 100mm fork maybe.
    I AM I AM
    Reputation: ducktape's Avatar
    Yep a bigger fork certainly helps with the ground clearance. A bashguard is a good step but still leaves the pedals low to the ground.
    I ran a 130mm fork on my Trance and then jumped on my Husbands new Alias, geez I neraly fell of pedalling around the corner because the pedal hit the road. I know it's not exactly ideal but after transferring the 130mm fork onto the Alias the pedal clearance problem is gone!
    If you don't want a longer fork then shorter cranks, but that of course has it's disadvantages too. Otherwise go and buy the new Trance X - only 200g heavier after all!
