2018 Trance Advanced 1 which thru axle ?- Mtbr.com
Results 1 to 9 of 9
    Jul 2014
    I wanted to replace the thru axle that requires an allen wrench on my 2018 Trance advanced 1 with one that has the little handle on it but I don't know the size or which one to go with. I saw some on the dt swiss site but I don't know about the size or if boost makes any difference. ANy help would be greatly appreciated. I wanted one for the front and back.
    https://www.dtswiss.com/en/products/hubs-rws/rws/
    Reputation: grubetown's Avatar
    Sep 2013
    If your fork is Fox, which I believe it is, get a Fox one. It is boost. Boost in the rear also. Why do you want it for the rear?
    Jul 2014
    It does have the Fox 34 elite. The reason I ask is convenience on the trail if I need to address a flat. I just came noticed this one on Jenson, anyone familiar if this handle (lever) just connects to the existing thru axle that came with the bike.
    Sep 2013
    My recommendation would be to convert to tubeless.
    Reputation: MSU Alum's Avatar
    Just bring a 6mm hex with you. You probably have one anyway.
    I was considering swapping out a through axle also, so that if I needed to throw the bike in the car, it would be more convenient to remove the front wheel. Turns out it's just not much of an issue.
    Reputation: slomtbr's Avatar
    Oct 2010
    The bike should have come tubeless. As often as you'll have to remove wheels, I'd keep the stock thru axles. Keep a hex wrench rolled up in your emergency tube.
    Almost = Didn't
    Reputation: MarinCRO's Avatar
    Jul 2013
    I'd suggest you get Specialized bottle cage with the little EMT tool on the end. This is great combo and keep tooled axles on the bike since they're lighter and won't catch trail obstacles.
    you can still flat tubeless
    Reputation: Swerny's Avatar
    Just carry a multi tool with a 6 mm wrench
  1. 2017 Trance Advanced 1 vs 2018 Trance Advanced 1
    By baraant in forum Bike and Frame discussion
    Last Post: 08-16-2018, 01:43 PM
  2. Replies: 9
    Last Post: 12-23-2017, 12:37 PM
  3. Replies: 3
    Last Post: 06-05-2016, 10:29 PM
  4. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  5. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
